playstation 5 digital firmware dump
  • Jacksoft
    replied
    Originally posted by Cobbes
    Check what southbridge is on your cfi-1216a edm-030
    After start, check if WiFi is working and showing its MAC in system infos.
    Used this on a three beeps PS5 (CFI-1216A, EDM-033, CXD90069GG):
    - Dumped original BIOS and extracted the SN and MB SN.
    - Written on your BIOS SN and MB SN with The Coder cmd tool.
    - Console starts! But LAN MAC address is different! (WiFi seems the same?).
    - Replaced both MAC addresses in the new BIOS.
    - Three beeps again. (Tryed also with another tool and same result)
    Only works with JUST the SN and MB SN replaced. Why!?
    Any suggestion? Could this affects online, PSN, etc?
  • Maxpower3
    replied
    The name of the dump ends with .BIN but must be .bin for the PS5 NOR Modifier.
    I've modified the Windows application to allow all extensions: .Bin /.BIN /.iso /.rom etc....
    If this helps, please test and give me feedback.
    I don't work on PlayStation.
    If this bothers TheCod3r​ or the forum administrators
    Please delete it.
  • umeediqbal80@gmail.com
    replied
    Originally posted by Comp_Pro
    Re: playstation 5 digital firmware dump
    Here is a firmware dump for CFI-1015A. Note that it must end A. Copied from known working and it helped me fix a PS5 that had 3 beeps as soon as you plugged in the AC cable. I believe the board was originally also going to 30mA and then shutting back down.
    Upon boot it is now asking me to reset the software, will update to see if software reset/update will work.
    Hello, will this work for PS5 disk version?
  • igeektech
    replied
    Originally posted by kUiTs
    try this
    tried this and still getting the 3 beeps unfortunately. Any ideas?
  • SoJustMe
    replied
    hi guys , need EDM-032 dump for 61GG please
    i uploaded my currupted firmware
  • kUiTs
    replied
    Originally posted by igeektech
    I have a PS5 Slim CFI-2015 EDM-044 with the 3 beeps, pulled the BIOS file and need help with a good file if anyone can assist.
    try this
  • igeektech
    replied
  • Darky777
    replied
    Good afternoon, any good soul to patch my original 1015B dump with 3BOD with one working??? It will be very appreciated
  • Gamingrepairsukk
    replied
    Looking for a clean dump of CFI-1216B, board EDM-030 if anyone have one thank you in advance
  • kUiTs
    replied
    Originally posted by PedroMa74111271
    i guess im going to try to reflow the wifi chip. i bought this console with a 3 beeps of death, i dont know if the wifi issues was there before or if was caused by nor chip getting corrupted. Its just weird that the same bin file that was corrupted and was causing 3bod its now working.
    Anyway if anyone needs a bin file for a CFI-2016 B01Y (EDM-041) (it may have wifi issues)
    Thank you, your dump kind of worked for me (CFI-2016 B01Y, EDM-040, 69gg, J20H104), but yeah I now also have WiFi issues - MAC is not shown. Do you know if you have J20H100 or J20H104 WiFi/BT module?
    I the beginning I had DEAD console - no peeps, no nothing, Power draw was quick 58mA -> 8mA. BIOS dump showed some errors.
    I replaced values in your dump with my SN and MAC and now console works but no WiFi.
    BT works, update works, PSN games work, disc games work etc, only WiFi does not work.
    Power draw now is 254mA->14mA - kind of strange or not for slim?
  • Reliance Gaming
    replied
    Here is a working dump from a edm-031 cfi-1216a with 69gg southbridge. Change at 0x001C7200 the console unique data (MainboardS/N and SerialNo)
    dude this worked on a edm-040! thanks alot!
  • BD4ROQ
    replied
    have i CFI-1200A, edm030, blown bios chip, can i have the bios file?
    thanks
  • murshad
    replied
    The error su-103121-8 means that the SIE chip on the BD board is not responding.
    This could be no power on the BD board, due to a bad fuse at the connector on the mainboard or missing data connections. The BD board can not be swapped if the BD should be working after the repair.
    If you are using TheCod3r s software to edit the offset, rename the .BIN to .bin
    Its working ok
    I swapped means i put SIE chip to anothor working BD Board
    Anyway thankss
  • Cobbes
    replied
  • murshad
    replied
    Why not fixing the issue with the disc drive? There are two fuses (12v and 5V) on the mainboard near the disc drive power connector and at least two fuses on the disc drive daughter board.
    If it is unfixable in case of a bad SIE chip, than it would be an option to edit the bios data. You can dump the original bios and use TheCod3rs program or do it manually to change the offset 0x001C7011 from 02 (BD) to 03 (digital) to prevent the check for the drive at the update.
    thanks bro
    I actually swapped BD board it shows same error , thats why i trying to edit bios .and i changed the offset but not turning on after that . i put og bios its turning on iam posting my og dump..
    and my bin is not working on the codErs nor modifier .
    replied
    as BWE has decided to bring up the subject of software,
    i'll just post these interesting links to free stuff
    https://github.com/TheCod3rYouTube/PS5NorModifier
    https://github.com/andy-man/ps5-wee-tools
  • Cobbes
    replied
  • murshad
    replied
    hey i have this ps5 for repair it shows error su-103121-8 it came up with drive controller chip so i saw the cod3r was doing that disk edition to digital edition via just rewriting a digital versions bios for try need working bios of a digital version and ,odel number is CFI-1208A
  • Karlhartl
    replied
    Hi Guys, i have this CFI-1200A EDM-030 69GG firmware 9.20 donor dump needed please anyone help out
  • techcity
    replied
    Originally posted by eznacho
    Need CFI-1215B EDM-030 digital version. Thanks in advance.
    Did you ever find this? I am also looking for this file. CFI-1215B EDM-030
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • Tamo Neko
    Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
    by Tamo Neko
    I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
    What Happened:
    I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
    • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
    • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
    What I Need:
    • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
    02-12-2025, 11:29 PM
  • jorpec
    Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
    by jorpec
    Hi, all
    I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
    10-17-2025, 03:51 AM
  • Mephysis
    DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
    by Mephysis
    Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
    I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
    03-27-2025, 02:34 AM
  • gun4as
    Need firmware dump for LG 23MP48HQ-P
    by gun4as
    Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
    08-25-2025, 04:28 AM
