Kenwood Food Processor A532 - Magic Smoke
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    My Mums food processor made a couple of loud bangs and emitted quite a bit of magic smoke a week or so ago. I took it apart to have a look, and as you can see on the attached photos, one of the capacitors on the circuit board blew open.
    There is another capacitor on the board, but it's slightly narrower than the one that blew open. The still intact one is about 5mm thickness, whereas the one that blew is 7 or 8mm thick, so they're probably not the same part.
    Can anyone tell me what I need to look for as a replacement? Is it a special type of capacitor?
    Also, is it likely it blew because of another problem, or age-related? And if age-related, I should probably replace the other one too.
    The unit is probably 30-35 years old, and other than a bit of discolouration of the plastic, still works ok, and yes, it does still work with that blown component, though I only ran it for a few seconds. The bowl plastics still look good with no cracks or breaks on them either, so it would be nice to see if I can revive it.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Kenwood Food Processor A532 - Magic Smoke
    Required viewing: EEVblog #1183 - RIFA Madness (Schaffner Repair)
    It is a common failure, you just need to replace them with X2 capacitors with the same ratings, in this case minimum 250VAC and 100nF (0.1uF)
    I actually buy Rifa even as replacements, others may want to stay clear, it is just personal opinion.
    Elfa has them: https://www.elfa.se/en/x2-capacitor-...9t0/p/11040241
    • tmcw
      • Oct 2010
      • 382
      • Ireland
      Thanks for the link, interesting viewing, I'd never come across this type of capacitor before, and I see the problem of them is rife in electronics of similar vintage, in lots of stuff from BBC Micros to Yamaha keyboards.
      I did have a search around after viewing that, and actually found a site that used to sell a replacement circuit board for the food processor, and from the picture they still have on the page, I can see that the cap that blew open on ours is a 0.15uF X2, not sure if 0.15 vs 0.10 would make much of a difference, but probably best to go with the same value.
      https://www.4kenwood.co.uk/obsolete-....pl?pid=661131
      A little further searching and I found some sellers on etsy and ebay selling repair kits for this generation of food processor, with the 2 caps, a resistor and a triac.
      https://www.etsy.com/nz/listing/5862...p400-processor
      https://www.ebay.co.uk/itm/152615176709
      I probably have the resistor, and will have a rummage around the parts boards for the caps and triac. It's good to know that the food processor might have a bit more life left in it, if I can work out how the springs under the selection buttons are supposed to be arranged. I was taking the whole unit apart to give it a good clean, and 5 or 6 small springs popped out all over the place when I got in there.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8705
        Hooray for another Rifa!
        Apparently all the equipment with Rifas made in the 1980s are about ready to blow up. I've got a few that I should change out but too lazy to. Namely my Tektronix scopes use them and they're about ready to blow too I'd think.
        As there are people who are willing to use Rifas and it seems only the 1980s Rifas blow up, perhaps they got their act together after Kemet took over...
        • seanc
          • Nov 2008
          • 1319
          I bought a Kenwood Chef 901 a few years ago for a whopping £17 - fully working. I'd read something before I bought it that referenced the Rifa capacitors were a ticking timebomb. I found a repair kit including replacement caps and triac's on eBay. Replaced those for preventative maintenance and it continues to work a treat. Mum's old 901 still exists somewhere with original caps!
          • tmcw
            • Oct 2010
            • 382
            • Ireland
            I hope you're going to change the caps on your Mums 901.
            My Mum has the older A701, still going strong. I wonder if there are any caps in there ready to go bang?
            Parts for these old Kenwoods are going for mad money.
            • jaifraic
              Allen & Heath Xone:92 (DJ mixer) no output on main out & magic smoke
              by jaifraic
              I have a DJ mixer here, an Xone:92 by Allen & Heath.
              When I turned it on, only magic smoke came out, so I turned it off again.
              An optical troubleshooting has brought me quite fast to the
              source of the smoke: two resistors look disproportionately black (see first pic)
              Those are R73 and R74 on the master PCB. See second pic for the corresponding page of the service manual.
              Behind those resistors are five OP-Amps (U3, U4, U5, U6 and U9).
              My thought is that one (or more) of those is defective. I've measured...
              03-15-2022, 12:32 PM
            • DrDos
              Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
              by DrDos
              Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
              08-08-2025, 03:16 AM
            • Mark R
              The Overseas Only Kenwood Model KR 790
              by Mark R
              I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
              The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
              09-23-2025, 08:27 PM
            • shelby5041
              old trs80 computer lots of smoke
              by shelby5041
              hi
              my neighbor gave me an old radio shack trs80 model3 computer...it was stored in his attic for 35yrs...i powered it on and after 5min lots of smoke was coming out of computer...i took it apart and didnt notice any fire evidence so i assume a cap split open...i looked around only saw 1 suspect part...see photo...could this be the smoke?
              07-14-2024, 05:11 PM
            • sansonet
              Diode ID (Food Processor Switch)
              by sansonet
              I have a small food processor with two speeds, but it doesn’t handle long use very well and tends to overheat. I guess I pushed it a bit too far this time because it started smoking. After letting it cool down, I tried using it again, but only the second speed is working. The motor seems fine, but I really want both speeds to work. When I opened up the switch cover, I found a component that was completely burned out—probably a diode. I want to replace it, but I'm not sure what type I need. It’s next to the switch that’s still working, but the one on the left for speed "I" isn't...
              10-15-2025, 11:18 PM
