Original PS4 BLOD after replacing HDMI port.
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Hi, ill try to keep this short. I got my hands on a PS4 with a mangled HDMI port and assumed that it would be an easy fix. before the replacement it booted up fine (white light) however after replacing the port it booted up fine for 2 times and then after plugging in an HDMI cable and turning on the console to check whether it had video out it never booted again, even after unplugging the cable. now it gets stuck on the blue flashing light and after 25-40 seconds it pops out the disk (if one is inserted) and shuts itself off. Upon investigating i found that the capacitors near the HDMI port are all shorted and so are the ones close to the APU (although the ones close to the APU might always read this way not sure) all the data pins and power pins on the new HDMI port seem to also be shorted to GND, visually they do not look shorted however im new to SMD soldering. I definately heated the board for way too long to remove the old port as the Pcb got somewhat charred (maybe this killed the HDMI encoder and shorted everything?) i fail to understand how the PS4 has gotten the BLOD as a short would usually result in the ps4 turning off almost instantly not 25-40 seconds.
    Any ideas or help would be incredibly appreciated. Thank you
  • BOBLibya90
    • Apr 2020
    • Libya
    Re: Original PS4 BLOD after replacing HDMI port.
    hi Bro
    first get to know that BLOD is not related to Hdmi problems
    can you first Post A high resolution pictures from your work on that board ?
    diffently there is short between pins during the rewrok of that HD
    and as a start
    desolder the hdmi port first and clean the pads
    then test the traces again from Pin 1 to 19
    • Gjackson
      • Aug 2021
      • 134
      • Malta
      Thanks for the reply!
      Here are some photos, i do not own a microscope so this is the best that i can do :/
      Could a short fry the APU? as I think the BLOD was brought on by something i did for sure, too much of a coincedence to not be. The black marks in the pictures is charring from overheating..
        • Jul 2011
        • 6070
        No this is flux residue and needs to clean off with flux remover or something similar you might have to rub it with q-tip
        • Gjackson
          • Aug 2021
          • 134
          • Malta
          Hi, ive already tried removing it with a qtip and some alcohol but it doesnt go, is flux residue conductive?
          • lotas
            • Jan 2016
            • 4808
            • Russia
            Take off this screen and see what is there with the components, there is also the hdmi controller, if the controller is not working (overheated, in a short circuit), then there will also be BLOD.
            • Gjackson
              • Aug 2021
              • 134
              • Malta
              Thank you, I will try removing the shield. I will check the 4 filters and then remove the IC if those seem fine. If the short goes away it is safe to assume that it is the IC at that point? of course I will check my soldering on the HDMI port first..
                • Jul 2011
                • 6070
                It might be depending upon what formula that was used
                Then get some flux remover spray will remove it
                One note of interest you can take an ice pick and very gently scrape the the flux area until it flakes off but do this carefully around circuit board traces or you will damage the traces
                • Gjackson
                  • Aug 2021
                  • 134
                  • Malta
                  Update: I found multiple shorts on the HDMI port due to my crappy soldering.. I hope I haven't fried the Encoder IC but there is little hope. I will attempt to fix the shorts and continue from there. Thank you all!
                    • Jul 2011
                    • 6070
                    Just make sure that you use the correct soldering iron tip and the correct temperature settings and the right flux and solder and take your time and do not get in a hurry
                    • RossMoodley1967
                      LG LCD TV HDMI PORT FAULTY
                      by RossMoodley1967
                      LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
                      02-28-2024, 08:38 AM
                    • survivalbloke
                      PS5 - no video but hdmi port looks ok
                      by survivalbloke
                      I'm a little green when it comes to consoles. I've done a fair amount of hdmi port replacement but not really any diagnostics. I've got a PS5 here which powers up but has no video output. I've also tried to boot to safe mode, also with no video. The hdmi port does not look damaged.
                      Where do I go from here? Thanks!
                      **UPDATE** I take that back. The external part of the port looks fine, but look at the pins to the mobo. Those pads are ripped off. How does this happen when the feet of the port are still sturdily soldered to the board?
                      **UPDATE 2** The pads were...
                      04-12-2023, 03:29 PM
                    • Robby-Gr
                      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                      by Robby-Gr
                      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                      Additional issues:...
                      09-27-2025, 12:02 AM
                    • amuse619
                      Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                      by amuse619
                      Hello!
                      Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                      Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                      08-14-2024, 01:22 PM
                    • bulkchart32
                      are these caps good for replacing the ones in front of the cpu/gpu on an original xbox?
                      by bulkchart32
                      nichicon
                      1500 µF 16 V Aluminum - Polymer Capacitors Radial, Can 8mOhm 2000 Hrs @ 105°C
                      are what​ i used because i had heard the voltage doesn't matter as long as it is more than the original cap. i'm now reading that high voltage may make the cap's esr too high. is this a good cap for replacing those oem ones?
                      05-14-2025, 02:12 PM
