dell 3567 / AC fine, but Battery not charging and CPU @ 0.4ghz if battery not removed
  • WhatsTheDellio
    • Jan 2023
    • 16
    thanks in advance for any help you can give.
    i have a vegus/turis skl/kbl
    15341-1
    91N85
    this came to me with broken hinges so I lovingly acquired the parts I needed and reassembled it all to find everything working except for the battery. It was @ 30% and drained to zero while installing the OS. When plugged in the laptop works. CPU at 100% when no battery installed and only 0.4ghz if battery and AC are both plugged in.
    i tried 3 different batteries and 2 different chargers so it's down to motherboard.
    IR camera doesn't show any obvious over heated components. I thought I saw damage to the ncp81208 but new one looks the same so maybe not.
    Now I'd like to understand the circuits and repair. Would someone be willing to walk me through it? I gather the mosfet may need replacing from the sticky but not sure how to find it.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: dell 3567 / AC fine, but Battery not charging and CPU @ 0.4ghz if battery not rem
    Does it shows the correct wattage of adapter in bios setup screen?? If no,then your problem is PS_ID circuit.
    Next measure voltage on PU4301/PQ4410 for Pin 1/4/8.
    All the measurements should be without battery,only adapter connected.
    Voltage on PL4401 also.
    Report back and then we decide and may opt for resistance check and some voltage measurements on charging ic PU4401.
    • WhatsTheDellio
      • Jan 2023
      • 16
      Bios shows the correct wattage.
      Bios also reports status of battery as charging, but reports current as 0 mA. (the battery said charging before, I think it shows idle in the screenshot below because it was nearly full and wasn't calling for a charge)
      • WhatsTheDellio
        • Jan 2023
        • 16
        Image from bios
        • WhatsTheDellio
          • Jan 2023
          • 16
          PIN1 = 42.1v
          PIN4 = 6.1v
          PIN8 = 42.1V (PINS 7&8 are joint in same solder, as is 5&6)
          PIN1=42.1V
          PIN4=3.2V
          PIN8=42.1V (PINS 7&8 are joint in same solder, as is 5&6)
          PL4401 I'm not sure how to test... looking that up now. It is labelled 4R7 734 VCM and seems to have only 2 pins?
          • mon2
            • Dec 2019
            • 14240
            PIN1 = 42.1v
            Say what ????
            • WhatsTheDellio
              • Jan 2023
              • 16
              Originally posted by mon2
              Say what ????
              hmmm.... I should have measured in DC, not AC, right?
              PIN1 = 19.4v
              PIN4 = 3.13v
              PIN8 = 19.44V (PINS 7&8 are joint in same solder, as is 5&6)
              PIN1=19.4V
              PIN4=1.77V
              PIN8=19.44V (PINS 7&8 are joint in same solder, as is 5&6)
              • mon2
                • Dec 2019
                • 14240
                Yes
                • WhatsTheDellio
                  • Jan 2023
                  • 16
                  Yes
                  I'm fully capable of doing this, just not on the first try... or the second... I tried like 5 different tools to view the .CAD file in the schematics thread for this board but it wouldn't load any of them... While you're here, can you throw me a bone and tell me which software I can easily acquire that will open the .cad file?
                  • WhatsTheDellio
                    • Jan 2023
                    • 16
                    Not sure if I tested it correctly, but PL4401 measure 0V on both sides when I press my black probe to ground and red probe to each terminal... is this the wrong method to test voltage? Or is the component faulty?
                    • mon2
                      • Dec 2019
                      • 14240
                      For checking the voltage, you will measure to ground.
                      Meter in DC volts mode (30v or higher is recommended since the adapter is ~19v).
                      Black meter probe to ground on the logic board (shield is ok).
                      Red meter probe to the point to measure.
                      For N-channel mosfets, the GATE pin # 4 is expected to be ~25 volts to ENABLE.
                      gate pin # 4 = adapter voltage + REGN voltage (~6 v) = ~25v.
                      For P-channel mosfets, the GATE pin # 4 should be LOWER than the voltage passing between SOURCE & DRAIN pins to ENABLE.
                      Continue to review & post the list of voltage checks requested by @mcplslg123.
                      Which file are you trying to open? Can you post or link it ?
                      • WhatsTheDellio
                        • Jan 2023
                        • 16
                        https://www.badcaps.net/forum/attach...2&d=1642585030
                        on PL4401 is 0V because it only has two pins (contacts really) and they both read 0V on a mtimeter range setting of 20V.
                        • WhatsTheDellio
                          • Jan 2023
                          • 16
                          I guess I found the schematic here in pdf. I don't know what I was trying to open before. How do I interpret this thing to follow the flow of power?
                          https://www.badcaps.net/forum/attach...1&d=1594378972
                          • mon2
                            • Dec 2019
                            • 14240
                            Review the suggestions above. Post your measurements.
                            A cpu is often throttled if the power adapter is under rated. Do you have a beefier power adapter from Dell?
