Missing ACDRV in Quanta 0P5D
  • orientalsniper
    • Apr 2013
    • 459
    Hello all, been trying to diagnose this board all night and haven't been successful, so once again I come here for help.
    Board has a history of being liquid spilled, but I see no corrosion since they brought it to me the day after.
    The DC-IN mosfets don't seem to be shorted (PQ1001 & PQ1002).
    I've replaced the PU1001 (BQ24728) with a BQ24725 with no changes.
    I've also removed PR1020 the 4K resistor connecting the charging IC with the two dc-in mosfets to see if 25V would be present for ACDRV, but I still get 0V.
    Voltages for PU1001 are:
    REGN: 6V
    VCC: 19V
    ACDET: was 2.0V, but I changed PR1024 for a 330K resistor to get 2.6V
    ACIN/ACPRES: was 0V but after getting 2.6V in ACDET, it's now 3V
    ACDRV: 0V <------ this is I what I need
  • Bonzas
    • 472
    • Indonesia
    Re: Missing ACDRV in Quanta 0P5D
    REGN: 6V
    VCC: 19V
    Remove PQ1002 and check if you get acdrv on pq1001
    • reformatt
      • Feb 2020
      • 1416
      Make sure you don't have your main power rail shorted, that's the usual thing I see when ACFET/RBFET aren't opened as the BQ IC has S/C protection. Check it at PR1001.
      • reformatt
        • Feb 2020
        • 1416
        Also noted that the values for PR1023/PR1024 don't seem correct on the schematic. Other Quanta boards have this as 430k/70k for the same BQ IC (which should give you roughly 2.6V for a 19V supply). But this is 430k/51k which gives you 2V. Other components in this area (PQ9/PQ11) seem to be nostuff so can be ignored. BQ24725 IC needs between 2.4V and 3.15V for ACDET, no datasheet available for BQ23728 but you'd assume it's the same. Odd!
        • orientalsniper
          • Apr 2013
          • 459
          I forgot to say I've removed the 2nd dc-in mosfet PQ1002 and I still didn't have ACDRV, but I don't know if this is relevant, I measured 0.8V on the drain (pin 5) of PQ1002 without the mosfet soldered on.
          I don't think there's a short, I'm getting a 0.450V in diode and 2 mohms resistance (steadily going down) on PR1001.
          I can confirm the resistors are 430K and 51K on the board, the components in ACDET3 are not present like you said.
          I did mention I had to replace the 430K resistor with a 330K resistor to get 2.6V, but I don't think it helped me get ACDRV.
          • orientalsniper
            • Apr 2013
            • 459
            Also, what's the difference between ACOK and ACIN/ACPRES, the BQ24725 datasheet has pin 5 as ACOK, but this board schematic uses the terms ACIN/ACPRES.
            • reformatt
              • Feb 2020
              • 1416
              Just a naming convention from whoever drew the schematic I think. It's function is the same.
              BQ24728 is a custom IC for the OEM's I believe, hence the datasheet hasn't been made publicly available as a result. But I think the general parameters are the same, as all BQ IC's tend to use the same general logic. I still cannot explain the values for ACDET on this board. Every other design I've seen using this IC results in 2.6V for a 19V adaptor so this makes no sense to me.
              There are a few conditions that will result in ACFET/RBFET being switched off and are usually as a result of overcurrent either to the main supply rail or in the battery charger MOSFET's. I'm thinking you may have an active short somewhere so a thermal camera might be the way to go here.
              • orientalsniper
                • Apr 2013
                • 459
                Solved
                SOLVED
                I was able to fix it, but it was by pure luck and 0% skill, so I went back to the area that had sign of liquid and noticed a solder jumper with a brownish color, when I took off the solder, I could see the trace was broken, I soldered it with a wire and it worked, I got ACDRV and laptop also turns on with no problem.
                I checked the boardview and that trace was not in there, I was able to trace it back to +VAD, I'm glad I was able to repair this, but I would be more happy if I was able to diagnose that +VAD was the cause.
                Can someone explain to me how +VAD is necessary for ACDRV generation? I don't think it even feeds the charger IC, I'd be glad to be educated about it.
                I also undid everything (put back charger IC, ACDET resistor), all it needed was the trace to be repaired.
                What I learned:
                ACDET can be okay with 1.9V
                ACOK/ACIN/ACPRES (however you're gonna call it) is okay with 3V
                BQ24728 is compatible with BQ24725 and BQ24738
                • reformatt
                  • Feb 2020
                  • 1416
                  So you are saying you had no continuity between the source of PQ1001 and the source of PQ1002? Usually ACDRV will appear momentarily and the IC will give up after 7 tries if an abnormality is detected. You may have seen a pulsing when the board first has power applied to it. Since no voltage appeared at the drain of PQ1002, this is probably considered a short by the IC so it removes ACDRV.
                  PQ1006 is there for reverse polarity protection, and normally it's biased off. So I don't think it played a part.
                  • orientalsniper
                    • Apr 2013
                    • 459
                    I never checked for continuity between the source of PQ1001 and PQ1002, I've already put that laptop back.
                    Can you tell me the difference between +VA_AC, +VA and +VAD? Is the power adapter the source for all three? Thanks again.
                    • reformatt
                      • Feb 2020
                      • 1416
                      Just different test points on the board really and a hangover from when the board was being developed. PL1001/1002 may have been fitted with RF chokes to pass some the RFI requirements in some countries, but in production were removed with shorts. From a troubleshooting perspective, +VA and +VAD are test points before and after the first FET.
                      • orientalsniper
                        • Apr 2013
                        • 459
                        I see.
                        Thank you for your assistance, I would had been stuck on this repair without your help.
                        • piernov
                          • Jan 2016
                          • 4437
                          • France
                          Re: Solved
                          Goes to charger IC CMSRC pin through PR1021.
                          • ResoluteHawk
                            Quanta 0P5 (DA0P5HMB8E0-Rev E) Missing ACDRV
                            by ResoluteHawk
                            I have an HP 15-DY laptop in because the battery is not charging.
                            If I use a charged battery, the laptop powers on but the battery will not charge, however the orange charge light does turn on. The laptop loses power as soon as I disconnect the battery.
                            I've replaced the BQ247 chip with a known working one and I get the same issue and the same measurements.
                            Measurements are as follows:
                            BQ728 IC
                            VCC (Pin 20) => 19V
                            CMSRC (Pin 3) => 0.8V (This is a problem but I can't figure out what's causing the low voltage)
                            ACDRV (Pin...
                            04-10-2025, 11:36 AM
                          • ugamazing
                            820-02020 PPBUS_AON missing
                            by ugamazing
                            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                            02-05-2025, 04:21 PM
                          • bushmann
                            HP omen 15 - DAG3DBMB8D0 - Quanta G3DB missing components
                            by bushmann
                            Hi all.
                            Please can you help me identification missing components on this board.
                            Power IC is MP2949A.
                            May be AOE6932
                            Thank you so muche....
                            06-07-2022, 05:02 PM
                          • lpraderi
                            Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
                            by lpraderi
                            Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
                            In some cases to use LVDS screen PCB use converter IC RTD2132/6
                            Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
                            at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
                            Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
                            11-25-2023, 09:31 AM
                          • jpreza
                            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                            by jpreza
                            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                            Looking at the card, it appears to be missing the following:
                            1x 1.0uH inductor - orange square
                            2x...
                            11-01-2024, 10:54 PM
