A1708 820-00840 no power
  • mon2
    • Dec 2019
    • 14209
    Re: A1708 820-00840 no power
    My bad...thank you for the correction. Too many netnames in my fading head.
    Remove all power. Measure the resistance to ground @ F7000 (pad # 1).
    This should be with F7000 fuse removed.
    Next, measure the VOLTAGE to ground for:
    SMB_SMC_CHGR_SDA
    SMB_SMC_CHGR_SCL
    the above SMBUS (I2C) lines are used to communicate with the ISL9239 @ U7000 to allow for this IC to become either a BOOST or BUCK regulator.
    Since you have 20V as input, this regulator should enter BUCK mode (high input voltage; low output voltage).
    • nassih
      • Oct 2015
      • 276
      • morocco
      what's creating PPBUS_G3H in this model?
      • mon2
        • Dec 2019
        • 14209
        U7000 is the switching regulator.
        It must be working but so should the external mosfets @ Q7030 & Q7040.
        The SMB_SMC communication lines must be working to allow for the configuration of U7000 to act like a BOOST or BUCK regulator.
        Do you see any damage to U7000 ? Inspect with your microscope to see if it looks ok.
        • nassih
          • Oct 2015
          • 276
          • morocco
          no damage on U7000,i have replaced U7000,Q7030,Q7040,U6990,D6905 no issue
          • mon2
            • Dec 2019
            • 14209
            With power adapter connected, measure the voltage to ground of:
            SMB_SMC_CHGR_SDA
            SMB_SMC_CHGR_SCL
            Meter in DC volts (20v or higher is ok) mode.
            Red meter probe to one of the above points. Black meter probe to ground (shield is ok).
            Post each measurement.
            U7000 (ISL) controller is configured over the SMBUS. Checking if they are stuck.
            • nassih
              • Oct 2015
              • 276
              • morocco
              #26
              SMB_PMIC_SDA : 3.2 v
              SMB_PMIC_SCL : 3.2v
              but the two voltages are not stable,fluctuation between 2.2v and 3.2v
              • mon2
                • Dec 2019
                • 14209
                The fluctuations are ok. This confirms that the measure line is switching between high / low logic levels. The switching is not being properly measured by the meter since it is not fast enough. This is common to most meters.
                To properly view the toggling of the SMBUS signals, you will need an oscilloscope or logic analyzer (some cheap ones are available on Aliexpress).
                With a logic analyzer and SMBUS plug-in, you can decipher what the SMBUS master is communicating with the SMBUS slaves (ISL, etc.).
                For the missing PPBUS_G3H voltage,
                1) is F7000 in or out of the PCB ?
                2) remove all power -> meter in resistance mode -> measure the resistance to ground of F7000, pin # 1 (aka ISL - U7000 side).
                What is the resistance reading ?
                3) What is the resistance between the F7000 fuse PCB pads (if the fuse is installed) ? It should be ~0 ohms if the fuse is NOT blown.
                • nassih
                  • Oct 2015
                  • 276
                  • morocco
                  #28
                  thank you mon2 for your support and effort to help people here it's interesting and useful, ok I'm going to take these tests and measurements tonight, thanks again
                  • nassih
                    • Oct 2015
                    • 276
                    • morocco
                    #29
                    i have measured with the oscilloscope SMB_PMIC_SDA and SMB_PMIC_SCL , I can see signals but I don't know the normal state (I'm not familiar with the oscilloscope),
                    F7000 have 560k resistance to ground and 0.1ohm (F7000 in)
                    • mon2
                      • Dec 2019
                      • 14209
                      Can you clarify the 0.1ohms? How was this measured?
                      Meter probes across the fuse?
                      • nassih
                        • Oct 2015
                        • 276
                        • morocco
                        #31
                        yes sir
                        i think i have a bad Q7040,Q7030 they are recovered from an donor board, I'm going to order them right away, maybe that's the origin of this problem.
                        • nassih
                          • Oct 2015
                          • 276
                          • morocco
                          #32
                          yes indeed I removed q7030 there is a short between pin1,2,3,13 and pin5,6,7,8,9,10,11,14
                          • nassih
                            • Oct 2015
                            • 276
                            • morocco
                            #33
                            sorry it was a bad measurement, the mosfet was closed,
                            • chth96
                              Is it possible to test small ceramic disc capacitor with analogue meter?
                              by chth96
                              I read EBOOK of Testing Electronic Component and found that
                              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                              Is it really possible to test small ceramic disc capacitor with analogue...
                              03-09-2024, 10:03 PM
                              Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                              by sam_sam_sam
                              I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                              I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                              12-31-2023, 06:04 AM
                            • thecookie17
                              Macbook Pro A1708 20V 0A, PPBUS_G3H 13v
                              by thecookie17
                              I'm a newbie regarding all this board repair stuff, and have never done it before, but I thought I might give it a try before throwing my logic board out or selling it. Thus I'm apologizing in advance for any stupid questions.
                              When I first plugged in the meter it showed 20V and 0.01A current draw, however now I have no current draw whatsoever.
                              I measured PPBUS_G3H with 13V, so that seems to be present.
                              https://repair.wiki/w/MacBook_Pro_A1..._shorts_repair
                              I tried everything listed on that page, but everything...
                              02-10-2025, 07:41 AM
                            • jorpec
                              Changing the scale of an analog meter
                              by jorpec
                              Hi
                              I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                              I wonder how i can accomplish this so the meter would be precise at any temperature ?
                              Thnaks
                              01-23-2023, 10:37 AM
                              How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                              by sam_sam_sam
                              About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                              Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                              Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                              12-14-2023, 07:45 PM
