Hp envy - ase30 c482p power on
  • motanya
    • Nov 2021
    • 160
    • Kenya
    I have an hp envy 13 -d023tu, the battery was unfortunately plugged in reverse way +ve to -ve pin and -ve to positive pin, it blew up the chip named NL17SZ74_VSSOP8 in the schematics. All volts are present, charging port lights white when in charger mode and orange when battery and charger are connected but it does not power on. I ordered what i think is the same chip, labelled MHH, after replacing it still doesn't power on. What might be the challenge?
  • mon2
    • Dec 2019
    • 14157
    Re: Hp envy - ase30 c482p power on
    Post or link the schematic.
    • motanya
      • Nov 2021
      • 160
      • Kenya
      Here
      https://www.badcaps.net/forum/showth...809#post835809
      Last edited by Vesko356; 04-19-2023, 08:44 AM. Reason: Attached schematic removed and replaced with the link.
      • mon2
        • Dec 2019
        • 14157
        Review the voltages on the charger IC @ PUB1.
        Interested in the voltage to ground of:
        pin # 1 - ACIN
        pin #30 - ASGATE = used to enable the DCin mosfets
        pin #18 - DCIN
        pin #29 - CMSRC
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Mita99
          Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
          by Mita99
          Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
          Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
          Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
          04-27-2025, 07:20 PM
        • themosttogain
          HP Envy 13-BA1565na with intermittent power button
          by themosttogain
          Hope someone can give me some suggestions on this because i'm at my wits end with it...
          I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
          Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
          07-12-2024, 03:03 AM