                            If yes, does the bios agree that is with more power?
                            • WhatsTheDellio
                              • Jan 2023
                              • 16
                              this is the AC adapter that comes with this model laptop. I tried two of them. not faulty. swapped internal ac wire on the board too. all parts have been swapped out except the motherboard.
                              i did give the measurements right? or did I miss one?
                              PU4301
                              PIN1 = 19.4v
                              PIN4 = 3.13v
                              PIN1=19.4V
                              PIN4=1.77VPIN8=19.44V (PINS 7&8 are joint in same solder, as is 5&6)
                              PL4401 (labelled, 4R7 734 VCM)
                              0V on both pins. (do I need to power switch on to measure?)
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Hmm.. The image at post#4 shows battery is at 99% charge level. Discharge the battery to atlest 90% and then plug the adapter.Does it charge now??
                                PS:Measurements at post#7 are correct and that proves nothing is wrong with these mosfets.
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  Yes. I am familiar with DELL power delivery in general and also the Vegas/Turis board for this model. Your electrical readings are absolutely fine.
                                  Therefore, there are only 3 possible causes to your problem:
                                  1. Too low power AC adapter (say 45W or 65W on a board with a dedicated GPU which requires 90W). Probably not your issue but you never know.
                                  What I know is the Vegas/Turis board comes in both UMA integrated CPU graphics and dGPU versions. The two versions require different wattages on the power brick. The version using integrated CPU graphics uses a tiny 45W brick off the top of my head. The DGPU one, I can't remember.
                                  Also check adapter power cable and motherboard power jack for continuity on ID pin.
                                  2. BIOS or EC firmware or hardware issue on KBC chip.
                                  3. Incompatible or damaged battery.
                                  There is a SOFTWARE (Windows level) bypass possible, it just requires admin access and a scheduled task - ThrottleStop on startup can force the CPU to full stock and turbo. But I would recommend finding out what causes the throttle in the first place.
                                  A working TV? How boring!
                                  • WhatsTheDellio
                                    • Jan 2023
                                    • 16
                                    I already discharged the battery to 80% since taking that picture. it says charging but current is still 0ma on bios. I just don't have a screenshot.
                                    I saw a YouTube video where someone with similar model replaced their ncp81208 and I was going to do this first before I realized this forum exists where I might actually learn how to read the schematic and work through it systematically instead of anecdotally.
                                    Aside, is there a good description of that solder procedure? Looks like heatgun to a specific temp (I have ir camera so I feel confident about that) but the flux I'm unsure about and I've only soldered with wire and pins with iron, never these IC with a air gun. (is it called BGA)?
                                    • WhatsTheDellio
                                      • Jan 2023
                                      • 16
                                      integrated graphics Intel HD 3000.
                                      The only difference is I swapped out the old HDD for an SDD but that wouldn't require a different power adapter.
                                      tried 2 different genuine Dell adapters. and 3 batteries (2 genuine Dell and 1 3rd party all behave same way).
                                      replaced the DC jack on motherboard.
                                      The throttle only applies when battery is installed. if I remove battery there is no throttle. And while the battery is not charging I see no reason to have it installed. thus I diagnose the board and repair it hopefully.
                                      • mon2
                                        • Dec 2019
                                        • 14240
                                        BGA = ball grid array. Will have tiny spheres / solder balls underside of the package.
                                        From a quick search, ncp81208 = QFN = Quad Flat pack.
                                        Each side has contacts that can be soldered + 1 in the center for often the heavy ground = we call it the 'metal belly'.
                                        Either way, flux is required = Amtech is a good brand pitched by Louis.
                                        The factory that sells the original Amtech is old school and we attempted to do business with them but they appear to be in bed on exclusives with Louis.
                                        That is fine, but is silly priced in Canada. We bought ours from Aliexpress and it is likely a fake but works fine.
                                        Have you tried Mobile Sentrix ? Check out their catalog. They do want to work with only established businesses but if you really want something from there, PM me and we can drop ship it.
                                        Likely there are other options for the flux in Canada as well.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • ipatch
                                          dell inspiron 5567 laptop battery lipo WDX0R
                                          by ipatch
                                          recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
                                          1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
                                          2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
                                          got the computer...
                                          04-02-2023, 04:45 PM
                                        • tomodachi
                                          Dell Precision 5510 " Not a Dell Battery"
                                          by tomodachi
                                          Hi
                                          Dell Precision 5510
                                          Mobo code : LA-C361P
                                          This one came in for battery replacement but without original battery, so original battery and charging history is unknown.
                                          The customer said he bought the computer several years ago second-hand and was told that there was no battery inside but that he could purchase one if he wanted.
                                          So we ordered a geniune battery for customer, plugged it in
                                          RTC battery was also dead and it was also replaced. First boot up brought up warning message;
                                          Funny thing is Service Tag is already set.
                                          And...
                                          11-07-2024, 06:08 AM
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
