Macbook 820-00923
  • mon2
    • 14662
    Re: Macbook 820-00923
    Measure the diode mode reading of PP3V0_G3H.
    • Instafixx
      • Jul 2022
      • 374
      • India
      #42
      Originally posted by mon2
      Pin #1 on C1227 its 1.8M (Omega Sign)
      Voltage is at 3V too.
      I think this line is fine too.
      Maybe the U7800 is defective. What do you feel Mon2 ?
      • Instafixx
        • Jul 2022
        • 374
        • India
        #43
        What should be done?
        • mon2
          • 14662
          Remove all power. Meter in the lowest resistance scale.
          What is the resistance to ground of PPVCC_S0_CPU ?
          Meter in voltage mode. Measure the voltage to ground of:
          PPBUS_HS_CPU (U7210 / U7220 / U7270)
          CPUCORE_PWM1
          CPUCORE_PWM2
          CPUSA_PWM
          PPVIN_S0_CPUVR_VIN (U7100)
          PP5V_COREVR_VCC (U7100)
          Going back to PP5V_S4, can you measure the voltage to ground @ L7600 (pin #1) ?
          Do you see a voltage on the working board for this rail ?
          Then check the non-working board as well.
          This voltage is required to power U7100 (pin # 42) which in turn sequences the CPU voltage phases.
          • Instafixx
            • Jul 2022
            • 374
            • India
            #45
            CPUCORE_PWM1
            CPUCORE_PWM2
            CPUSA_PWM
            PPVCC_S0_CPU resistance is 5.5 (Meter kept on the Lowest Scale - at 200.)
            PPBUS_HS_CPU is at 13V
            CPUCORE_PWM1 is 0.5 Volts
            CPUCORE_PWM2 is at 0.5 Volts
            CPUSA_PWM is at 0.48 Volts
            PPVIN_S0_CPUVR_VIN is 13V
            PP5V_COREVR_VCC is at 5 Volts
            PP5V_S4 is at 5 Volts.
            What can be the issue? i am so utterly confused here!
            • mon2
              • 14662
              Are these measurements from the non-working board?
              Compare these readings with the working board.
              Do you have caps key light toggle?
              External type c to hdmi produce video?
              Test for usb activity on each usb port. See if a thumb drive led flickers on each port.
              • Instafixx
                • Jul 2022
                • 374
                • India
                #47
                Readings on the Working Board
                PPVCC_S0_CPU resistance is 7 (Meter kept on the Lowest Scale - at 200.)
                CPUCORE_PWM1 is 0.2 Volts
                CPUCORE_PWM2 is at 2.5 Volts
                CPUSA_PWM is at 0.21 Volts
                Updating the rest in 10 Mins
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  #48
                  Dont have Caps Key Light.
                  The Power Button is Working.
                  Pressing it Switches off the Machine (the trackpad doesnt press) and then again switches on using the power Button.
                  There is no external display with and without the LCD connected.
                  We dont have any usb to check usb activity .
                  • mon2
                    • 14662
                    Locate for testing a usb c to hdmi dongle or hub that is compatible with macbooks. Test again on both units.
                    • Instafixx
                      • Jul 2022
                      • 374
                      • India
                      #50
                      i Have a hub that has HDMI. There is no external video output.
                      • mon2
                        • 14662
                        Test it on the working board. Any video?
                        • Instafixx
                          • Jul 2022
                          • 374
                          • India
                          #52
                          Yes.
                          This video output is checked after installing both boards on the body with battery connected and booting the machine.
                          The bad board doent boot. But has fan spin etc.
                          • mon2
                            • 14662
                            What is the voltage to ground of VCC_S0_CPU ?
                            Measure for a few seconds.
                            Compare to the working board.
                            Reference:
                            https://boards.rossmanngroup.com/thr...of-life.60763/
                            • Instafixx
                              • Jul 2022
                              • 374
                              • India
                              #54
                              Reference:
                              There is nothing a VCC_S0_CPU . Its PVCC_S0_CPU.
                              Voltage on the Working Board
                              1.06V the Drops to 0.6V after a few seconds.
