Macbook 820-00923
  • Instafixx
    • Jul 2022
    • 374
    • India
    Macbook 820-00923
    We have wrecked a Macbook Pro 820-00923.
    The Macbook came in for a LCD Replacement. So we went ahead a performed a LCD only repair to find out that the Camera was showing as "Camera not connected". Upon diagnosis and checking through a couple of days we were able to isolate the problem to the flex beside the camera beneath the lcd. We may have damaged it while removing the LCD.
    We used jumper wire to jumper the flex hoping to get back the Camera but i think we wrecked the board. The board isnt booting up now. It is drawing 20 Volts on the Amp Meter and evening drawing upto 1.3 to 2.5 A. The keypad works. The fan spins doesnt spin initially. The CPU becomes very hot.
    I think its the Camera Jumper that have wrecked it.
    WHile checking the J8500 i found one thing
    With nothing connected to the board and charger connected there was no voltage at
    PP5V_S0 and PP5V_S0_ALSCAM_F
    Any help in this regard will be very grateful.
    @mon2 @piernov @reformatt
  • mon2
    • Dec 2019
    • 14106
    Re: Macbook 820-00923
    CPU is very hot with the heatsink ? Or without the heatsink ?
    Yes, CPU will be hot without a heatsink. This is normal.
    Remove all power -> what is the resistance to ground of PPVCC_S0_CPU ?
    What is the voltage to ground of PPBUS_G3H @ F7000 ?
    • Instafixx
      • Jul 2022
      • 374
      • India
      CPU isnt very hot. Its normal heating. The heatsink is there.
      PPVCC_S0_CPU checked at C10G1 .
      Meter is Resistance Mode (Omega Sign) 5.08 ohms
      Meter is 2K Mode (Analog Meter) its 0.05.
      (Both Images attached)
      PPBUS_G3H at F7000 is 13.02V
      • mon2
        • Dec 2019
        • 14106
        Switch the (first) digital meter to the lower 200 ohm scale and measure again. The resistance looks ok for the CPU.
        See attached. Measure the voltage to ground of each point of interest.
        U8500 is a load switch. Fancy name for a solid state relay and is used to power the LCD display. If you are not measuring a voltage to power the display / camera then the wiring that was applied should be reviewed and also the linked regulators.
        Confirm that U8500 is being powered; being enabled. Post each measurement.
        • Instafixx
          • Jul 2022
          • 374
          • India
          The voltage at all points of U8500 is 0.
          Since the area is a bit cramped hence i checked corresponding points on other area of the board for the same line. Its 0V.
          The amp meter shows that the board is pulling 19.7V.
          (Nothing is connected to the board except the charger.)
          Setting the resistance to 200 i am getting 5.1 ohms at C10G1.
          • mon2
            • Dec 2019
            • 14106
            After allowing for a normal boot up of the logic board, does the caps key LED toggle ? This will confirm that the logic board is booting.
            • Instafixx
              • Jul 2022
              • 374
              • India
              No, it doesnt toggle.
              The Touchbar is inactive.
              The trackpad works though.
              Removing the trackpad cable also gives us a max fan spin (which it should).
              • mon2
                • Dec 2019
                • 14106
                If you are drawing 20V, this means the CD3215s are working.
                Check the following list of power rails:
                https://www.logi.wiki/index.php/Power_Rail_List#A1706
                Update:
                Measure the voltage of L7660 to ground.
                See attached - does the board turn ON/OFF with the button presses?
                If yes, measure PM_PWRBTN_L voltage to ground as you press the same button(s). What voltage do you measure?
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  PPBUS_G3H
                  PPBUS_HS_CPU
                  PPBUS_HS_OTH5V
                  PPBUS_HS_OTH3V3
                  PPBUS_S4_HS_TPAD
                  ALL AT 13.03V TO 13.5V
                  PP3V3_G3H
                  PP3V3_G3H_SMC_ISNS
                  ALL AT 3.4V
                  PP3V0_G3H
                  AT 3.08V
                  PPVCC_S0_CPU
                  PPVCCSA_S0_CPU
                  PPVCCGT_S0_CPU
                  AT 0 VOLTS
                  IMVP RAILS AT 0.
                  PPVCCIO_S0_CPU
                  ALSO AT 0 VOLTS
                  CPU VCCIO Rails AT 0
                  PPVCCEDRAM_S0_CPU
                  ALSO AT 0 VOLTS
                  CPU EDRAM Rails AT 0
                  PPVCCPRIMCORE_SUS_PCH
                  IS AT 1V
                  PP0V6_S0_DDRVTT
                  PP0V6_S3_MEM_VREFDQ_A
                  PP0V6_S3_MEM_VREFCA_A
                  PP0V6_S3_MEM_VREFDQ_B
                  ALL AT 0 VOLTS.
                  0V6 Rails AT 0
                  PP1V8_SUS
                  PP1V8_S4
                  PP1V8_S3
                  PP1V8_S3_MEM
                  PP1V8_S0
                  ALL AT 1.8 VOLTS
                  PP1V0_SUS
                  PP1V0_SUS
                  PP1V0_SUS
                  PP1V0_SUS
                  ALL AT 1V.
