PS3 CECHC04 no power
+ More Options
Posts
  • N3Star
    • May 2021
    • 32
    I have 2 mobos - both COK-002, one with YLOD and without NEC/TOKINs on one side (if needed any comparison measurements I also have working COK-002) and one that literally doesn't do anything. So far I checked roughly capacitors on both sides, none seem to be shorted. Another thing are voltages coming to CSW-001 board - on the connector seems to be no sign of 1.6V, 3.3V or 2.8V (comparing to YLOD mobo), but 5V coming from PSU is present, I am unable to check if 12V is present on mobo as it "activates" when PSU is on. Also resistances on RSX caps seem to be quite low - less than 2 Ohms, but if it powers on I will be able to check syscon errors.
    • 31117
    Re: PS3 CECHC04 no power
    well if one works cant you test all the psu's in it?
    as for the damned prodalizer caps, i think they temporarilly heal if you heat them - thats why people used to think reflowing was the fix - it wasnt but the heat was healing the caps!!
    (temporarily)
    btw, you probably already know this, but you can power them up without the fan if you have alternative cooling - they amazingly arent monitoring the fan rpm!
    • N3Star
      • May 2021
      • 32
      Sorry I didn't mention that, I will replace both RSX and NECs on both (at least on one mobo).
      Yeah, as You mentioned, having just one failure point being quite easy to replace NECs would be perfect, but unfortunately in most cases for reliable operation RSX has to be replaced as the balls and glue holding substrate and silicon core are damaged. I somehow got my hands on CECHH mobo with 90nm RSX that has 25days power-on-time and less then 500 cycles so when I will feel confident enough in my BGA soldering skills I will try to replace original chip. Of course, thermal cycles and time aren't everything, but on used boards I have to rely solely on them. You also can try doing same as Sony did for refurbs - replace old RSX with 40nm one, but it needs some other microchip or so i read. As for PSU, I don't even have the PSU that came with them, I just use known good CECHE PSU for all testing. NECs unfortunately don't cause power loss, they just cause YLOD and syscon error, if I recall correctly A0401002 error code.
      I didn't know about the cooler though, good to know. Maybe liquid cooled BC PS3 would be a good project in the future
        • 31117
        if the nec's short, you dont have the core voltage for the main chips - it shuts the buck convertor down
        • N3Star
          • May 2021
          • 32
          I measured resistances on: (probes alone shorted - 0.7Ohm, all measurements on the backside)
          failed NECs on SEM-001 BE - 4.2Ohm, RSX - 3.5Ohm,
          second failed NECs SEM-001 BE - 8.1Ohm, (3 NECs replaced with 7 in total 470uF tantalums, still not working) BE - 7.7Ohm, RSX - 2.2Ohm,
          failed RSX SEM-001 BE - 5.4Ohm, RSX - 3.7Ohm,
          second failed RSX SEM-001 BE - 3.3Ohm, RSX - 2.3Ohm,
          working SEM-001 BE - 4.5Ohm, RSX - 2.6Ohm,
          second working SEM-001 BE - 3.3Ohm, RSX -2.5Ohm,
          third working SEM-001 BE - 5.0Ohm, RSX - 2.8Ohm,
          working DIA-001 BE - 5.1Ohm, RSX - 4.2Ohm,
          failed RSX COK-002 (2 RSX NECs present) BE - 3.2Ohm, RSX - 3.2Ohm,
          no power COK-002 BE - 2.1Ohm, RSX - 2.7Ohm
          So, you might be actually right, CELLs caps are only ~1.4Ohms, I've heard that NECs below 2Ohms might cause trouble, tomorrow I will try and piggyback 2 or 4 these 470uf tantalums and check after that
          • N3Star
            • May 2021
            • 32
            Although I managed to repair one of the failed NECs SEM-001 - second after reading syscon errors shows problem with RSX - same method didn't help with the mobo in question. I also tried just heating the caps up at 200 degrees @2mins each, no positive resault either.
            • N3Star
              • May 2021
              • 32
              NECs most probably will be a cause of YLOD somewhere in the future, but for now there is 1.8V, but no 3.3V on the mobo. Which IC does the 12V -> 3.3V? I guess it is IC6003 (MB39A116), but maybe there are more converters I need to check before I go and fight with hot air.
              • N3Star
                • May 2021
                • 32
                I somehow managed to "repair" it by changing IC6005 from the SEM-001. Why in quotes? Syscon tells me that there is a problem with RSX, as expected. At least its last owner kind of took care of it, as there was no sign of errors up to 2016 and it has >2000 cycles and >4500hours on it.
                  • 31117
                  what is ic6005?
                  • N3Star
                    • May 2021
                    • 32
                    It's a SB_5V -> SB_3.3V voltage regulator, NCP511SN33T1G, successfully replaced by TK63133SCL-G. Look here, page 23, there are two 3.3V converters, one on each side, but only IC6005 is enabled on stand-by, on schematic its output is marked as +3.3V_EVER, second one is enabled by IC6004.
                      • 31117
                      nice and simple then
                      • ChaosLegionnaire
                        by ChaosLegionnaire
                        09-13-2022, 09:02 AM
                      • Cerberuska
                        Mobo MSI B550-A PRO password popup
                        by Cerberuska
                        Hello guys,
                        I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                        BIOS I updated to last one.
                        any suggestions?
                        And same thing for two different 5600G, and yes, MoBo supposed to support it.
                        Thank you...
                        11-10-2024, 01:23 PM
                      • mrsith
                        Dell G3 17 3779 - no display after mobo replacement
                        by mrsith
                        Hi guys,
                        I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                        Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                        04-30-2023, 05:11 AM
                      • Ibod
                        Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                        by Ibod
                        HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                        With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                        Not sure where to go from here ?
                        Is the PSU at fault or is the mobo causing the problem
                        Look forward to any help :-)
                        If I plug the 24...
                        02-08-2023, 11:00 AM
                      • Felipe_Serra_83
                        Dell Inspiron 14-5448 - fan turns off and mobo keeps running
                        by Felipe_Serra_83
                        Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
                        So I got this Dell Inspiron to play with.
                        No charger, so I connected to my bench PSU.
                        The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
                        ------What it did (and didn't do)------
                        1) I turned it on and it powered on. Powered down in 2 seconds by itself.
                        2) Removed RAM, changed slot. Same...
                        04-04-2024, 12:39 PM
