mitsubishi 3000gt ecms
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    been seeing a bunch of these lately.
    caps leak on board and cause all sorts of annoying intermittants.
    had 3 in this week.
    usually get 1 a month.
    same ecm in other mitsubishi cars too.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    HMMM... Do you have a 3000gt with leaking caps in the ECM? If so, maybe a couple pics?? I've got a 1990 Nissan 300ZX, and now I'm getting curious and might pop the cover off my ECM... Mitsubishi and Nissan both come from the same neck of the world....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      not seen any datsun/nissan stuff yet.at least not for bad caps.
      i didnt take pictures yet as i try to fix and put back in the mail same day.
      here is a page describing the procedurehttp://www.stealth316.com/2-ecmremoval.htm
      • SpaceFrog
        • Apr 2006
        • 4
        300zx
        Not bad caps, but are you aware that the series 1 Z32's PTU generally fail.
        its believed to be related to heat and vibration, so ppl generally relocate it to another point in the engine bay.
        • rumblefish73
          • May 2006
          • 10
          Re: mitsubishi 3000gt ecms
          I have a 1993 Mitsubishi 3000GT that I replaced the caps on it's computer. Two were starting to leak and would have caused problems. Did not have any symptoms, I just did it in advance when I heard about this problem.
          • millions@rideau.net
            • Jul 2006
            HEY rumblefish73 could you please take a picture of the back of your ECU ...
            My 100 microfarad Capacitor has leaked and burnt the copper trace of the negative side of that Capacitor.
            So I dont know what copper trace to resolder the negative lead to
            A picture would let me know where to start
            Thank you
            • rumblefish73
              • May 2006
              • 10
              I wasn't aware mine was CA emissions. What's the difference?
              Here's some more pictures of the ECM when I had it apart.
              I don't have any pics of the underside. Have you tried looking for a schematic?
                • Jul 2006
                Thank You so much for those pics rumblefish73
                There is a trace in the 4th picture you sent that I didnt even know was there
                The Leaky Capacitor must have destroyed the entire trace
                I will resolder the trace today and send You a pic of What I am dealing with
                Where are you located....mabye I could pay you to take out your ECU and rebuild mine looking at yours
                I tried looking and calling around for a schematic......No Such Thing
                Again Thank You very very much
                • hugocarmo
                  Mitsubishi HS-E82 VCR Bad Picture
                  by hugocarmo
                  Good morning everyone.
                  This time I have a Mitsubishi HS-E82.
                  It was a bargain that I found with original remote included.
                  The problem reported by the owner is that it was working but no output video.
                  I took it appart and immediately saw that three 470uf capacitors were leaking on the signal board and one in the Hi-Fi board the same value too. I have located them in the pictures in red marker.
                  I replaced them, cleaned all the liquid remains and the video output got working again.
                  I saw too that were three surface mounted capacitors, two near the 470uf and...
                  11-21-2023, 04:11 AM
                • sikocan
                  Help identify chip MITSUBISHI ELECTRIC Air-Conditioner Network system
                  by sikocan
                  Looking for a component labelled 56 on top 59 on bottom. It's from a MITSUBISHI ELECTRIC Air-Conditioner Network system. Thanks!...
                  06-13-2023, 08:16 PM
                  Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                  by sam_sam_sam
                  I was working on this CNC machine today found no keyboard functioning no control relay powering on
                  The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                  Found shorted diodes on main controller relays there are 3 of them that...
                  01-07-2023, 05:43 PM
                • michalk3777@gmail.com
                  Looking for discontinued Mitsubishi MCU - M306N1MCT
                  by michalk3777@gmail.com
                  If this is not correct forum I apologize, I looked on the store page but did not see anything even close to this.
                  I need help finding a replacement MCU. Its from a Seadoo gauge cluster. Made by Mitsubishi, part No. M306N1MCT-203FP (bottom one on the picture, specs. attached). Cannot locate it anywhere. If anyone can point me to where I could find one in either USA or Canada that would be greatly appreciated.
                  Regards,
                  Michal...
                  09-03-2022, 12:30 PM
                • Keshenatech1
                  Mitsubishi LT-52149 help
                  by Keshenatech1
                  Has anyone out there had any experience with the Mitsubishi LT-52149? (The LT-46149 is identical and uses the same main and power boards, just a smaller panel) I have one that is very intermittent and normal logical troubleshooting steps are not working for me. The set came in with a no sound/no picture problem. After I hit the reset button on the control panel, I got it to come on one time. Snowy screen and loud static in the speakers so I hit the input button to try to switch to an HDMI to quiet it down. It said it was adjusting something and then just shut down. I held the menu and input buttons...
                  12-20-2020, 11:03 AM
