PS4 loses date/time settings every time
  • CapLeaker
    Leaking Member
    • 8340
    Re: PS4 loses date/time settings every time
    Originally posted by khaled1981
    change cmos battery brother
    Read post #1 again.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      #42
      Read post #1 again.
      Yup - not the solution I'm afraid. We tried that a couple of times in fact
      Wattevah...
      • tomlig
        • Apr 2021
        • 3
        • New Zealand
        #43
        Did you ever find the fault for this?
        I have a PS4 Slim SAD-002 which doesn't retain time/date and does not restart (endless pulsing blue light hanging, no beeps) unless the CMOS batt is taken out and reseated.
        Sounds a bit different to OP unit as that would happily shut down and restart, albeit take itself back to 1970 each time with known good CMOS batt.
        I managed to get mine updated to 8.50 with difficulty (SU-30746-0), but got there with LAN cable and multiple CMOS batt reseats due to the machine hanging rather than restarting, when it tries to restart.
        I have tried to get the RTC synced, but can't get recognised on PSN even though it would seemingly let me create user and login to PSN when unchecking one of the time update options. But, it's not really connected to PSN cos Internet Test throws the 30391-6 on that part (PSN) of the connection test.
        If you got anywhere and can point me in the right direction, appreciate it, and I hope to start trying to trace from the batt
        I was surprised the update to 8.50 took on the machine, I was expecting repeated loop of SU-30746-0
        • Hellstorm32
          • Apr 2021
          Hello!
          I just joined this forum looking for help with an Xbox 360. I noticed this post and decided to lend my game console experience to help with this problem.
          It seems to me that the issues experienced related to this are most often linked to a bad Southbridge IC. This is the large IC with SCEI written on it. The chip part number starts with CXD and if it ends with 42GG then these chips are famous for going bad. This is a ~400 ball bga chip. I have replaced 2 in my time and I know many more technicians that have replaced waaaay more than that. I hope this helps.
          • tomlig
            • Apr 2021
            • 3
            • New Zealand
            #45
            Update on this one, disconnecting CMOS batt is not required to get it to boot IF the machine is left unplugged for 2 hours (maybe shorter, TBA...), and did hold date / time overnight (replaced CMOS batt with an older but seemingly OK one, even tho the one replaced can't have been more than 5 years old).
            It really is struggling with the internet (wired and wifi), and once reported it was connected to PSN, although still threw the CE-30391-6 five seconds in to a game.
            The machine not restarting might be a faulty PSU (i.e. it doesn't reset itself), but I suspect a component somewhere which doesn't tell the PSU something, and then the 2 hour wait is while the PSU completely drains...
            Waiting 2 hours again now to see if I can get a boot + connect to PSN and then leave it on for a few hours to see if the RTC updates, although surely the RTC updates on connection? Well, hard to say....
            • tomlig
              • Apr 2021
              • 3
              • New Zealand
              #46
              Further update on this one. 30 mins of being unplugged will suffice for to allow the machine to restart rather than just pulsing blue power button light
              Also, it will allow a PSN user to log on to the machine when the "Time / Date > Set using Internet > Set Automatically" option is UNchecked / disabled. Then it will allow the PSN log in and the Internet Connection Test says PSN sign in "successful". As soon as that option for automatic time / date update via internet is checked, then it doesn't want to liaise with PSN, won't sign in a PSN user, and reports PSN sign in as failed during internet connection test.
              It is holding the time / date now so presumably the CMOS batt I put in is fine, but how to get the Real Time Clock thing reset now, if indeed that is a problem. Is there a jumper to reset the CMOS I wonder?
              This, coupled with the reluctance of the machine to soft or hard restart / power cycle (unless left unplugged for 30 mins) is the situation. Not sure if the 2 issues are linked.
              • RetroComputingGrotto
                New Toy UNI-T UTi260B - What Settings?
                by RetroComputingGrotto
                I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
                After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
                I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
                09-02-2025, 08:36 AM
              • YG007
                Asus BIOS How To Reset To Default Settings?
                by YG007
                Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
                I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
                06-05-2023, 08:22 PM
              • titomno2
                Gaming Laptop Zephyrus S17 TFT not detected every time !
                by titomno2
                Hi guys,
                I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                Then the screen won't work for a long period of time.
                If I wait 1 or 2 hours it work again most of the time.
                When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                01-19-2025, 08:27 AM
              • i440bx
                Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
                by i440bx
                Hey there,
                I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
                The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
                It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
                As written above, I plugged in a new CMOS cell and checked...
                08-19-2024, 02:28 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
