Macbook pro 15" 820-2915-B 2011 A1286 boot on but black screen
  • resistor83
    • Oct 2018
    • 131
    • Italy
    Hi everyone, I have this 2011 MacBook Pro 15" model 820-2915-B which has a problem.
    I turn it on, the startup sound is heard but the screen doesn't turn on, not even the backlight. The keyboard lights up after a while and the capslock works. If I press any key I can hear sounds as if the system is booting.
    I thought it was a screen problem but after changing it the problem remains.
    What could I do?
  • dellxps15
    • Feb 2014
    • 1600
    • italy
    Re: Macbook pro 15" 820-2915-B 2011 A1286 boot on but black screen
    hi do a pram reset. if the screen become wait then most likely it's gpu is gone and u need a gmux to disable it.
    • resistor83
      • Oct 2018
      • 131
      • Italy
      I have already tried to reset the pram and also the SMC but the screen is still off
      here video: https://streamable.com/1761vz?src=player-page-share
      • dellxps15
        • Feb 2014
        • 1600
        • italy
        do u have image on external monitor ? connected with display port to hdmi-vga adapter?
        if u have screen on external, then amd gpu is fine.
        • resistor83
          • Oct 2018
          • 131
          • Italy
          no video signal even with the display port adapter
          • resistor83
            • Oct 2018
            • 131
            • Italy
            some measurement:
            PP3V3_S0 3,34V
            PP3V3_SW_LCD 0V
            U9000: pin 2 and 3 3,34V pin 4 and 5 0V
            • mon2
              • 16210
              As noted, likely a GPU fault.
              https://www.badcaps.net/forum/showthread.php?t=74024
              • dellxps15
                • Feb 2014
                • 1600
                • italy
                he just need to be sure that it's not a lvds connector, lcd cable or lcd itself before doing a gmux .
                once a customer told me to disable gpu, and problem was a bad lcds connector with some burned pins.
                • resistor83
                  • Oct 2018
                  • 131
                  • Italy
                  I have a working screen that I tried but it won't turn on so it can't be the display/cable
                  However, in the MacBooks that I have repaired over the years, when the video card was broken, either the operating system started with various lines on the screen or the screen was black/white but the system did not start in the worst cases. It has never happened to me that the operating system started up and the screen was completely turned off due to the video card
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • Rav_tangle
                    MacBook Pro 2011 turns on with keyboard light , screen dead
                    by Rav_tangle
                    Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                    I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                    Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                    is this...
                    05-31-2024, 04:09 PM
                  • marcelofct
                    Help Macbook Pro A1286 820-2915 blank screen
                    by marcelofct
                    Hello friends, I need someone to help me clean ME the bios that I leave attached since the macbook pro a1286 SN: C02FDHXPDFF8V 820-2915 loads the logo and then the screen is left blank, I think it could be bios
                    Greetings and thank you very much in advance...
                    01-30-2025, 08:35 AM
                  • roxboy1984
                    MacBook Pro 2020 (Intel version) screen ghosting issue
                    by roxboy1984
                    Please could someone advise me on what may be causing this. When I open my MacBook lid the screen seems to malfunction and gets lines on it and the picture tends to ghost whatever is on the screen. If I start closing the lid it gets to a point where the screen displays normally. The display is fine on a second monitor. I can’t see any issue with the ribbon cables. Is there anything else that may be causing this issue that I can check?...
                    06-12-2026, 07:52 AM
