Wson8 spring pin probe WORKS
  • perfm2
    • Nov 2019
    • 29
    • usa
    I couldn't find anywhere on the internet where someone had discussed actually using one of these newer wson8 probes for flashing your Wson8 BIOS chip without removing it from the MB.
    I recently ordered one to give it a shot and it actually worked quite well.
    The tricky part is obviously keeping the probe pins in place on the exposed Wson8 pads of the MB while reading/writing.
    I used a larger binder clip attached to the top of the probe to create a large flat surface, then added about 1lb of weight to it.
    This aided greatly in allowing the probe to stay in place with help of a steady hand.
    Sky is the limit on more elegant solutions to hold the spring probe in place, but I wanted to post that it worked and wasn't really any more difficult finding the correct position than using a Soic8 clip on chips with exposed legs.
  • TrumanHW
    TrumanHW
    • Jun 2021
    • 52
    Re: Wson8 spring pin probe WORKS
    Would love to see pictures if you wouldn't mind.
    I know what "probes" are ... but do you mean a POGO ..? Hence the request for pics.
    • anhbanxoi
      • Sep 2021
      • 178
      • VN
      To use pogo pin with WSON8 you need fast reader/programmer like raspberry pi with flashrom. Just need to keep it in position for 30s to read 32MB file.
      • Barboska
        • Sep 2021
        • 20
        • Ukraine
        Hmm, I have an idea..
        this is an old film developing device, I use it as a tripod for a camera or lighting
        https://upload.wikimedia.org/wikiped...and_Yunost.jpg
        • perfm2
          • Nov 2019
          • 29
          • usa
          That's a sweet rig. I was just using a CH341 on a Windows 10 laptop, read was about 2 min, 3 for write.
          • perfm2
            • Nov 2019
            • 29
            • usa
            Brilliant!
            • CapLeaker
              Dell ATX PSU won’t start, but forcing it works fine?
              by CapLeaker
              Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
              Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
              10-28-2024, 06:59 PM
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              🛠 Original Issue
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • ex250
              Kenwood SW-505D no sound issue and pops from time to time when it works
              by ex250
              Hello mates,
              I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
              It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
              12-29-2024, 03:27 PM
            • eurowill
              a2141 820-01700 internal display not working / external works
              by eurowill
              Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
              Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
              07-23-2024, 10:06 AM
            • vf fa
              EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
              by vf fa
              Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
              I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
              So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
              01-31-2024, 01:40 PM
