reading EC with svod4 Lenovo NM-D271 issue
  • Pfudaniel
    • Feb 2021
    • 91
    • Netherlands
    Hello, im trying to read the EC of lenovo NM-D271 butthe files come up empty after read.
    Im using pinout provided from online database made by Adytia.
    Pin detection is succesfull and i read in 384 size.
    I was hoping to have some help to get the EC read succesfully. might be a pinout issue ? if anyone got more info on this id love to hear it.
    Thanks.
  • peste
    • 13661
    • ROMANIA
    Thanks.
    post S/N, full name and model, TYPE,etc.
    read the forum rules..
    https://www.badcaps.net/forum/troubl...ore-posting​
    • volinakis
      • Jan 2021
      • 2874
      • N/A
      Thanks.
      "pin detection"? just choose NUVOTON in mode of programmer, power on motherboard and hit Read ID. then config nuvoton, choose 384kb and hit Read
      • Pfudaniel
        • Feb 2021
        • 91
        • Netherlands
        Excuses Mod, and thanks for correcting.
        lenovo L14 gen2
        NM-D271
        HL4A0
        • Pfudaniel
          • Feb 2021
          • 91
          • Netherlands
          Thanks for answering. “Power on motherboard” as press power button and turn laptop on?
          • volinakis
            • Jan 2021
            • 2874
            • N/A
            no, just plug in the charger.
            • Pfudaniel
              • Feb 2021
              • 91
              • Netherlands
              I have battery disconnected, plug in lenovo 65charger and followed steps. But still empty read files
              • Pfudaniel
                • Feb 2021
                • 91
                • Netherlands
                Like this
                • volinakis
                  • Jan 2021
                  • 2874
                  • N/A
                  Like this
                  set programmer for 1.8V. I don't know why but setting for 3.3V gives errors, even SIO is powered from motherboard and not programmer. Check again if you set the ribbon cable in right position with a multimeter, is tricky for lenovo.
                  • Pfudaniel
                    • Feb 2021
                    • 91
                    • Netherlands
                    Set to 1.8v . Ribbon cable sits good, checked with multimeter. But still file read is empty.
                    • Pfudaniel
                      • Feb 2021
                      • 91
                      • Netherlands
                      • volinakis
                        • Jan 2021
                        • 2874
                        • N/A
                        what's the problem is with your laptop? and post serial no. as requested by moderator.
                        • Pfudaniel
                          • Feb 2021
                          • 91
                          • Netherlands
                          i checked video's aswell im doign exactly as it shud but something is not right.
                          bioslock
                          sn: PF-3F4G3X
                          • volinakis
                            • Jan 2021
                            • 2874
                            • N/A
                            bioslock
                            sn: PF-3F4G3X
                            use Maxpower3 solution
                            https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
                            • shahnld
                              Lenovo legion 5 pro startup issue
                              by shahnld
                              Good day Experts
                              I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                              A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                              And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                              08-24-2025, 12:31 PM
                            • riko 656
                              Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                              by riko 656
                              I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                              Laptop Model:
                              • Model: Lenovo Legion Slim 5 16APH8
                              • GPU: NVIDIA GeForce RTX 4070
                              • Main BIOS chip size: 32MB
                              • VBIOS chip size: 16MB
                              Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                              What I Have Tried So Far:
                              1. I
                              11-04-2025, 05:14 AM
                            • db80
                              Lenovo Ideapad 5 15ARE05 startup issue
                              by db80
                              Hello friends,
                              I've been racking my brain over the past few months on the following issue:
                              I have a Lenovo Ideapad 5 15ARE05 laptop that basically works fine as long it starts up at all.
                              If you shut it down, often you hear the HDD still spinning and the Power LED remains on, it only shuts down if you force it (pressing the power button for like 15 seconds).
                              Then, if you want to Switch it on, nothing happens, only the Power LED lights on, nothing else. If you leave it, then after like 30-60mins it turns on itself.
                              I tried all the common alleged „fixes“...
                              07-06-2024, 05:58 PM
                            • coasterghost
                              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                              by coasterghost
                              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                              System Hardware:
                              Processor: AMD Ryzen 7 PRO 5850U
                              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                              09-08-2025, 10:46 PM
                            • totof
                              Lenovo Ideapad 3 15ALC6 motherboard issue
                              by totof
                              I have a Lenovo Ideapad 3-15ALC6 computer that I'm trying to repair.
                              Initially, the computer wouldn't start, and there was no power consumption from the charger. The board itself is reference HS261&HS561&HS761 NM-D521 rev 3.0, where you can find the schematic and board view here: https://www.badcaps.net/forum/troubl...-hs761-nm-d521
                              When I opened it, I noticed three burnt components near...
                              10-26-2025, 10:27 AM
