PS One (SCPH-101) disc reading issue
  • Technomancer
    • Nov 2021
    • 20
    Hello folks,
    I have an SCPH-101 console with a bit of a strange issue. The unit doesn't want to read discs. Now that in itself isn't all that strange as the lasers in these things often go bad. What is strange, however, is that when I take the laser assembly from this unit and put it in a known working console, it works just fine. Also, when I try the laser assembly from the working unit in this broken one, the disc spins and the laser moves up and down but doesn't really do much else.
    One thing I noticed is that it doesn't want to read even audio CDs until I turn the impedance down on the laser pot. Then it will start to read them but with garbled audio. Turning the impedance down even more will get the audio CD to play just fine and it will sometimes even read the PlayStation discs. I also took some voltage measurements from the output of the laser pot (before adjusting the impedance) and it read the same as what I had gotten on the working unit. Obviously I don't really like adjusting those due to the possibility of damaging a perfectly good laser but this problem has me a bit stumped.
    Any idea as to what might cause a laser to work on one unit but not another?
    *edit* Forgot to include that I can get the unit to read audio CDs and PS1 games with the pot set at around 600ohms.
    • 31294
    Re: PS One (SCPH-101) disc reading issue
    turn the console upside-down and try it.
    in the original playstations the surface that the laser moved on could wear down and make the laser drop.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      Interesting... I'd never would have thought on that.
        • 31294
        early lasers had hard plastic (not hard enough),
        newer ones had a metal rail added.
        i actually fixed one by putting a thin layer of epoxy on it!!!!!
        • petehall347
          • Jan 2015
          • 4450
          i used to simply play an audio disc then it would load games . no idea why it worked but it did .
          • Pfudaniel
            reading EC with svod4 Lenovo NM-D271 issue
            by Pfudaniel
            Hello, im trying to read the EC of lenovo NM-D271 butthe files come up empty after read.
            Im using pinout provided from online database made by Adytia.
            Pin detection is succesfull and i read in 384 size.
            I was hoping to have some help to get the EC read succesfully. might be a pinout issue ? if anyone got more info on this id love to hear it.
            Thanks.
            03-29-2025, 03:04 AM
          • nervous_capybara
            Repairing the Hitachi DA-6000 CD player
            by nervous_capybara
            Hello everyone !
            I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
            Feel free to share your experience if you ran into other issues.
            DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
            CD tray would not come out of the player
            I could hear a motor spinning inside the player but the CD tray would not come out.
            Turned out that the issue was the CD tray belt that aged poorly and began to...
            11-05-2025, 03:11 AM
          • Xabi
            Pioneer PD-F1007 CD player not reading
            by Xabi
            Hi guys, I need some help with a CD player. It is a pioneer PD-F1007
            The issue is that it doesn't play any disks. The disk gets loaded, spins up, but it doesn't actually plays. Just keeps spinning until I stop it.
            If I put in the CD the wrong way, it will eject it quite quickly, so the unit at least understands that a CD is in and if it's in the correct orientation, tries to read it, but for some reason it can't.
            I started with cleaning the lens to be sure, but ofc that didn't help. Also the laser is ligthing up at least, so it's not totally...
            06-19-2023, 03:15 PM
          • Syph1979
            PS5 EDM-031 1216A BIOS Issue
            by Syph1979
            Hi all. First post here, so I hope I'm getting this right and operating in the spirit of things here.
            I've been working on consoles for a while now. Always learning and trying new repairs, but I have one that has been stumped and I wondered if anyone with more experience could help?
            I picked up a PS5 from eBay recently. It was described as not having the disc drive, but it was also a no power unit. On testing it was clearly an issue with the supply (no 12v), so I replaced that and then when I inserted the power lead, I got 3 beeps. So far, seems all related. As I was...
            09-25-2025, 05:48 AM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
            🛠 Original Issue
            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
