Macbook Pro 1398 LCD damage?
  • triplefour
    • May 2014
    • 1747
    any chance this could be caused by anything other than a damaged LCD panel? replacement panels are quite expensive...going for about 200...for a used part no less! in this picture you cant see it but when i first turned it on it was flickering pretty bad as well. the flickering was like between having ok looking color and then totally solarized like in the picture. it eventually stabilized into this.
    Don't fear the repair...
  • myth77
    • Feb 2017
    • 380
    • Croatia
    Re: Macbook Pro 1398 LCD damage?
    did you check on external screen?
    • reformatt
      • Feb 2020
      • 1497
      Screen for mine. Sanity check is to run it to an external monitor via Thunderbolt to HDMI adaptor.
      Great machines this series but a lot are consigned to parts only on eBay due to defective screens.
      • triplefour
        • May 2014
        • 1747
        i have traditionally avoided apple products and been quite successful in doing so...up until now it seems! so of course i dont have this adapter. of course apple couldnt just put a hdmi plug on the laptop like normal people :[
        first thing i wanted to do was check for loose connection and identify which series mainboard it is (since it matters for ordering the correct replacement screen) but i found i dont have the necessary pentalobe screwdriver bit to get into the case!
        ordered some bits. waiting on that. will post progress.
        thanks!!!!
        P.S. is there any way to get and replace just the LCD itself? all i can seem to find is full assembly with bezel and hinges and all that
        • reformatt
          • Feb 2020
          • 1497
          Only if you are masochist. Unlike PC laptops (which are all self contained), Apple screens have the LCD and backlight diffusers/polarizers separate. The screen is also glued in on top of that, so getting it out without contaminating the diffusers etc is tricky. Then you need to source a replacement screen, which will often be a factory reject.
          Screens on the PC space typically use an existing design that is made to a standard spec and made by multiple suppliers. Apple go the other way, and get a factory to make the screen for them only, and change the design every year or so. The factory produces only a limited quantity as a result and you end up with scarce replacements and high prices as a result. It's a built in obsolescence.
          There are aftermarket screens for some of the lesser resolution models like the Air, but for older Retina's there doesn't seem much out there.
          Stick with fixing the Apple devices, as they are the low hanging fruit when it comes to repair. Apple customers are used to getting bent over and still keep buying their stuff. As such, they often will spend far more on repairs than their PC counterparts.
          • piernov
            • Jan 2016
            • 4439
            • France
            A1398 chassis does have an HDMI port. Also without HDMI port you can also use a mini-DisplayPort (which is a standard used by some other laptops as well) to HDMI adapter.
            • triplefour
              • May 2014
              • 1747
              LOL everything you said was what i already suspected. what an evil company! but their followers insist they must have their macbook no matter what the cost. and it has to look perfect too! no way to take this screen apart without someone being able to tell you did it. PC owners wouldnt care as long as it works. mac owners cant handle things like damaged rubber around the screen.
              but hey if they want to pay, who am i to turn their money away?
              plus as an electronics repair guy with the nerve to dream of being an engineer one day, i am on the quest to be able to build or repair any electronic circuit.
              thank you for your comments
              • triplefour
                • May 2014
                • 1747
                youre right. it does have a HDMI port after all. i should have looked before believing that. i was able to use keyboard shortcut cmd + f1 to output to external monitor, where the picture looks fine.
                does this tell us the mainboard is most likely fine? or is there still something that could be damaged on the mainboard that would affect only the built in screen?
                it would be awful to spend 200$ on a used screen only to realize it was the mainboard causing the issue the whole time!
                also if its something on the mainboard, i could do a component level repair, im thinking a lot easier than trying to repair something on the screen itself.
                relating this to my knowledge of tv repair, it looks like the kind of graphic problem you could get from a failed Timing Control board...which i would assume is some small board buried in the panel assembely.
                • dellxps15
                  • Feb 2014
                  • 1598
                  • italy
                  some days ago got one macbook 15 2013 from ebay as non working. after repairing the mainboard that works perfectly on external, i had that on off screen. i replaced the lvds cable but problem is the same.
                  it do as the video i posted here: https://www.youtube.com/watch?v=SPN5CdsExeQ
                  im going to read voltage on the tcon board. it all looks ok under microscope inspection.
                  yes these macbook screens are really bad... when they go ko it's hard to find a valuable replacement. they go from 250 to 500€ for just the screen assembly, while whole notebook wort like 350€.
                  • triplefour
                    • May 2014
                    • 1747
                    my screen is doing a similar thing but not as fast. more random when it snaps back to regular color...and then eventually it doesnt. ill try take video of it and put on youtube soon.
                    • reformatt
                      • Feb 2020
                      • 1497
                      Yep sorry was thinking Air, not Pro, which has the HDMI port.
                      Unfortunately, cost of the screen for A1502/A1398 makes them uneconomical for refurb and resale. Everyone who resells these knows this, so any machine you buy as not working on eBay will very likely also have the display swapped out as well. The only time you come across a steal is from an end user who has no idea what the screens are worth.
                      So the boards/parts etc are reasonably easy to source because most are written off due to bad displays. The boards for the most part are easy to fix, but sometimes ones I buy have a shorted PCH or CPU. I wait for a cheapish board to turn up, but then if the price is cheap, it's usually got a shorted CPU in it.
                      • dellxps15
                        • Feb 2014
                        • 1598
                        • italy
                        inspected lcd t-con. all voltage present , but noticed one big bga getting hot. it was "parade ao dp635".
