Macbook A1990 820-01041-A No Power on
  • mon2
    • Dec 2019
    • 14012
    Re: Macbook A1990 820-01041-A No Power on
    The input voltage @ R7015 is too low. It should be 5 volts or higher.
    Are you using the official and recommended power Type C adapter to power this logic board?
    Start with the voltage to ground measurement of the port that is mated with the power adapter.
    PP20V_USBC_XA_VBUS ; whichever is powering your board now
    PP20V_USBC_XB_VBUS
    You should see 5 volts going into your logic board.
    • Strolch
      • Nov 2017
      • 237
      • Deutschland
      i use the 96W original Apple. Pin 1 R7015= 4,15V
      • mon2
        • Dec 2019
        • 14012
        Ok. See attached. Measure the voltage at the entry fuses. It is possible that some component is pulling down this voltage.
        If still the same 4,15V -> remove all power. Meter in resistance mode.
        Measure the resistance to ground of R7015. What is the resistance reading ?
        • Strolch
          • Nov 2017
          • 237
          • Deutschland
          the board is hot at the point like in the picture from the cam. Maybe that's why only 4V?
          • mon2
            • Dec 2019
            • 14012
            Ok - proceed to remove the 2 x fuses in the last post = F3000 and F3001.
            Then power up again and confirm that the adapter is indeed supplying 5 volts at the PCB pads of F3000 pin # 1.
            • Strolch
              • Nov 2017
              • 237
              • Deutschland
              #26
              F3001= 4,96V but F3000 is 0V But I see that the Q3100 is probably not ok. I think it was soldered! I took a picture. I think I have to swap it!
              • mon2
                • Dec 2019
                • 14012
                F3000 is linked to the other type C connector.
                Move the power adapter to the other connector and confirm it.
                • Strolch
                  • Nov 2017
                  • 237
                  • Deutschland
                  #28
                  I swapped Q3100 and I saw the cc742 was missing. Now it goes up to 20V and down again and sometimes 6V so unstable.
                  • mon2
                    • Dec 2019
                    • 14012
                    Does L7030 still get hot?
                    What is the voltage of ppbus_g3h with the fuse removed?
                    • Strolch
                      • Nov 2017
                      • 237
                      • Deutschland
                      #30
                      F7000 Pad 1 it's 5v it then goes up to 12v and then it goes back down to 5v and then it goes back up to 12v back and forth
                      • Strolch
                        • Nov 2017
                        • 237
                        • Deutschland
                        #31
                        L7030 is hot
                        • mon2
                          • Dec 2019
                          • 14012
                          Check if AWAKE and SLPS2R voltages are present; small coils surrounding U7800.
                          If any 0v, skip to test the next netname.
                          Post the readings.
                          Just saw the thermal.. wow.
                          Remove all power, check the resistance to ground of this coil.
                          • Strolch
                            • Nov 2017
                            • 237
                            • Deutschland
                            #33
                            Awake 0,0015 V It also always goes on of 20V then 0
                            • mon2
                              • Dec 2019
                              • 14012
                              Remove all power -> what is the resistance to ground of L7030 ? It is getting hot due to some event in this region / power rail.
                              Is the fuse present on PPBUS_G3H output side ?
                              • alfredodinolfo
                                MacBook Pro 2019 (A1990)
                                by alfredodinolfo
                                mb code:820-01827-A;
                                sn:C02Z349ALVDR;
                                i9 32GB Ram 1TB
                                Hi, I found short on one of 6 black nand (total 1TB).
                                i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                                I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                                macbook with A2141 configuration run on recovery but don't complete it.​
                                anyone can help me?
                                05-26-2025, 09:27 AM
                              • robka
                                MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                                by robka
                                my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                                I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                                The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                                After that the Macbook was dead. It isn't charging anymore.
                                The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                                03-02-2024, 02:58 PM
                              • DATATECH85
                                Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                                by DATATECH85
                                I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                                The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                                I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                                However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                                Here are the values...
                                07-24-2024, 06:34 AM
                              • Cameron Kajohn
                                A1990 MacBook no power help
                                by Cameron Kajohn
                                I have a a1990 2018 15 inch MacBook Pro that will not power on.
                                I have replaced the pch bga chip because it was heating up under my thermal camera.
                                I have replaced the battery, and replaced the small ic between the gpu and cpu as it had a direct short to ground.
                                the MacBook now pulls 20v 2.4amps the trackpad clicks but it does not ever attempt to power on not even fan spin. After PCH replacement I was able to get it in dfu mode 1 time and restore bridge OS, but now the MacBook will no longer go into DFU mode.
                                I have also noticed L7030 gets extremely hot yet...
                                01-24-2024, 12:00 AM
                              • ahoonid
                                MacBook A1990 vertical stripes on external screen
                                by ahoonid
                                Hey everyone,
                                I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                                The board is neat. Not opened before for sure. Just a little dust, nothing more.
                                Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                                06-20-2025, 08:54 AM
