Nintendo Switch drains battery in 2 days when off
  • foshland
    • Jan 2017
    • 122
    • Spain
    Hi, I fixed a nintendo switch that was faulty replacing the M92T36 chip, since it had a short meassured in near capacitor.
    After that the console works ok, but i find 2 problems, one I dont know it it is normal, the second problem I know is not normal.
    BQ24193 charging chip heats a lot when charging, reaching near 70 degrees, with console open, with no disipation from the console chasis, so I dont know if it is normal. By the way, it charges ok, but would like to know if it should heat so much (meassured with a thermal camera and i can touch it because it burns)
    The second problem is that if I turn it off, not standby, fully off, the battery drains alone in maybe 1 day, if I use the thermal camera again on it, I can see that the M92t36 chip heats a little, maybe 10ºC more than the rest of the console, no other hot spots found, that chip maybe reachs 25 or 30 degrees when the rest of the console is at 15 degrees.
    What could it be? maybe any resistance or capacitor "shorted" in some way??? A bad M92t chip?
    If I leave the battery alone, disconnected, it doesnt drains and when fully asembled, the battery seems to hold playing time, but it drains at night fully off.
    Thanks a lot for any help
  • Technomancer
    • Nov 2021
    • 20
    Re: Nintendo Switch drains battery in 2 days when off
    I have a switch that has the same issue that I haven't gotten around to looking at. Back when I was doing digging on the top of repairing these things, one user who was pretty good at fixing them mentioned a fuel gauge IC that would go bad and possibly cause issue with the battery draining. I don't really have any more info than that but hopefully it gives you something to look into. A quick Google search says it's the MAX17050 chip.
    • foshland
      • Jan 2017
      • 122
      • Spain
      Hi, thanks a lot, in these days ill look about it and ill try to replace the battery with my bench supply, so I can see the miliamps it takes when turned off now and after cleaning or removing that MAX, thanks a lot again, will post my findings
      • Moq
        • Mar 2022
        • 3
        • Argentina
        I have the same issue with my repaired Switch. Exact same, overheating when in sleep mode and battery drainning overnight.
        Mine had a damaged M92T36 and woulnd't charge, when it was repaired they didnt change the IC but some capacitor.
        Did you manage to solve the problem?
        • foshland
          • Jan 2017
          • 122
          • Spain
          Hi, not yet, it is sitting in the shelf for next week or so, ill post if I find something new
            Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
            This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-06-2024, 05:30 AM
          • taso
            N. Switch HAc-10, no resistance on usb C 6 & 19 pin (D+), console not charging
            by taso
            Hi everyone:
            Anybody know anything about a N.switch without resistance in 6 & 19 pin (D+) in USB C conector? This is a HAC-10 board, all conector pins al good. Console runs ok but charging in very very slow 005 mAp.
            Thx!!!...
            07-15-2025, 12:37 PM
          • tommy97
            Nintendo Switch Oled - Joy con charging
            by tommy97
            I'm having an issue with a Nintendo Switch OLED that suffered liquid damage. After a full cleanup and replacing the Joy-Con rails and joysticks, everything was working fine for about a week. However, now the Joy-Cons won't charge or connect again.
            I tested with a second set of Joy-Cons, and the issue persists. Measuring the voltage on the connector shows 3.7V instead of 5V, which I believe should be the correct value.
            Any insights or suggestions on what could be causing this?
            03-17-2025, 06:30 AM
          • estabilito
            Nintendo Switch Oled dead
            by estabilito
            Hello, i bought dead nintendo switch oled.
            after plugging charger with amp meter device shows 5v and 0,0 or 0,02 amperage draw.
            I inspected motherboard and someone tried to reflow or replace m92t36 and didn't do it well, i resoldered it proper and find that usb-c fuse was blown too(replaced it).
            After this device started to draw 15v and something around 0,48 but only for few seconds after this returned to 0A draw.
            I tried to plug motherboard without battery - shows 15 0A and when charger was pluged i put battery back in then console started to charging battery but stuck...
            05-07-2024, 03:48 PM
          • CraigR
            Nintendo switch drown victim help needed
            by CraigR
            Nintendo switch with some water damage came in and I need a picture of components and values on both sided down by the fuel gauge ic. If anybody would have a pic or could help me out it would be greatly appreciated!...
            08-13-2024, 12:22 PM
