Aron bs-601 scope issue
  • The_Todd
    • Jul 2017
    • 66
    Hello guys,
    im trying to fix a Aron BS-601 scope but the issue im having is the vertial part is not worki ng properly, whatever signal you put in ans whatecer setting you use the trace is always very thin and flat.
    the problem is the the vertical amp, its only pumpi g out about 12v to the scope with of couse needs to be much more. ive attached the circuit that im refring to, the circuit has all the corect voltages going ito it and q19 nd q20 also have the 120v sitting behind it.
    however about 12v is geting to the outputs
    The exact way this circuit works is a bit beyond my capa bilities but if i coukf get any help it wold be appreciated.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Aron bs-601 scope issue
    The Aron BS-601 is a dual trace 20MHz single timebase oscilloscope.
    Need to back up a moment, so you're saying the signal is "flat" or is it just a line?
    Also there's a vertical position knob, do these move the trace up and down? Both of them?
    As an aside though not quite needed yet: do you have a working oscilloscope to debug with?
    • The_Todd
      • Jul 2017
      • 66
      Helo there,
      mostly flat, if iput it on the lowest voltage division i can get a smalll imagae of thr signal, but where it should take up the screem from top to bottom it ont even go up to the first line. The position knob works a bit, again only moves up and down a little bit.
      Also should mention that both sides are the same, ive done thoughough testimg on the calibration pots with makes minimal diferences and yes i do have a fully working scope to test with
      • The_Todd
        • Jul 2017
        • 66
        I should also mention all the horizontal controls work fine
        • The_Todd
          • Jul 2017
          • 66
          Could i ask as its doing my head in, what is the relation btween Q18 and Q20 (and Q17 Q19) im asumings ones basicly a mosfet controling the full voltage output but whats the other for? Feedback of some sort or perhaps pulling the voltage down...?
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            So the trace stays near the bottom of the screen and you can't get it to go to the top?
            Yeah looks like some sort of complementary drive for slew rate, looks like one of the halves is not working, you're probably looking in the right place.
            • The_Todd
              • Jul 2017
              • 66
              Oh no, stuck in the middle, its doesnt gk uo nor down very far but tbey are about equal, botb up and down outputs are about 12v they should be about 60v
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Okay, THAT's a big piece of information. If it stays towards the center, power supply is working, and both deflection outputs stay at 12V, I'd then look at the bias voltages across that voltage divider tree there - D10 R80 R89 D11 D14 ... are those voltages correct?
                Also what does the scope do in XY mode, does it also not want to deflect vertically?
                • R_J
                  • 9547
                  Does the VERT POSITION control move the trace up and down?
                  • redwire
                    • 3910
                    OP cross-posted here also: https://www.eevblog.com/forum/repair...cal-amp-issue/
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Ah... I was wondering where that 60 volt number came from, looked like it came out of someone's brown gas generator. It is the most logical number however as it is in the middle of the 120V and 12V, but it doesn't necessarily have to be there for the scope to work. As long as the voltages are about equal, the trace will be in the middle. Just need the voltages to differ and somewhat be closer to the 120V mark to make a larger deflection.
                      • The_Todd
                        • Jul 2017
                        • 66
                        Funny you ask that, it actually doesnt move it, it only stretches of shrinks the signal slightly. doesnt move it at all
                        • R_J
                          • 9547
                          It looks like you should have -8 volts going to the center of the vert. position control, That shouuld change the bias on q29 and q30 moving the trace up or down. You say you have all the voltages but where did you check them? they may be at P3 but do they get to get to where they should. There are a number of coils in the voltage lines, make sure the voltage is on both sides of them and one is not open.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            There are two vert position knobs and the impression is that neither apparently work, so I'd imagine the fault is in some common stage after those controls, hence suggesting something wrong with the power/bias of the final amplifier... but wondering what other controls have effect on the trace just to make sure.
                            BTW, once you determine both channels behave identically, test with just one channel, that would be a PITA if one has to deal with the chop/alt signal... heh.
                            Looks like Q15 is identified wrong in the schematic, looks like it should be 2SA836 PNP in the BOM but it's written as 2SC458 NPN there... The (lack of) symmetry is bothering me...
                            • The_Todd
                              • Jul 2017
                              • 66
                              Here is a pic of the signal the best i can get it, thisis a .5v test signaL
                              • The_Todd
                                • Jul 2017
                                • 66
                                and thanks for your help guys, ill Be gettjng back into it later this arvo
                                • petehall347
                                  • Jan 2015
                                  • 4426
                                  • United Kingdom
                                  pull out red knob to calibrate
                                  • R_J
                                    • 9547
                                    Even with no input signal you should be able to move the trace "position" from the center of the display up or down close to the top or bottom of the screen.
                                    If both inputs act the same, that should eliminate the front ends/inputs
                                    • The_Todd
                                      • Jul 2017
                                      • 66
                                      already tried makes litter difference, same for both sides.
                                      • R_J
                                        • 9547
                                        The fact that you get a waveform at all is a good sign. too bad you don't have a scope to trace the signal
                                        Check some of the voltages on the vertical board and see if something is missing or a voltage that does'nt look right, I see a few voltages listed on the schematic so check them first
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • Alimash
                                          op amp circuit function?
                                          by Alimash
                                          I am repairing a ups which doesn't turn on ,it has the following ICs:
                                          SG3525 used to drive inverter mosfets.
                                          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                          A LM358 and TL074 for control mechanism and of course the uController.
                                          The SG3525 is shutting down every time the ups is turned on.
                                          I want your help to know the function of LM358 and TL074 in the system.
                                          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                          07-31-2025, 07:45 AM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          šŸ›  Original Issue
                                          āš ļø New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
