macbook pro a1989 macbook started But no screen on extern or intern display.
  • SaYHell0
    • Jun 2023
    • 9
    Hello i guess i have another logic board as the usual a1989?
    Iam new into smd fixing but i want to learn That because that makes so much fun
    I guess i Found my Problem?
    Problem was: macbook started But no screen on extern or intern display.
    Cpu/gpu was very Hot after trying a few commands with reboot
  • SaYHell0
    • Jun 2023
    • 9
    Re: macbook pro a1989 macbook started But no screen on extern or intern display.
    i could not find any brd file for my logic board...
    after replacing the thermal paste of the cpu and gpu the macbook starts with full rpm of both fans...
    Anyone any clues?
      • 22030
      Schematc & Boardview -> https://www.badcaps.net/forum/showthread.php?t=76497
      • SaYHell0
        • Jun 2023
        • 9
        Edit: On Windows i can see everything
        Thank you!
        The "burned" part on my logic board is missing on the schematic... Could that be from the U5710?
        • SaYHell0
          • Jun 2023
          • 9
          Where do you guys gets the parts?
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            depends on what part u need. for resistor i got that sample book with the most common resistor and capacitor values.
            for different unique type i get from donor board, or make order from digikey or mouser.
            for ic and so on i go to aliexpress or china in general or digikey or mouser.
            • SaYHell0
              • Jun 2023
              • 9
              Thank you so much!
              and special like that, how or where can i find that?:
              or what is the name of that? how can i find the name?
              • mon2
                • Dec 2019
                • 14693
                Each logic board from Apple / Foxconn has a 820-**** part number etched onto the PCB itself. Using this as a guide, you may be able to locate the schematic on this forum.
                For example, A1989 = 820-00850 and the schematic is posted here in post # 33:
                https://www.badcaps.net/forum/showth...0-00850&page=2
                • SaYHell0
                  • Jun 2023
                  • 9
                  Thank you so much guys. I love to do that. But i rly cant find the "destroyed" parts to buy.
                  Do you have anywhere a guide to find the name of the parts? like transistor etc.
                  • SaYHell0
                    • Jun 2023
                    • 9
                    if i got the part number in the schematic, where can i search for that to buy?
                    • mon2
                      • Dec 2019
                      • 14693
                      The vendors / stores will vary.
                      For simple passive parts like resistors / capacitors - suggest Digikey or Mouser or Arrow Electronics. They are international firms.
                      For rare parts that are often on these logic boards by Apple / HP / Dell - suggest AliExpress.
                      Apple will often have parts custom made to their specs to make it more difficult for techs to repair these units but they magically appear in Asia on AliExpress.
                      • Stephen
                        Meow Meow MEOW!
                        • Apr 2020
                        • 674
                        Donor Boards are your friend. Always keep them and never throw them out. You’ll come to a point where you need them. All sizes 13” 15” 16” keep them. We have over 200 in stock. Just repaired a dead board that had a bad diode that was blown, (clean board) had a failed u7000, resistor as well and blown cap. One board we had didn’t have all the parts but we had 3 boards left with all the parts and got the board repaired.
                        sigpic
                        MEOWING IN THE IMPOSSIBLE UNIVERSE!
                        • SaYHell0
                          • Jun 2023
                          • 9
                          Thank you so much guys!
                          You have some agenda or something to see what the parts looks like? I mean how the resistor or something looks like?
                          What do you guys do, if your part is obvisouly burned but not on the schematic?
                          Macbook starts but doesnt show anything on screen with hdmi adapter either...
                          • MyronViegas
                            MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
                            by MyronViegas
                            Hey guys,
                            I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
                            Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
                            10-06-2025, 08:45 AM
                          • ErinV
                            MacBook Pro A1989 820-00850-A not powering on
                            by ErinV
                            Hey everyone!
                            I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                            I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                            The diode voltages around all 4 CD3215's seem fine.
                            For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                            09-30-2024, 10:21 PM
                          • Madoy104
                            Macbook Pro A1989 - No image, working fine with external monitor
                            by Madoy104
                            I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                            08-15-2024, 10:01 AM
                          • tommy97
                            MacBook A1989 No power
                            by tommy97
                            I’m having an issue with an A1989 board after water damage, it’s stuck at 5V 0.20A. I’ve checked the measurements, and all readings are the same across all four CD3215 chips. I replaced them one by one (using chips from a donor board), but nothing has changed.
                            I don’t need a fully functional board, as the repair is only for data recovery purposes.
                            • PP3V3_G3H: 3.3V
                            • PPBUS_G3H: 12.26V
                            • PP20V_USBC_XB_VBUS 5V
                            • PP3V3_UPC_XB_LDO 3.3v
                            • PP1V8_UPC_XB_LDOA 1.8V
                            • PP1V8_UPC_XB_LDOD 1.8V
                            • PP1V1_UPC_XB_LDO_BMC 1.1V
                            Can the A1989 work with just one master CD3215? What would...
                            10-16-2025, 01:57 PM
                          • PITERPENY
                            Macbook A1989, 820-00850, won't boot. 20V, 0A.
                            by PITERPENY
                            Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
                            Here are some measurements, maybe someone can tell what the problem is.
                            The initial problem was a burnt out induction coil L8504 (replaced).
                            When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
                            here are some measurementsmotherboard...
                            01-16-2024, 02:19 PM
