macbook pro a1989 macbook started But no screen on extern or intern display.
  • SaYHell0
    • Jun 2023
    • 9
    Hello i guess i have another logic board as the usual a1989?
    Iam new into smd fixing but i want to learn That because that makes so much fun
    I guess i Found my Problem?
    Problem was: macbook started But no screen on extern or intern display.
    Cpu/gpu was very Hot after trying a few commands with reboot
  • SaYHell0
    • Jun 2023
    • 9
    Re: macbook pro a1989 macbook started But no screen on extern or intern display.
    i could not find any brd file for my logic board...
    after replacing the thermal paste of the cpu and gpu the macbook starts with full rpm of both fans...
    Anyone any clues?
      • 20637
      Schematc & Boardview -> https://www.badcaps.net/forum/showthread.php?t=76497
      • SaYHell0
        • Jun 2023
        • 9
        Edit: On Windows i can see everything
        Thank you!
        The "burned" part on my logic board is missing on the schematic... Could that be from the U5710?
        • SaYHell0
          • Jun 2023
          • 9
          Where do you guys gets the parts?
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            depends on what part u need. for resistor i got that sample book with the most common resistor and capacitor values.
            for different unique type i get from donor board, or make order from digikey or mouser.
            for ic and so on i go to aliexpress or china in general or digikey or mouser.
            • SaYHell0
              • Jun 2023
              • 9
              Thank you so much!
              and special like that, how or where can i find that?:
              or what is the name of that? how can i find the name?
              • mon2
                • Dec 2019
                • 13986
                Each logic board from Apple / Foxconn has a 820-**** part number etched onto the PCB itself. Using this as a guide, you may be able to locate the schematic on this forum.
                For example, A1989 = 820-00850 and the schematic is posted here in post # 33:
                https://www.badcaps.net/forum/showth...0-00850&page=2
                • SaYHell0
                  • Jun 2023
                  • 9
                  Thank you so much guys. I love to do that. But i rly cant find the "destroyed" parts to buy.
                  Do you have anywhere a guide to find the name of the parts? like transistor etc.
                  • SaYHell0
                    • Jun 2023
                    • 9
                    if i got the part number in the schematic, where can i search for that to buy?
                    • mon2
                      • Dec 2019
                      • 13986
                      The vendors / stores will vary.
                      For simple passive parts like resistors / capacitors - suggest Digikey or Mouser or Arrow Electronics. They are international firms.
                      For rare parts that are often on these logic boards by Apple / HP / Dell - suggest AliExpress.
                      Apple will often have parts custom made to their specs to make it more difficult for techs to repair these units but they magically appear in Asia on AliExpress.
                      • Stephen
                        Meow Meow MEOW!
                        • Apr 2020
                        • 667
                        Donor Boards are your friend. Always keep them and never throw them out. You’ll come to a point where you need them. All sizes 13” 15” 16” keep them. We have over 200 in stock. Just repaired a dead board that had a bad diode that was blown, (clean board) had a failed u7000, resistor as well and blown cap. One board we had didn’t have all the parts but we had 3 boards left with all the parts and got the board repaired.
                        sigpic
                        MEOWING IN THE IMPOSSIBLE UNIVERSE!
                        • SaYHell0
                          • Jun 2023
                          • 9
                          Thank you so much guys!
                          You have some agenda or something to see what the parts looks like? I mean how the resistor or something looks like?
                          What do you guys do, if your part is obvisouly burned but not on the schematic?
                          Macbook starts but doesnt show anything on screen with hdmi adapter either...
                          • ErinV
                            MacBook Pro A1989 820-00850-A not powering on
                            by ErinV
                            Hey everyone!
                            I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                            I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                            The diode voltages around all 4 CD3215's seem fine.
                            For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                            09-30-2024, 10:21 PM
                          • Madoy104
                            Macbook Pro A1989 - No image, working fine with external monitor
                            by Madoy104
                            I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                            08-15-2024, 10:01 AM
                          • PITERPENY
                            Macbook A1989, 820-00850, won't boot. 20V, 0A.
                            by PITERPENY
                            Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
                            Here are some measurements, maybe someone can tell what the problem is.
                            The initial problem was a burnt out induction coil L8504 (replaced).
                            When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
                            here are some measurementsmotherboard...
                            01-16-2024, 02:19 PM
                          • Nikan.e
                            MacBook A1989 repair / no CPU voltage no boot signs
                            by Nikan.e
                            Hello everyone.
                            I have recently obtained a MacBook Pro A1989 model with a touch bar and Apple ID. Unfortunately, it does not want to start up.
                            No CPU Voltage.
                            U7800 Does produce voltages.
                            T2 Chip warming up very very little.
                            I do have voltages like 1.8, 0.9, 3.3, 2.5 volts, etc., present. I did not find any short circuits. Unfortunately, the device has no touch ID/start button. So, I have used the debug jumper to put the device into DFU mode. - It is getting recognized as a Macintosh while not in DFU mode and as Apple (DFU) while in DFU mode....
                            11-24-2023, 11:55 PM
                          • biosdi
                            MacBook Pro A1989 trackpad and keyboard not working
                            by biosdi
                            Hi guys.
                            I Just replaced battery on my MacBook Pro A1989. Unfortunately doing that, I’ve broken the trackpad flex cable (821-01701-a), and I’ve already ordered a spare one. At the same moment I’ve noticed that also the keyboard it’s not working anymore and I’ve found an SMD chip unsoldered and moving freely inside the backplate. I can read L20L on the chip. Is something could explain the keyboard not working or the keyboard doesn’t work due the unconnected trackpad?
                            thanks...
                            04-17-2025, 09:42 AM
