sanyo se in ccfl inverters
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    been seeing a bunch of these bad in ccfl inverters.
    there are 4 paralell 100@25v
    they go high esr/open
    they are the common sanyo green/gold.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: sanyo se in ccfl inverters
    shit what else is next.....rubycon?
    what you think....fake sanyo?
    • arneson
      • Sep 2005
      • 1267
      To some who try fixing these inverters big and small, be aware of not only badcaps but also the very small fuse on the boards.
      Jim
        Design of CCFL Backlight Inverters with Frame & Bar Cores
        Summary
        Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
        The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
        The frame and bar ferrite cores, described in this brochure, are especially designed...
        10-07-2024, 04:26 AM
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • mikey5791
        Help on Samsung Syncmaster T220 dead ccfl lamp
        by mikey5791
        This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
        Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
        10-18-2020, 03:17 AM
      • cj_reha
        Mystery 80s Sanyo cap - perhaps polymer?
        by cj_reha
        Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
        01-06-2023, 09:24 AM
        Protection Pin Shutdown in PWM Controllers & LCD inverters
        How to remove the protection of the inverter - several ways to protect shutdown in popular PWM controllers, LCD inverters.
        When repair and diagnosis, it is often necessary to check the individual
        inverter circuits - power converter lamps illuminate the LCD panel.
        Carry out the necessary measurements is sometimes not possible, the
        generation of breaks for various reasons, for example because of the
        imbalance in the loads.
        Together, artists and researches different options for the repair of
        conferences were blocking inverter protection in order...
        11-06-2024, 04:18 AM
