A1708 820-00840 no power
  • nassih
    • Oct 2015
    • 280
    • morocco
    hello everybody my macbook a1708 is giving me some issues:
    no power and no amp consumption i have replaced c7078 was shorted to ground. voltage checked :
    ppbus_g3h=0.3
    ppdcin_g3h_chr_r=5.1v
    ppvin_g3h_p3v3 g3h=3.8v
    pm_en_p3v3_g3h_r=4.6v
    pp3v3_g3h_vr=2.2v (required 3.3v)
    pp3v3_g3h=2.2v (required 3.3v)
    no short to ground
    tanks
  • mon2
    • 14672
    Re: A1708 820-00840 no power
    ppbus_g3h=0.3
    STOP.
    Remove the fuse @ F7000. Then, meter in DC volts mode (30V or higher is ok).
    Red meter probe to F7000, pin # 1 (ISL side) PCB pad.
    Black meter probe to ground (shield is ok).
    What is the voltage to ground ?
    Next, meter in RESISTANCE mode. Remove all power.
    Check the resistance to ground of F7000, pin # 2 (downstream / consumer side) PCB pad.
    One meter probe on F7000, pin # 2 PCB pad.
    Other meter probe to ground.
    What is the resistance to ground ? Make a note of the meter scale if it is not automatic scaling.
    Post your readings. From the very low voltage, sounds like you have a shorted capacitor on the downstream / consumer side of the logic board.
    • nassih
      • Oct 2015
      • 280
      • morocco
      tanks sir for reply.ok I will do all that tonight, I also want to inform you that after replancement of diode D6905 the voltages have changed:
      ppdcin_g3h_chr_r= 20v
      pp3v3_g3h_vr= 3.4v
      pp3v3_g3h= 3.4v
      ppbus_g3h=0.3
      • nassih
        • Oct 2015
        • 280
        • morocco
        voltage on F7000 pin 1 = 0.123v
        when I was measuring the voltage across f 7000, I noticed that f 7000 has a high resistance about 470k,replaced from donor board same issue
        • mon2
          • 14672
          Do you have F7000 removed or on the board ?
          The fuse must be removed to check if the PPBUS_G3H voltage rail is being generated.
          • nassih
            • Oct 2015
            • 280
            • morocco
            yes i have removed f7000 but still no generate voltage
            how much voltage should be on f7000 when removed?
            • piernov
              • Jan 2016
              • 4439
              • France
              Bad dual diode and possibly resistor feeding PP3V3_G3H input as always.
              • nassih
                • Oct 2015
                • 280
                • morocco
                I believe that the diode seems good, I have checked with meter, the last one was open on point 1 and 3
                ppbus_g3h can generate the voltage without battery in?
                • mon2
                  • 14672
                  Yes. One leg of the dual diode is a feed from the battery.
                  Other leg of the dual diode is a feed from the external power adapter.
                  The diode will select the higher of the 2 sources to create the PPVIN_G3H_P3V3G3H.
                  This input feeds the regulator @ U6990.
                  Review the voltage to ground on each leg of D6905 (dual ANODE diode).
                  Next, check the voltage to ground of PP3V3_G3H @ L6995, pin # 2.
                  Post each measurement.
                  • nassih
                    • Oct 2015
                    • 280
                    • morocco
                    the voltage on D6990:
                    pin1: 0,3V
                    pin2: 20V
                    pin3: 19
                    PP3V3_G3H on L6995: 0,23v
                    • nassih
                      • Oct 2015
                      • 280
                      • morocco
                      sorry its D6905 not D6990
                      • mon2
                        • 14672
                        So this rail is missing. This rail may have a shorted part on this leg.
                        Remove all power. Meter in resistance mode.
                        Measure the resistance to ground of L6995.
                        Post the resistance reading.
                        • nassih
                          • Oct 2015
                          • 280
                          • morocco
                          black probe to ground red probe to L6995 :130k
                          red probe to ground black probe to L6995 :2.8k
                          • nassih
                            • Oct 2015
                            • 280
                            • morocco
                            voltage on L9695 : 3.4v
                            • mon2
                              • 14672
                              From post # 10
                              Which is correct ?
                              • nassih
                                • Oct 2015
                                • 280
                                • morocco
                                sorry PP3V3_G3H is 3.4v
                                • mon2
                                  • 14672
                                  pin1: 0,3V
                                  pin2: 20V
                                  So PPBUS_G3H is now @ 20V ?
                                  Can you confirm this? What changed ?
                                  • nassih
                                    • Oct 2015
                                    • 280
                                    • morocco
                                    checking resistance between PPBUS_G3H and the output of buck converters:
                                    L8030: 1m
                                    L8060: 0.8m
                                    L7960:
                                    L7900:
                                    L7730: 1.5m
                                    L7690: 15m
                                    L7670: 12m
                                    L7430: 8m
                                    L7370: 7m
                                    L7220: 6m
                                    • nassih
                                      • Oct 2015
                                      • 280
                                      • morocco
                                      no sir PPBUS_G3H is 0.037v
                                      • nassih
                                        • Oct 2015
                                        • 280
                                        • morocco
                                        to confirm:
                                        PPDCIN_G3H_CHGR_R : 20v(pin2 D6905)
                                        PPBUS_G3H_R : 0.037v (pin1 D6905)
                                        PPVIN_G3H_P3V3G3H :19.76v (pin3 D6905)
                                        • chth96
                                          by chth96
                                          03-09-2024, 10:03 PM
                                          12-31-2023, 06:04 AM
                                        • thecookie17
                                          Macbook Pro A1708 20V 0A, PPBUS_G3H 13v
                                          by thecookie17
                                          I'm a newbie regarding all this board repair stuff, and have never done it before, but I thought I might give it a try before throwing my logic board out or selling it. Thus I'm apologizing in advance for any stupid questions.
                                          When I first plugged in the meter it showed 20V and 0.01A current draw, however now I have no current draw whatsoever.
                                          I measured PPBUS_G3H with 13V, so that seems to be present.
                                          https://repair.wiki/w/MacBook_Pro_A1..._shorts_repair
                                          I tried everything listed on that page, but everything...
                                          02-10-2025, 07:41 AM
                                        • jorpec
                                          by jorpec
                                          Hi
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
