Almost dead Lenovo V15-ADA 82C7
  • vpower
    • Sep 2022
    • 111
    • italy
    Hi, I have this laptop that acts strange. If I try powering on, the power led, the numeric keypad light and the fans will turn on but the screen has no image. The fuse F2 near the lcd connector is blown, I tried to replace it with some similar fuses (1A) but it keeps blowing. I tested these mosfets with multimeter:
    PQ201 drain 20v source 20v, gate 26v
    PQ202 drain 20v source 20v, gate 26v
    PQ5907 drain 20v, source and gate 0v (both shorted to ground too)
    PQ5908 drain 0v shorted, source 0v shorted and gate 0v (connected to pin 33 of PU5901)
    a lot of capacitors behind the cpu are shorted. thermal cam shows heat on the cpu shield
    maybe the problem is in the backlight circuit? too bad I cannot find schemathics for this laptop.
    any hint?
    Boardview: https://www.badcaps.net/forum/showth...57#post1211357
    Schematic: https://www.badcaps.net/forum/showth...08#post1242808
    Last edited by Vesko356; 06-19-2023, 02:20 PM. Reason: Attached BV removed and replaced with link + schematic link added.
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Almost dead Lenovo V15-ADA 82C7
    First i would give resistance to ground on all coils put it and the current sensor on the picture. So that somebody can look at it and help you how to further investigate. My gues it will be 3,3 v is shorted or and mosfet on vcore maybe.
    • vpower
      • Sep 2022
      • 111
      • italy
      sorry I'm trying to learn. with coil you mean, for example, PL401 and PL402?if yes, with multimeter in resistance mode:
      PL401 open circuit on both sides
      PL402 open circuit on both sides
      PL5903 8,4 ohm on both sides
      PR201 open circuit on both sides
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        So no short on the currentsensor to ground . Did you check the first second mosfet for internal short. If the are good i would look into the charger circuit the acdrive pin is the one that controls the mosfets.
        • vpower
          • Sep 2022
          • 111
          • italy
          multimeter in diode mode
          no short on PQ202 (I only find short for a few seconds between source and drain after I check between gate and drain..is it normal behaviour?)
          no short on PQ201
          source (1 2 3) is shorted to ground in PQ5907..is this mosfet is connected to F2 fuse that keeps blowing?
          I found other coils and mosfets under the cpu shield:
          resistance mode
          PL5901 and PL5902 around 80 ohm to gnd both sides
          PQ5901 to PQ5906 I can check if it's needed.
          acdrive pin... where can I find it?
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            I can not open boardview . Fuse blows so you must have a short can you give close up picture from the area. Fuse can only blow if you have a short.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              No point probing the charging circuit here. Measure resistance on both pads of blown fuse after removing the fuse. One side is definitely shorted. Then you need to inject voltage on the shorted side of fuse. Voltage should'nt be more then 1V.
              Resistance measurements should be done twice
              01.With edp cable inserted
              02.Without edp cable.
              No power should be attached to the board while checking resistance.
              • onepic
                • May 2019
                • 20
                • RO
                Hi vpower
                did you manage to fix it? I run into same problem. V15-ADA 82C7 laptop power on (but no numeric keyboard light into my case) and no picture on screen or HDMI out. My one do not have soldered memory so i cand remove the 8GB DIMM from slot. If i power it without DIMM inserted there ar no beep error sound.
                • luckyleo
                  • Mar 2021
                  • 3
                  • Italy
                  Originally posted by onepic
                  Hi vpower
                  Did you try change ram?
                  • onepic
                    • May 2019
                    • 20
                    • RO
                    Yes, but te same.
                    • Sephir0th
                      • Oct 2020
                      • 1282
                      If you assume, your board is "full on" then grab a external USB-Keyboard and look whether the CapsLock key is responding when pressing the related key. But if it is "stuck" somewhere and not all necessary voltages are present, then: Without measurements no clue.
                      FairRepair on YouTube
                      • double_DD
                        How can I be sure that my EC chip is dead?
                        by double_DD
                        As the title suggests, how can I be sure that my EC chip is really dead?
                        I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                        Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                        03-12-2025, 07:47 AM
                      • disorder
                        ps5 edm-033 dead after hdmi/usb ports destroyed
                        by disorder
                        hello guys,
                        i need help to repair a edm-033 ps2
                        history : as always hdmi port and usb ports destroyed after unplugged
                        after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                        so i changed it
                        now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                        but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                        i don't see any projection of liquid metal on pcb.
                        01-14-2025, 12:48 PM
                      • Beton
                        Finding a dead short component
                        by Beton
                        Hi guys!
                        I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                        So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                        I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                        I have a bench PSU and if I try to inject voltage the voltage...
                        12-10-2021, 01:05 PM
                      • zunasthegreat
                        Chieftec GPS-450-AA with dead 20N60C3
                        by zunasthegreat
                        Hello everyone hope all doing well!
                        I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                        09-01-2024, 07:12 PM
                      • FiguringITout
                        MSI Raider GE75 - Not posting, probable dead CPU
                        by FiguringITout
                        Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                        Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                        07-25-2024, 07:27 AM