                  PP5V_S5 IS AT 5V
                  PP5V_S4 IS AT 5V
                  PP5V_S4SW IS AT 0V
                  PP5V_S4SW_ISNS IS AT 0V
                  PP5V_S0 IS AT 5V
                  PP5V_S0_KBD IS AT 5V
                  5V RAILS PARTIALLY MISSING
                  PP3V3_S5 is at 3.3V
                  PP3V3_SUS is at 3V
                  PP3V3_S4 is at 3.3V
                  PP3V3_TBT_X_S0 is at 3.3v
                  PP3V3_TBT_T_S0 is at 3.3V
                  PP3V3_S4_BT is at 3.3V
                  PP3V3_S4_TPAD is at 3.3V
                  PP3V3_S4SW_SNS is at 0V
                  PP3V3_S5_SSD_LB is at 3.3V
                  PP3V3_S5_SSD is at 3.3 V
                  PP3V3_S4_MESA is at 3.3V
                  PP3V3_2V7_NAND_VCC is at 2.7V
                  3v3 Rails are partially missing
                  PP3V3_S5_T139 is at 3.3V
                  PP3V3_S4_SOC_PMU is at 3.3V
                  T208 rails are ok.
                  I am bit worried now as the CPU rails are 0. I hope this is recoverable.
                  Voltage to Ground at L7660 Pin #1 is 3.3V and Pin#2 is 19.06V.
                  No the board doesnt turn on/off with the button pressed.
                  • mon2
                    • Dec 2019
                    • 14106
                    What is the voltage to ground of SMC_SENSOR_PWR_EN ?
                    Review u8213.
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      PP5V_S0
                      PP5V_S0 IS AT 5V
                      • Instafixx
                        • Jul 2022
                        • 374
                        • India
                        Originally posted by piernov
                        Hi Piernov,
                        I didnt notice this. Thanks for pointing out. I will get back on this tomorrow. The rail voltage was checked at 2 different points i guess thats why the different voltages.
                        Will update tomorrow.
                        • Instafixx
                          • Jul 2022
                          • 374
                          • India
                          Review u8213.
                          SMC_SENSOR_PWR_EN at U8213 Pin#2 is 3.39V.
                          Pin#5/6 and Pin#7 is Missing.
                          • Instafixx
                            • Jul 2022
                            • 374
                            • India
                            There is Voltage at PP5V_S0 and PP5V_S0_ALSCAM_F.
                            Maybe the initial reading was wrong.
                            • Instafixx
                              • Jul 2022
                              • 374
                              • India
                              What can be the issue ? Please help. @piernov @mon2
                              • mon2
                                • Dec 2019
                                • 14106
                                What is the voltage on pin # 1 of U8213 ?
                                Confirm each of the voltages on U8213.
                                If this part is being powered AND being ENABLED, then output should be present.
                                Either this load switch is defective OR the output rail is being shorted.
                                Remove all power -> meter in resistance mode and check the output pin # 5 to ground.
                                What is the resistance reading of PP5V_S4SW to ground ?
                                • piernov
                                  • Jan 2016
                                  • 4435
                                  • France
                                  Pp1v2_s3
                                  • Instafixx
                                    • Jul 2022
                                    • 374
                                    • India
                                    U8213
                                    Voltages
                                    Pin# 1 5.13V
                                    Pin# 2 3.38V
                                    Pin#3/4 5.13V
                                    Pin#5/6 0.09V
                                    Pin#7 0.09V
                                    Pin# 8 GND
                                    Resistance (Omega Mode)
                                    Pin # 5 is 5.4.
                                    • Instafixx
                                      • Jul 2022
                                      • 374
                                      • India
                                      Pp1v2_s3
                                      What about this?
                                      • mon2
                                        • Dec 2019
                                        • 14106
                                        To me, U8213 is defective and should be replaced. This is a load switch that is being enabled but the voltage is not present at the output pin # 5.
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
                                        • shlomim412
                                          macbook pro a1990 - 820-01041 drawing 5v on usb c port
                                          by shlomim412
                                          Hello
                                          working on a 820-01041 a1990 macbook pro
                                          the machine is only drawing 5v on usb c ports, and around 0.24a
                                          one board measured 5v and 0.00a but later when i connected again it's went to 0.24a
                                          ppbus is 12.27v-12.29v
                                          is not recognized on apple configurator on dfu or recovery
                                          can't seem to find a short anywhere on board but with the power adapter connected (without battery)
                                          i notice the t2 chip is getting a little hot..
                                          pp1v8_slps2r present and doesnt seems to be shorted..
                                          any ideas? how can...
                                          07-16-2024, 12:58 PM
                                        • tobeend
                                          Bypass mdm macbook m2 ventura
                                          by tobeend
                                          1. RESET MACOS WITH IPSW
                                          a. Power off MacBook, press and hold the power button to enter Recovery
                                          b. Open Disk Utility, remove Macintosh HD
                                          c. Reboot, connect to the network to Activate Mac.
                                          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                          e. Release the other keys, but keep holding the Power key for another 10 seconds
                                          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                          05-26-2023, 07:18 AM
                                        • mikay786
                                          Is this jumper wire correct? macbook board missing pad.
                                          by mikay786
                                          2015 macbook pro which has no sound.
                                          Noticed some corrosion by the Cirrus audio ic. Resister R6324 had corroded off the board, pad indicated in pic is gone.
                                          So soldered another 100k resister to the pad closest to the ic and ran a jumper wire as per pic to l6201 for the 3v.
                                          Is that correct or should i be jumpuring to somewhere else?...
                                          04-13-2023, 09:54 PM
                                        • SarcasticOP
                                          General question about MacBook power rails for repair.
                                          by SarcasticOP
                                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                          • PPBUS_G3H (12.6V-12.8V)
                                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                          • PP3V42_G3H (3.42V)
                                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                          • PPVRTC_G3H (3.3V)
                                            • This
                                          12-12-2024, 05:50 PM
