Nintendo Switch - Joy Cons won't charge, fan not spinning
  • wyga
    • Dec 2020
    • 16
    So, I've got the Nintendo Switch on the bench.
    Issue:
    * Won't charge up the joy-cons
    * Fan is not spinning.
    * Battery discharges very quickly
    * Serial number from joy-cons unavailable
    I have located the shorted diode near the cpu fan connector. Apparently that is pretty common issue. Once the diode has been removed the short is gone.
    Apparently it is going to work fine right know without the diode.
    But... I understand that this diode someone of course put there for a reason. Problem is I don't have a donor board.
    Do you know maybe what are the diode values?
    Anyone had that problem before?
    • Jul 2011
    • 6070
    Re: Nintendo Switch - Joy Cons won't charge, fan not spinning
    You could use a 1N007 diode ( or equivalent in a surface mount device) in place of the one that is shorted just make sure you have the polarity is correct when you install it or you will have what appears to be a short but it because it installed backwards
    I have seen this type of diode which has the markings ( 7 ) I have found some of them shorted before and I just put a 1N007 in it place
    • wyga
      • Dec 2020
      • 16
      Thanks a lot!
      I will make sure that polarity is correct.
      • BMCappelletti
        • Nov 2021
        • 154
        • Brasil
        Hello.
        Sorry to resurrect this old thread.
        But what if the Nintendo Switch has the same issues (fan not spinning when device reaches 65C and joycons not charging) but it's already a new revision, without the diode on the board?
        What could be causing the issue?
        • sansonet
          Diode ID (Food Processor Switch)
          by sansonet
          I have a small food processor with two speeds, but it doesn’t handle long use very well and tends to overheat. I guess I pushed it a bit too far this time because it started smoking. After letting it cool down, I tried using it again, but only the second speed is working. The motor seems fine, but I really want both speeds to work. When I opened up the switch cover, I found a component that was completely burned out—probably a diode. I want to replace it, but I'm not sure what type I need. It’s next to the switch that’s still working, but the one on the left for speed "I" isn't...
          10-15-2025, 11:18 PM
          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 05:30 AM
        • Tomylee
          No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
          by Tomylee
          Sorry for the person who’s going to read all this !
          I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
          While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
          During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
          07-11-2025, 11:52 AM
        • estabilito
          Nintendo Switch Oled dead
          by estabilito
          Hello, i bought dead nintendo switch oled.
          after plugging charger with amp meter device shows 5v and 0,0 or 0,02 amperage draw.
          I inspected motherboard and someone tried to reflow or replace m92t36 and didn't do it well, i resoldered it proper and find that usb-c fuse was blown too(replaced it).
          After this device started to draw 15v and something around 0,48 but only for few seconds after this returned to 0A draw.
          I tried to plug motherboard without battery - shows 15 0A and when charger was pluged i put battery back in then console started to charging battery but stuck...
          05-07-2024, 03:48 PM
        • fab13
          Nintendo Switch lite shuts down after nintendo log and replaced M96T36o
          by fab13
          Hello everyone
          After checking the defective USB-C port and close to a short circuit on the M96T36 chip (8ohm) I have changed both components.
          I specify that there is no other short circuit or heating component(Vu thermal camera)
          First, the problem arises: Error 2101-0001 after the start-up screen ("Nintendo" logo), poor soldering.
          Secondly, I install a new M96T36 and the problem I have is a brief display of the "Nintendo" logo (no short circuit, no sure charge chip, no sure charge port, no sure charge management chip percentage)....
          08-23-2023, 10:54 AM
