Sega mega driveII AV problem
  • playman
    • Jan 2011
    • 252
    I have this SMDII and works fine, wanted to get a better picture from it so I made my own 9 din to
    SCART cable, used a 9din cable that I found laying around, think it had a plug similar to what Samsung note 10 uses.
    Pin 4 had no wires connected to it so I bridged 4 and 5 and shortened the 5 pin.
    I get good picture and sound on the TV but the image is shaking alittle.
    Any idea what could be the problem?
    I used this schematic to make the cable.
  • R_J
    • 9628
    Re: Sega mega driveII AV problem
    How long is the cable? If it is of any real length I would use shielded cable for each of the colors and the audio.
      • 31300
      the 75ohm resistors are wrong,
      get rid of them.
      composite video is 75ohm, not rgb.
      and you dont use them like that anyway - they go to ground.
      you may want to put one in the sunc signal though.
      • playman
        • Jan 2011
        • 252
        It's only 60cm long
        get rid of them.
        Is that schematic correct then?
          • 31300
          it's an improvement.
          • playman
            • Jan 2011
            • 252
            I did those modifications, it still shakes as before.
            I noticed that the SCART ports were differently marked, AV and then RGB.
            When in RGB port it shakes, but when in AV port it's pretty steady.
            I thought this was a RGB mod and therefore should work with the RGB port, right?
            • R_J
              • 9628
              It's likely the sync signal is not compatable with the tv. or it is too low in amplitude or even wrong polarity. What do you mean when you say it shakes? does the picture shake from side to side or shakes up and down?
                • 31300
                https://pinouts.ru/Home/Scart_pinout.shtml
                replace the 75ohm resistor with something higher,
                and put the 75 ohm resistor between sync and ground at the scart end.
                • playman
                  • Jan 2011
                  • 252
                  I took a video of it, was unable to upload a video file so I had to zip it.
                  It doesn't show as well on camera though
                  maybe my wording of it wasn't the best.
                  Sorry but not quite understanding you.
                  There is only one 75Ω resistor in that schematic, or are you talking about the 180Ω resistor that I should make higher? and how much higher?
                  Made another schematic of what I think you were talking about.
                    • 31300
                    that's close, but also put a resistor in series with the sync wire to lower the voltage.
                      • 31300
                      this is interesting:
                      using a cap to change the sync level
                      • R_J
                        • 9628
                        Its hard to tell by that video but it does'nt seem to be a sync issue. looks more like noise in the video signal.
                        • CapLeaker
                          Leaking Member
                          • 8352
                          interesting, almost looks like a cheap unshielded scart cable is used.
                            • 31300
                            well we are stabbing in the dark here.
                            we know what a tv expects,
                            but we have no idea what voltages are coming out of the console.
                            testing should really be done with short wires too - for the reason you mentioned.
                            • playman
                              • Jan 2011
                              • 252
                              The cable is exactly 95cm.
                              The cable is just a 9din to PDMI (I believe) that i found at a flea market, not much of a shielding on it, I think
                              its only the ground that is braided over the inner wires, the cable diameter is 4mm.
                              As you might have guessed i'm just a electronics hobbyist and did not finish much school in electronics,
                              but I do believe I have the basics and I've able to repair many electronics with and without help.
                              I guess i'll just order some 9din connectors from ebay and use a spare scart cable I have here with it, that should remove all
                              doubt regarding the cable and the shielding right?
                              • R_J
                                • 9628
                                That 95cm is long, when you are talking about video signals. Each of the R, G, B, should be using shielded cable, and I would also use a shielded cable for the sync and for the audio. Find an vga monitor cable, cut off the ends, and use it.
                                • CapLeaker
                                  Leaking Member
                                  • 8352
                                  get yourself a quality scart cable first. Backtrack a loong time ago, my scart cables were much thicker than 4mm. Those thin ones are cheap and also perform as such.
                                  • theone111
                                    by theone111
                                    3. Problem: TV shuts down
                                    07-22-2024, 10:36 AM
                                  • Zeonalbasta
                                    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                    by Zeonalbasta
                                    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                    09-13-2024, 01:17 PM
                                  • Gibon378
                                    Problem with stopping audio and video for no reason
                                    by Gibon378
                                    PC Specs:
                                    • CPU: Ryzen 5 1600
                                    • GPU: GTX 1080 Palit JetStream
                                    • MOBO: ASRock ab350 PRO4
                                    • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                    • PSU: XFX 650W (don't remember what model)
                                    • OS SSD: ADATA SP920
                                    • OS: Windows 10 21H2
                                    Problem description:
                                    Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                    11-19-2022, 09:41 AM
                                  • perzyk23
                                    Lenovo T580 - LCD Panel problem - error 0288
                                    by perzyk23
                                    Good morning,
                                    I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                    10-25-2024, 12:42 AM
                                  • lazaro.089
                                    Asus Zephyrus M16 / GU603ZW problem
                                    by lazaro.089
                                    Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                                    CPU: Core i9-12900H
                                    Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                                    Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                                    The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                                    08-26-2025, 06:33 PM
