Diode ID (Food Processor Switch)
  • sansonet
    • Nov 2013
    • 245
    • US
    I have a small food processor with two speeds, but it doesn’t handle long use very well and tends to overheat. I guess I pushed it a bit too far this time because it started smoking. After letting it cool down, I tried using it again, but only the second speed is working. The motor seems fine, but I really want both speeds to work. When I opened up the switch cover, I found a component that was completely burned out—probably a diode. I want to replace it, but I'm not sure what type I need. It’s next to the switch that’s still working, but the one on the left for speed "I" isn't working at all.
    • 31314
    need to see the other side of the switch board to see how it's wired.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8353
      Probably just a standard flyback diode to protect from damage due to inductive spikes when actuating the mechanical switch. That’s all that is.
      • sansonet
        • Nov 2013
        • 245
        • US
        This is the back side, and I have marked the burned diode.
          • 31314
          oh shit - i think i see the (design) problem!
          it only has 2 wires to the pcb right?
          it's switching direct for full speed and switching through a rectifier diode for half-speed by blocking half the sinewave.
          great trick with lamp bulbs, but motors are power hungry!
          you need a rectifier diode preferably 1000v and as high a current as you can fit!
          maybe a 1N5408
          • sansonet
            • Nov 2013
            • 245
            • US
            Yes, it's just two wires. Thanks for clearing that up! I'll order the diodes. Should I skip the low speed setting unless I really need to use it? I've been running it at low speed more often to keep the motor from overheating too fast.
              • 31314
              it's a 3A diode so it should take a lot more stress than that glass one that was probably only 1A.
              • sansonet
                • Nov 2013
                • 245
                • US
                I think I found the right ones on an old PC power supply. Is it okay to use them? Also, probably a dumb question, but how should the grey stripe be positioned when I solder it?
                  • 31314
                  good question.
                  luckily in this i dont think direction matters.
                  • sansonet
                    • Nov 2013
                    • 245
                    • US
                    good question.
                    I just fixed it; both speeds are working now! Thank you!
