Dell Precision 5510 " Not a Dell Battery"
  • tomodachi
    • Apr 2012
    • 632
    • Turkey
    Hi
    Dell Precision 5510
    Mobo code : LA-C361P
    This one came in for battery replacement but without original battery, so original battery and charging history is unknown.
    The customer said he bought the computer several years ago second-hand and was told that there was no battery inside but that he could purchase one if he wanted.
    So we ordered a geniune battery for customer, plugged it in
    RTC battery was also dead and it was also replaced. First boot up brought up warning message;
    Click image for larger version  Name:	resim.png Views:	0 Size:	210.9 KB ID:	3502168
    Funny thing is Service Tag is already set.
    And in battery information tab ;
    Click image for larger version  Name:	resim.png Views:	0 Size:	288.0 KB ID:	3502167
    Thought it could be a faulty battery and ordered another, but no change.
    Battery is not being charged even powered off
    Note : There is a " This product contains used parts" sticker on bottom cover.
    Any ideas to get it to charge battery please ?
  • mon2
    • 16807
    Check the voltage on the SMBUS lines of the battery connector with the battery attached. You should have ~3v3 on the SCL / SDA lines.
    • tomodachi
      • Apr 2012
      • 632
      • Turkey
      Hello and thank you for answering
      Both lines have 3.3V
      • mon2
        • 16807
        Try to update the bios or test with another known good bios.
        https://www.dell.com/community/en/co...ccf8a8de62bc4a
        • tomodachi
          • Apr 2012
          • 632
          • Turkey
          Both done, no result.
            • 25735
            Does the service tag in the bios screen match with the one on the sticker on the base cover
            • tomodachi
              • Apr 2012
              • 632
              • Turkey
              Umm service tags are different
              By the way, when I tested it with the battery I got from another same laptop, it charges perfectly and gives no startup errors... pretty confusing
              • mon2
                • 16807
                To me, it appears the batteries you are sourcing have bogus and incompatible BMS modules. The last one you have tested is a good fit and has pacified the checks made by the logic board.
                • tomodachi
                  • Apr 2012
                  • 632
                  • Turkey
                  Absolutely.
                  You wouldn't believe the ability of some companies to produce fake batteries and sell them as original.
                  Returning batteries to supplier, I will share the news
                  • tomodachi
                    • Apr 2012
                    • 632
                    • Turkey
                    Update :
                    Problem fixed with a geniune battery from another supplier. Everything work fine now.
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • Fejroo
                      Dell lattitude 5285 2-in-1 marks battery as "Not DELL Battery".
                      by Fejroo
                      I bought used battery from exactly same model of Dell lattitude 5285 2-in-1. I plugged battery in my device and at the first run I get message that inserted battery is not a DELL Battery. The battery isn't charging either.
                      After some research I found out that that battery might need a BMS Programming for my device. Is it really necessary? Is there another way to solve this problem?...
                      10-11-2026, 01:25 AM
                    • XIII
                      Dell latitude 5510 i5 10th unknown battery error
                      by XIII
                      Good evening, I'm dealing with this weird case where the battery does boot the laptop and hold the charge, but it won't charge and is described as "unknown battery" in bios, the charger is detected fine as a 130w dell charger, I've tried with diffrent batteries and I still get the same case, I have the nlba1 and I've confirmed that the tested batteries works fine, I'm getting a 4 amber 1 white error as well, I've found a shorted mosfet on the battery power rail which I've replaced, I've tested and replaced the diods that relates to the clock and data but still have the same issue, BTW...
                      10-26-2026, 07:13 PM
                    • TheQuentincc
                      Dell Precision 7550 - Battery charging issue ? BQ40370 BMS
                      by TheQuentincc
                      I have a Dell precision 7550 with BQ40370 BMS on the 95Wh Dell 3S2P battery.
                      Using batteryinfoview I can check the health of the battery, it is currently at 66.2% (63Wh) :
                      The specs printed on the battery claims nominal voltage is 11.4v and charging voltage is 13.35v (4.45V per cell, so LiHV ?).
                      However it doesn't charge past 11.65V (3.88V per cell), with this "low" voltage the battery only last for 43Wh (estimation using excel + discharge rate from fully charged to power down). When it "stops" charging it goes from 68% to 100%...
                      08-27-2026, 04:24 AM
                    • Boardview and Schematic Bot
                      Dell Precision T3240 Workstation IPCML-RN65DGFX Boardview & Schematic
                      Dell Precision T3240 Workstation - IPCML-RN65DGFX IPCML-RN65_DGFX.cad
                      Dell Precision T3240 Workstation - IPCML-RN65DGFX IPCML-RN65_DGFX.pdf...
                      11-02-2026, 04:20 PM