                              Voltage on the Bad Board
                              1.06V Stable does not increase.
                              This Voltage was initally 0V.
                              We did a reball of U7800 and this Voltage was achieved.
                              • mon2
                                • 14662
                                On the hub, can you insert a usb flash drive? Do you see activity on the usb flash drive? Test on the working and non-working boards.
                                Do you have the tools to reflash the BIOS?
                                One thought is to remove the good bios on the good board. Keep the good bios aside.
                                Then take the bios from the non-working board and apply to the working board.
                                Does the working board continue to work?
                                This should confirm if the bios is not corrupted.
                                • Instafixx
                                  • Jul 2022
                                  • 374
                                  • India
                                  #56
                                  I don't have the tools do flash the bios but i can get that arranged locally.
                                  Flashing the BIOS will remove the Data ? ( I have absolutely no idea about this)
                                  • mon2
                                    • 14662
                                    Bios is used to boot up the logic board. It is the first code used to start up the board. Data is on the ssd of this logic board. That is, ssd could be blank but the bios firmware still will offer the power up apple logo. The operating system from the ssd or internet follows afterwards.
                                    It is only an attempt but perhaps the main bios is corrupt. We do not want to alter or risk the known good bios so best to remove and place it aside.
                                    From the resistance, do not think the CPU is dead but not 100% sure.
                                    Do check for usb activity on both boards to gauge the differences.
                                    Wish to be clear that we do not want to erase or write to the flash device.
                                    Only apply the flash from one board to the other.
                                    • mon2
                                      • 14662
                                      Also, compare the voltage to ground of the spi lines used by the flash memory device on both boards. Post your updates.
                                      • Instafixx
                                        • Jul 2022
                                        • 374
                                        • India
                                        #59
                                        Which programmer will you recommend ?
                                        Also the bad board is bad board is drawing more amps than normal. I will tell you the exact voltages tomorrow .
                                        • Instafixx
                                          • Jul 2022
                                          • 374
                                          • India
                                          #60
                                          Do you mean the SPI ROM Lines?
                                          • envym
                                            by envym
                                            Hi everyone!
                                            06-27-2025, 08:54 AM
                                          • shlomim412
                                            macbook pro a1990 - 820-01041 drawing 5v on usb c port
                                            by shlomim412
                                            Hello
                                            working on a 820-01041 a1990 macbook pro
                                            the machine is only drawing 5v on usb c ports, and around 0.24a
                                            one board measured 5v and 0.00a but later when i connected again it's went to 0.24a
                                            ppbus is 12.27v-12.29v
                                            is not recognized on apple configurator on dfu or recovery
                                            can't seem to find a short anywhere on board but with the power adapter connected (without battery)
                                            i notice the t2 chip is getting a little hot..
                                            pp1v8_slps2r present and doesnt seems to be shorted..
                                            any ideas? how can...
                                            07-16-2024, 12:58 PM
                                          • Flasman90
                                            Macbook Pro DFU Restore Issues
                                            by Flasman90
                                            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                            08-30-2025, 10:27 AM
                                          • Tend0
                                            MacBook Pro A2141 (820-01700-A) Not turning on, drawing 0.088-0.04A at 20V
                                            by Tend0
                                            Diagnostic Steps:
                                            I try DFU Revive and Restor got error [AMRestoreErrorDomain – 0xA (10)]
                                            find a short to ground on PP2v5_NAND_SSD_1 Resistance is 21ohm
                                            PP1v8_SSD1 resistance is 2.7 ohm
                                            PP0v9_SSD1 resistor is 305ohm
                                            i think NAND_SSD_1 fail
                                            Before doing anything, I need expert advice on how to get the computer working again thanks for support
                                            10-26-2025, 06:29 PM
                                          • tobeend
                                            Bypass mdm macbook m2 ventura
                                            by tobeend
                                            1. RESET MACOS WITH IPSW
                                            a. Power off MacBook, press and hold the power button to enter Recovery
                                            b. Open Disk Utility, remove Macintosh HD
                                            c. Reboot, connect to the network to Activate Mac.
                                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                            05-26-2023, 07:18 AM
