Ps3 fat Cechk04 no power
  • sigmeyer
    • Feb 2020
    • 147
    • Serbia
    #41
    Re: Ps3 fat Cechk04 no power
    So thats pretty much ylod... You will need to replace the NEC / tokin caps/// there are 8 on each side.. they are above the cpu and the rsx on each side of the board... This was really tricky for me to do first time , but i got the hang of it... its big capacitors you cannot miss them... look up NEC/ Tokin Cap replacement on google ... and you will find plenty of answers...the way i did it , is take a sharp screwdriver(the one with the pointy tip) and use alot of hot air on them and SLOWLY pry them off ... Keep the air on the pads to clean them up... Be very careful if you are forcing , because you might drive the screwdriver when they pop off and damage something else... but i had 100% success rate with this so dont lose hope. Replace 2 caps and check , and repeat untill the ps3 starts working. There is probably a disk inside the tray too.
    good luck!
    • sigmeyer
      • Feb 2020
      • 147
      • Serbia
      #42
      It might not be that this is the issue tho... but im pretty sure it is... check the voltages first on the main line just in case... it might not be the ylod !
      • Admirality
        • May 2020
        • 80
        • South Africa
        #43
        Thanks for the info sigmeyer,much appreciated
          • 30979
          did you actually connect it to a tv yet?
          • Admirality
            • May 2020
            • 80
            • South Africa
            #45
            Yes stj the green led comes on,fan starts then 2x 3 beeps then red led flashing no video
            • Admirality
              • May 2020
              • 80
              • South Africa
              #46
              You are right sigmeyer there was a disc in the tray
              • Admirality
                • May 2020
                • 80
                • South Africa
                #47
                • Admirality
                  • May 2020
                  • 80
                  • South Africa
                  #48
                  Which are the nec/tokin caps
                    • 30979
                    2R0 122
                    although your seem to be made by nippon-chemi-con.
                    which is something i'v not seen before!!
                    • Admirality
                      • May 2020
                      • 80
                      • South Africa
                      #50
                      Oh thanks stj,i think this ps3 was made here by Sony South africa
                        • 30979
                        unlikely, i think the boards are made in korea by Asus.
                        here is a pdf of what there is to find.
                        you need to replace them with 4 tantalum or polymer 330uf caps
                        it would be worth trying to find which is shorted with a low-ohms meter or maybe an esr tester given the number of them!
                        • Admirality
                          • May 2020
                          • 80
                          • South Africa
                          #52
                          Ok i have an autorange meter,do i have to tes them out of circuit stj
                          • sigmeyer
                            • Feb 2020
                            • 147
                            • Serbia
                            #53
                            Dont bother testing ... They will always show as very low resistance or a short... you should get around 3 or 5 ohms or something like that ... but it doesnt matter... 1 Cap is equivalent of 1200uF ,you can go a bit higher then that... like 1300uF each. Its gonna be unusually difficult ... you'll see when you try
                            • Admirality
                              • May 2020
                              • 80
                              • South Africa
                              #54
                              Ok sigmeyer two of them are 1200μf and the other two are 1000μf,are they 2.5v
                              • Admirality
                                • May 2020
                                • 80
                                • South Africa
                                #55
                                2R0102 and 2R0122
                                • Admirality
                                  • May 2020
                                  • 80
                                  • South Africa
                                  #56
                                  ok i see they are obsolete
                                  • Admirality
                                    • May 2020
                                    • 80
                                    • South Africa
                                    #57
                                    Ps3 has video in AV and plays a game disc but fan is high and shuts down after a few minutes and the ps3 is in demo mode,i must still change the caps,is there anything else i must check
                                      • 30979
                                      that's NOT the caps causing that - bad caps would stop it running.
                                      i dont know about demo-mode, not heard of it.
                                      but the fan is a clue that the temps are too high - did you use silver or carbon based paste when you re-assembled it?
                                      • Admirality
                                        • May 2020
                                        • 80
                                        • South Africa
                                        #59
                                        V1 thermal compound is what i used on the two heat sinks,which is the right paste to use and there are you tube videos about demo mode,i wanted to update it and wouldnt because it is in demo mode
                                          • 30979
                                          i know FSM - factory service mode.
                                          i'll have to look demo mode up.
                                          why did you want to update it?
                                          hopefully so you can hack it with custom firmware like "Rebug"
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • dicky96
                                            Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
                                            by dicky96
                                            Hi guys
                                            I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
                                            If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
                                            If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
                                            03-24-2023, 06:33 AM
                                          • cajoeg
                                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                            by cajoeg
                                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                            02-10-2025, 04:01 PM
                                          • russpall
                                            LG 39ln540v - red light flashes twice, no power to LED driver?
                                            by russpall
                                            Hi there,
                                            I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                            The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                            08-27-2024, 01:07 PM
