macbook pro a1990 - 820-01041 drawing 5v on usb c port
  • shlomim412
    • May 2018
    • 45
    • israel
    Hello
    working on a 820-01041 a1990 macbook pro
    the machine is only drawing 5v on usb c ports, and around 0.24a
    one board measured 5v and 0.00a but later when i connected again it's went to 0.24a
    ppbus is 12.27v-12.29v
    is not recognized on apple configurator on dfu or recovery
    can't seem to find a short anywhere on board but with the power adapter connected (without battery)
    i notice the t2 chip is getting a little hot..
    pp1v8_slps2r present and doesnt seems to be shorted..
    any ideas? how can i confirm wheter t2 is the problem or not?
    thanks!
  • mon2
    • 16656
    Are you drawing an immediate 0.24A on the 5v USB C ? Or does it climb up to this current value?
    • shlomim412
      • May 2018
      • 45
      • israel
      hi
      sorry for the late response
      main port is drawing 0.00a 5v for around 10 seconds and than jumps to 0.24-0.25a steady.
      all other 3 ports once connected starting on 0.01 to 0.11 and immediatly to 0.24-0.25a steady. (total around a 1second to get to this amp draw).
      • mon2
        • 16656
        Confirm if you have the following:
        PP3v3_S5
        PP5V_S5
        Review the case details here:
        MacBook Pro A1990 Charger stuck at 5V repair - Repair Wiki
        • shlomim412
          • May 2018
          • 45
          • israel
          hi
          seems like those are missing
          PP3v3_S5
          PP5V_S5
          thanks for the link
          but can't find any port that is boot looping
          the only thing that is diffrent between the others is that the main port starts off with 0.00a 5v
          after a few seconds it climbs also to 0.25-24a
          any help would be appreciated..
          thanks..
          • mon2
            • 16656
            Measure the voltage to ground at the battery connector J6951 for:
            SMBUS_3V3_BATT_SCL
            SMBUS_3V3_BATT_SDA
            Post each measurement.
            • megacap
              MacBook Pro Retina 15.4-inch (2018) A1990 820-01041 No charge, no power after letting battery die and not using for a bit
              by megacap
              So I this MacBook Pro Retina 15.4-inch (2018) A1990 laptop that suddenly will not charge or start. It was working fine before. It would charge and was starting up normally from sleep. The only thing abnormal is that it seemed to be getting battery health warnings. Maybe a precursor of what was to come. Let it sit in sleep mode for about a week. Now it seems completely dead. Seems like no power at all. No lights, no fans, no screen, no touchpad clicks. Battery charger, which is apple 87w, doesn't get hot at all when plugged in. Charger will charge an iphone just fine though....
              06-05-2026, 12:38 PM
            • Boardview and Schematic Bot
              Apple MacBook Pro 13 M1 820-02020-A 820-02020 Boardview and Schematic
              Apple MacBook Pro 13 M1 820-02020-A boardview 820-02020 V1.0 Boardview
              Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB
              Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Physical scanning image
              Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Location map...
              06-20-2026, 10:11 AM
            • alfredodinolfo
              MacBook Pro 2019 (A1990)
              by alfredodinolfo
              mb code:820-01827-A;
              sn:C02Z349ALVDR;
              i9 32GB Ram 1TB
              Hi, I found short on one of 6 black nand (total 1TB).
              i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
              I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
              macbook with A2141 configuration run on recovery but don't complete it.​
              anyone can help me?
              05-26-2025, 09:27 AM
            • silver60618
              Macbook Pro A1990 - Battery not detected after connector torn off
              by silver60618
              Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
              Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
              11-12-2025, 06:36 PM
            • robka
              MacBook Pro 2018 - A1990 Dead - not charging - only 5V
              by robka
              my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
              I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
              The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
              After that the Macbook was dead. It isn't charging anymore.
              The USB-C Port where the charger was plugged is burned. Also The Cable and the...
              03-02-2024, 02:58 PM
