Screen Replacement for A2337
  • kino0924
    • Jan 2023
    • 12
    I have a 2020 macbook air m1 that needs a screen replacement (cracked)
    Right now, I have few options but not sure what to take
    1. Screen only from aliexpress (80 USD)
    2. Housing and screen from aliexpress (144 USD)
    3. Genuine used screen from ebay (250 USD ish)
    4. New screen from ifixit (450 USD)
    To be honest, I dont think new screen from ifixit is worth it since I can get it replaced by apple with same amount of price (haha)
    Now, I am wondering is it really worth to spend 100 more on used genuine screen.
    Also, do I get a warning/issue with replacing screen?
    I know recent iphone gives stupid genuineparts/true tone disabled if serial does not match with original.
    I couldnt find any information if that gets applied for MBA 2020 M1 but want to double check.
    Thanks!!
  • reformatt
    • Feb 2020
    • 1745
    Re: Screen Replacement for A2337
    I’ve bought screens off AliExpress. Enough to not offer them for a customers device. You will get a blemish or two on most or the colours aren’t quite right. If you have an issue with the screen down the track, the suppliers just ghost you. I’d get the used genuine display if it were me, or buy an iCloud locked device to steal parts off.
    • piernov
      • Jan 2016
      • 4438
      • France
      Many mislabelled or poorly refurbished display assemblies on Aliexpress, especially for newer machines. Not recommended.
      • kino0924
        • Jan 2023
        • 12
        Thank you so much for the reply
        I will not cheap out on the parts and will get genuine parts from ebay.
        • spidertnt
          • Jul 2016
          • 34
          Amazon.ca $349
          https://www.amazon.ca/GBOLE-Replacem...NsaWNrPXRydWU=
          • mon2
            • 16552
            The reference Amazon display is NOT an Apple original. It is a compatible display made by some company in China (most likely) / Taiwan. With Amazon, at least you have rights that you can return it if it does not work for you or is not to your liking.
            We have had fairly good luck in sourcing displays offshore that work fine but the original is the original. Different price points / different specs.
            Take for example, the Apple logo on the actual display. You will not find that support @ Mobile Sentrix - perhaps is available on Amazon. Offshore, yes but need to ask for it.
            True tone support - no idea at this time.
            Zero dead pixels - be sure to ask the vendor.
            Intensity - the ones we have sourced have been fine but the original is still better.
            Under the circumstances, proper vetting of the vendors offshore is worthwhile to seek out a quality product.
            • rediii
              h???, spurrrn
              • Mar 2018
              • 556
              • somewhere in europe
              exactly this, thanks mon2
              • SpifTek
                • Jan 2023
                You can buy an IC locked complete unit in great condition for about $250.
                No one wants them because you can't yet bypass them.
                • nikey22
                  • Aug 2021
                  • 5
                  I'm unsure if this is still accurate as of 6/13/2023, but regarding a used genuine Apple M1 Display for 2020 machines:
                  Even if you manage to get a genuine replacement unit, the serial number located in the LCD I/C will be different that your logic board's serial number. M1 models pair the LCD to the Logicboard. This mismatch disables True Tone functionality. There is currently no way to program the LCD I/C to the logic board's serial number, like you can easily do with iphones.
                  Can someone who has replaced these with Genuine Apple LCDs shed some "light" (no pun intended) on the matter? Is True Tone preserved with a genuine swap or not?
                  Thanks!
                  • abadcap
                    • Jan 2020
                    • 12
                    • 342A
                    I replaced recently a cracked screen with a genuine Apple LCD on MBA M1. The result is:
                    - True Tone does not work (there is no option to turn it on/off in the settings)
                    - the Apple Hardware Test will show at the end of the diagnostics the error code "ALS001" saying "There may be an issue with the ambient light sensor"
                    • MagJ_
                      MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
                      by MagJ_
                      Hello Everybody,
                      I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
                      10-09-2024, 02:51 PM
                    • FreakyMex
                      Trouble to identify part (Lunii screen) for replacement
                      by FreakyMex
                      Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                      I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                      02-17-2025, 01:16 AM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • mferna14
                      MacBook Air A2681 battery problem after Screen Replacement
                      by mferna14
                      Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                      12-06-2024, 08:10 PM
                    • abajor
                      A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                      by abajor
                      Having this very weird issue.
                      The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                      I swapped with a working screen from an A2141 waiting for parts.
                      The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                      The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                      04-27-2024, 01:37 PM
