Lenovo G510 Slow Charging Problem
  • mon2
    • Dec 2019
    • 14839
    Re: Lenovo G510 Slow Charging Problem
    Sorry - most of the BQ (TI) charger ICs feature the ACDRV pin. This model of charger IC on your logic board does not. My mistake.
    See attached. The DCin mosfets are P-channel on your logic board (most other laptops are N-channel). With P-channel mosfets, the gate pin #4 voltage must be lower than the voltage being passed between source/drain pins.
    Attach your adapter. Carefully measure the voltage to ground of each of the following mosfet pins:
    source (1-2-3)
    gate (4)
    drain (5-6-7-8)
    Repeat to test the 2nd DCin mosfet.
    Post your measurements.
    Q: Have you replaced only the charger IC at this time or also the 2 x DCin mosfets?
    • mon2
      • Dec 2019
      • 14839
      Adding to your pile...
      (from post #38) - concerned about the ACOK# voltage to ground.
      On the charger IC used in this model, the ACOK# is an ACTIVE LOW signal.
      So if the adapter voltage is OK (based on ACDET), this pin should be a logic LOW = 0 volts. But you are measuring a logic HIGH.
      1) Connect the adapter and carefully measure this ACOK# pin # 5 voltage to ground. Best to measure at the charger IC pin if you can.
      2) Remove the adapter (use the battery) and measure this pin voltage to ground again.
      This is important because this pin is used to drive downstream 2N7002 mosfets which in turn enable / disable the 2 * DCin mosfets.
      Summary: If this signal is logic HIGH, the 2 * DCin mosfets will remain disabled so the power adapter is NOT powering the logic board.
      • ay_erdi
        • Feb 2013
        • 74
        • turkey
        #43
        source (1-2-3)
        gate (4)
        drain (5-6-7-8)
        Attached only adapter with measurements,
        PQ301;
        Pin 1 2 3 =19.98 V
        Pin4=19.98 V
        Pin 5 6 7 8=20.50 V
        PQ302
        Pin 1 2 3 =19.99 V
        Pin 4 =19.99 V
        Pin 5 6 7 8=1.66 V
        After 6 may,coming new charger ic replacement pu301 and pq310.beacuse pq310 source and gate short circuit.
        After this All replacement;motherboard working only adapter or battery and both.but no battery percentage full.
        I has been measuremented to pu301 all pins only battery and adapter attached send to for you failure again.
        At the moment only start battery.no attached adapter to determine.
        • ay_erdi
          • Feb 2013
          • 74
          • turkey
          #44
          Only adapter plugged in pin5=5.88V
          Only battery plugged in ping5=9.75V
          • mon2
            • Dec 2019
            • 14839
            PQ301 was replaced?
            Can you confirm?
            • ay_erdi
              • Feb 2013
              • 74
              • turkey
              #46
              I didn't replace it but if you want I can replace it
              • mon2
                • Dec 2019
                • 14839
                The first mosfet is showing voltage on each side when it should be off but this is likely due to the internal forward biased body diode.
                Remove the battery. Attach the power adapter.
                Grab a piece of wire and connect one side to ground. Other side of the wire to pin #4 of either DCin mosfet (since they share pin #4).
                Do this carefully to not touch pin #3 of the mosfet.
                Does the laptop turn on?
                • ay_erdi
                  • Feb 2013
                  • 74
                  • turkey
                  #48
                  Does not turn on
                  • ay_erdi
                    • Feb 2013
                    • 74
                    • turkey
                    #49
                    Pu301 all voltages down
                    • mon2
                      • Dec 2019
                      • 14839
                      Remove all power and meter in resistance mode.
                      Measure the resistance across the mosfet pins on pq301 and the next DCin mosfet.
                      Source & drain
                      Source & gate
                      Gate & drain
                      Post each measurement.
                      • ay_erdi
                        • Feb 2013
                        • 74
                        • turkey
                        #51
                        S D 113 kohm
                        S G 196 kohm
                        G D 285 kohm
                        • mon2
                          • Dec 2019
                          • 14839
                          Measure also the next DCin mosfet.
                          • ay_erdi
                            • Feb 2013
                            • 74
                            • turkey
                            #53
                            Relevant measurements pq301 with pq302
                            • mon2
                              • Dec 2019
                              • 14839
                              Remove all power. Meter in diode mode.
                              Follow the process shown in step #1 here:
                              https://electronicsbeliever.com/how-...-is-defective/
                              Post your diode mode readings. Do test with probes in each direction.
                              • ay_erdi
                                • Feb 2013
                                • 74
                                • turkey
                                #55
                                a little detail;
                                (ground to,related pin voltages
                                • mon2
                                  • Dec 2019
                                  • 14839
                                  The +3VALW voltage rail will only work once the adapter voltage passes through the 2*DCin mosfets.
                                  The resistance looks a bit low for a good mosfet so best to check in diode mode as per the shared article. No power in diode mode checking.
                                  • ay_erdi
                                    • Feb 2013
                                    • 74
                                    • turkey
                                    #57
                                    I have been performed step 1 for pq301 and 302 for Pmos ;
                                    two mosfets are good.
                                    • mon2
                                      • Dec 2019
                                      • 14839
                                      What are the diode measurements?
                                      Measure the resistance to ground of PQ302; Drain pins (5-6-7-8) = P3 in schematic.
                                      When you connected gate pin # 4 of the PQ301/PQ302 mosfets to ground, what was the voltage on the drain pins (5-6-7-8) PQ302 ?
                                      • ay_erdi
                                        • Feb 2013
                                        • 74
                                        • turkey
                                        #59
                                        pq302 diode measurements; 0,534v DC .
                                        • ay_erdi
                                          • Feb 2013
                                          • 74
                                          • turkey
                                          #60
                                          pq301 and pq302 diode measurements :0,534 V DC.
                                          PQ302 drains to ground pins measurements;290 Kohm.
                                          • coasterghost
                                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                            by coasterghost
                                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                            System Hardware:
                                            Processor: AMD Ryzen 7 PRO 5850U
                                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                            09-08-2025, 10:46 PM
                                          • roman728
                                            Lenovo E15 / NM-C421 Charging Problem
                                            by roman728
                                            Hello guys,
                                            I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop...
                                            02-20-2024, 03:40 AM
                                          • tmks2
                                            Lenovo ThinkPad T14 gen1 charging problem
                                            by tmks2
                                            I have a think pad t14 gen1, mainboardboard NM-C931 REV 1.0, I replaced the damaged USB-C charging socket, I still have a problem with charging only 5V. Where to look for the fault? Which electronic component is responsible for charging negotiation?
                                            here is schematics an boardview
                                            https://www.badcaps.net/forum/troubl...98#post1768898
                                            10-29-2024, 06:41 PM
                                          • Scoff
                                            HP Probook 470 G4 - Power and Charging Problem
                                            by Scoff
                                            Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                            Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                            07-03-2023, 09:28 AM
                                          • ravi_1617
                                            Lenovo B540 ,Starting Problem
                                            by ravi_1617
                                            Hello !
                                            Model Lenovo B540
                                            Board Details 09244-1
                                            LA14 DIS MB
                                            48.4DMO4.01.1
                                            This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
                                            when connected CMOS dont start.
                                            3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
                                            One more thing i want to mention ( by mistake i started at...
                                            10-14-2025, 02:08 AM