                        removed and ordered a new one from china. when it will arrive ill post back if monitor come back to a normal working condition.
                        • Matt42386
                          • Mar 2021
                          • 4
                          When you do get it please let me know. the same issue and when taking a thermal cam it was the only chip getting hot at about 50C. I may just order one to check. BUt definitely keep us updated!
                          • Matt42386
                            • Mar 2021
                            • 4
                            I apologize for the double post, I just found that the ipad 4 and possibly the Ipad 3 have the same DP635 in their display. So if you can find an icloud locked or cracked LCD Ipad3 or 4 for cheap you may be able to avoid long shipping times.
                            • triplefour
                              • May 2014
                              • 1747
                              ok i finally got the correct bit to take out the bottom screws and reveal the logic board. i see a sticker saying C024084001EFJTCAF but a google search gets me nothing there.
                              serial on the bottom of the case is C02M924SFD58 and according to this site i found http://www.chipmunk.nl/cgi-fast/applemodel.cgi
                              it says its a late 2013 model.
                              anyone know a good source for a replacement screen?
                              and how to tell for sure what the part number i need is?
                              edit: i found a better site for looking up serial numbers. also cross referenced with what i find in system information on the mac itself. quite sure this is the exact model:
                              Apple MacBook Pro "Core i7" 2.6 15" Late 2013 (IG)
                              https://everymac.com/systems/apple/m...lay-specs.html
                              • Stephen
                                Meow Meow MEOW!
                                • Apr 2020
                                • 674
                                thanks!!!!
                                My best suggestion is buy a broken MacBook Pro 15” A1398 and take the screen off of it then buying one working. Risky but as long as the seller is honest and states the screen is good you save money this way.
                                sigpic
                                MEOWING IN THE IMPOSSIBLE UNIVERSE!
                                • Stephen
                                  Meow Meow MEOW!
                                  • Apr 2020
                                  • 674
                                  I was going to say the same thing. Easy test if external shows the same we have a board issue on hand and his screen is good.
                                  sigpic
                                  • dellxps15
                                    • Feb 2014
                                    • 1598
                                    • italy
                                    update: changed the dp635 with another one i got from aliexpress. new chip get hot too and problem remain the same as in the video i posted erlier. i will inspect this problem more the next days, but seems like another component get hot in the tcon board on the lcd.
                                    • triplefour
                                      • May 2014
                                      • 1747
                                      i like this idea a lot. but what models will have a compatible screen?
                                      i am having trouble finding a conclusive compatibility list.
                                      i read this page and still have no idea as my model doesnt seem to be listed anywhere
                                      https://logi.wiki/index.php/MacBook_..._Compatibility
                                      for clarity i will repost these infos:
                                      serial:C02M924SFD58
                                      MacBookPro11,2 (Late 2013)
                                      the seller of this item assures me it is compatible but i dont know if i want to gamble with a "D" grade screen
                                      https://www.ebay.com/itm/133525802782
                                      in the ad it has a compatibility list:
                                      MacBookPro11,3 (Mid 2014)
                                      ME293LL/A
                                      MGXA2LL/A
                                      ME294LL/A
                                      ME874LL/A
                                      MGXC2LL/A
                                      MGXG2LL/A
                                      but i cant find any model numbers that look like any of these in the mac i am working on.
                                      but is it some kind of clue? does it mean any screen that comes from a mac with these model numbers is compatible with mine?
                                      • reformatt
                                        • Feb 2020
                                        • 1497
                                        The 2015 model is the one that is unique, but 2013/14 are interchangeable. Motherboards for 2013/14 are 820-3787. 2015 are 820-00138, 820-00163, 820-00426. If the board number isn't visible, it's usually hidden under a black sticker somewhere.
                                        I think the difference is LVDS and EDP IIRC.
                                        • rounin
                                          MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
                                          by rounin
                                          Device Information
                                          • Model: MacBook Pro 14” M1 Pro (A2442)
                                          • Logic board number: 820-02443-05
                                          Original Issue
                                          The device suffered liquid damage, causing a short circuit on the logic board.
                                          Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
                                          Work Performed
                                          Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
                                          Current Status
                                          • When powered on, the screen shows support.apple.com/mac/restore....
                                          10-20-2025, 11:15 PM
                                        • Ugur87
                                          MacBook Air M4 A3240 Brand New Water Damage no Image
                                          by Ugur87
                                          I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                                          08-28-2025, 01:09 PM
                                        • mon2
                                          A1466 Macbook Air (Liquid damage repair)
                                          by mon2
                                          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                          Macbook AIR Model A1466 Diagnostic 09-01-2021
                                          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                          Problems & Resolutions
                                          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                          09-01-2021, 09:31 AM
                                        • TimSinger
                                          MacBook Pro M4 16" A3403 on the table with water damage
                                          by TimSinger
                                          Hi guys,
                                          I have a MacBook Pro M4 16" A3403 on the table with water damage. I allready found the problem within a bad cap. As far as my researh went, I couldn't find the schematics and boardview for this MacBook model. They seem not to be released now. So my question is if anybody has a working A3403 on the table and could tell me, which specification this capasator has?
                                          I attached a photo of the missing cap. It's on the bottom side of the logicbard.
                                          I am very thankful for your replys.
                                          Thanks in advanced and best regards from Hamburg Germany...
                                          07-13-2025, 11:12 AM
                                        • dbuergi
                                          Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
                                          by dbuergi
                                          i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
                                          Any ideas where to look?...
                                          11-07-2024, 10:57 AM
