Macbook A1286 no boot, voltages seem ok
  • retrorepair2
    • Feb 2023
    • 92
    • United Kingdom
    This board is a head scratcher.
    I've checked all voltages against the schematic and all are present on powerup, but get no chime, taking ram out doesn't give me beeps, sleep light and fans come on for about 5 seconds then shuts down.
    What I'm reading is pointing to the gpu but this is a 820-2850 and I didn't think this revision suffered this badly from this issue? I've already replaced C9560 but same issue.
    Not really keen to run loads of wires just yet to disable the gpu, is there anything I can do to rule the gpu out?
  • mon2
    • Dec 2019
    • 14662
    Re: Macbook A1286 no boot, voltages seem ok
    What is the voltage to ground of ppbus_g3h?
    • retrorepair2
      • Feb 2023
      • 92
      • United Kingdom
      It's on battery as I don't have a charger at the moment, but it's 11.28v when power is off, 10.8v when it's on.
      Also checked ALL_SYD_PWRGD and it's 3.3v when powered on so sounds like it's happy enough with power.
      • retrorepair2
        • Feb 2023
        • 92
        • United Kingdom
        I've noticed PPVCORE_GPU is about 3ohm to GND, surely can't be right??
        It does read .9v which is in spec according to the schematic..
        • retrorepair2
          • Feb 2023
          • 92
          • United Kingdom
          Further testing: There is no USB activity on my thumb drive and LCD_PWR_EN does go low. I'm starting to wonder if the GPU is the only factor left
          • No Lan
            [Macbook pro A1708] [Boot loop] [Trackpad ?]
            by No Lan
            Hey everyone,
            Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
            Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
            Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
            05-24-2025, 03:09 PM
          • resistor83
            Macbook pro 15" 820-2915-B 2011 A1286 boot on but black screen
            by resistor83
            Hi everyone, I have this 2011 MacBook Pro 15" model 820-2915-B which has a problem.
            I turn it on, the startup sound is heard but the screen doesn't turn on, not even the backlight. The keyboard lights up after a while and the capslock works. If I press any key I can hear sounds as if the system is booting.
            I thought it was a screen problem but after changing it the problem remains.
            What could I do?
            09-14-2023, 12:38 PM
          • twonk9098
            Macbook Pro mid 2015 battery required to boot?
            by twonk9098
            I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
            The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
            This model has the newer trackpad which is not clickable when turned off.
            At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
            If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
            12-10-2024, 06:51 PM
          • veedo
            Macbook A2442 820-02098 boot and display issue
            by veedo
            Hi All
            I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
            Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
            I found component UD290 ( SF0101-I2C) little...
            04-01-2024, 06:06 AM
          • PITERPENY
            Macbook A2251 no boot
            by PITERPENY
            The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
            01-05-2025, 03:11 PM
