MacBook Pro 16” 2019 Boots installs os Catalina but won’t install Ventura or lower.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Re: MacBook Pro 16” 2019 Boots installs os Catalina but won't install Ventura or lowe
    We downloaded BIG SUR and upgraded into Big Sur. Tried the same thing for Monterey and Ventura to no avail. Those installs were then copied to external USB and tried on another 16” to successful installs. And you can install external as long as you change the security settings.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
    • ugamazing
      • Jun 2013
      • 171
      • usa
      When you keep saying the updates/installs (beyond Catalina) "fail", do they all fail the same way--i.e. hanging during final stages of install (black screen, Apple logo, progress bar, XX minutes remaining, etc)? What happens if you try to install Monterey/Ventura on a connected USB drive (after disabling T2 boot security settings on board via IR)?
      Do you see any indications of this board being a previously-refurbished (Apple or otherwise) board? Look for any markings or small stickers. If this IS a previously-refurbished board from Apple, then you will need to consider damage caused by their terrible rework techs. They overheat things, don't protect critical components, don't properly repair "ALL" liquid-damage, and other things.
      You've got to dig deeper on this one; you need to start with memtest. Then you will need to get your hands dirty and begin 'poking' some of these subcircuits and components. There's a failure here, but it's not an obvious or high-level one.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        It upgraded to Big Sur without issue. It doesn’t hang it just gives errors like the previous posts stated trying to go to Monterey or higher. So ruling it out as nothing crazy yet, it works perfectly fine and 100% without any crashes on Big Sur or below. YouTube, stews testing is good but going to do a memtest Monday. Just repaired a few logic boards on our bench, not to worried on fixing this one just wanted to see if it was something simple before fixing our board.
        sigpic
        • duwane
          A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
          by duwane
          Hi All.
          Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
          The issue:
          Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
          10-26-2022, 07:02 AM
        • japlytic
          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
          by japlytic
          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
          Tried (only with keyboard/mouse connected):
          • BIOS + database update
          • Using latest Windows 11 image built with official image creation tool
          • Previous setup version for Windows 11 installer
          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
          06-19-2025, 04:59 PM
        • 24gsm
          MacBook Pro A1708 install macos fail
          by 24gsm
          hi to all
          i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
          after enter to recovery and format hdd 1to .
          after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
          can help please
          Serial Number: FVFXP0U0HV2J
          Config Code: HV2J
          Find My Mac: OFF
          04-16-2025, 03:57 AM
        • N3Star
          ASRock X99 Extreme4 boots only on cold boot
          by N3Star
          The motherboard in question boots only on cold boot - if I cut power to the PSU it will boot fine, but as soon as I reboot from Windows or even short reset pins it goes into bootloop - 1 second on, a few off and so on.
          Initially the board arrived to me broken - bad PCH, after replacing it it worked for a while. I suspected a bad connection, but pushing the IC down does nothing. I don't really think that the PCH is dead, since it still boots and works fine until I reboot the PC. Obviously I tried looking for something that heats up or bad caps, but nothing so far....
          10-25-2025, 02:53 PM
        • tommy97
          ASUS FA507R - BLOD, cannot install windows
          by tommy97
          I have an ASUS FA507R in for repair where I’m unable to install any operating system. The laptop works fine when booted from an external Windows or Linux drive, but any attempt to install on an NVMe SSD fails.
          I’ve already tested with three different SSDs (Gen 3 and older), and the issue persists. The laptop originally came in with a faulty SSD showing 0% health....
          08-22-2025, 07:55 AM
