Bad heating element, or something else ?
  • guix
    • May 2018
    • 25
    • France
    Hello!
    I have a problem with a multi function electric oven Whirlpool MT66 which is at least 10 years old, it can do microwave, grill, and "pulsed heat".
    When I use this "pulsed heat" mode (a fan with a circular heater at the back of the oven), it will trip the RCD, but not really randomly, so I doubt that it's the heating element!
    Apparently, I can repeat this scenario indefinitely: I preheat at 200°C, or 250, for 10 minutes... When countdown reach 0:00, RCD trips. I reset the RCD, insert food in the oven and turn it on again at 200 or 250°C, now it will trip the RCD every ~2-3 minutes (the hotter, the quicker), and the interval between each trip is so constant that I could predict, within 10 seconds, when it was going to trip.
    Then finally, when countdown reach 0:00 and my meal is ready, this time it will NOT trip the RCD but ends normally..! But I did not test this last part carefully, because generally I don't bother turning the oven again for the last few minutes, in case it could trip again at 0:00, I prefer to not attempt...
    So, I'm not sure but I think it's more a problem with an electronic component like a relay or transistor, or maybe a thermostat..? I'm not too bad at electronics so I'm not affraid of opening the case, I know I must not touch the big capacitor, etc, in fact I opened the back and checked the heating element with my multimeter and it looks fine... I think! But I will wait to read your answers before opening the entire thing.
    Other than that, every other function of the oven, grill, microwave, plate rotation motor, fan on the back, buttons, display.. everything else than "pulsed heat", works great since so many year... I like it so much, so I would like to keep it and repair it if possible.
    The RCD (Merlin Gerin Multi 9 ID, 40A, 30mA) begins to show mechanical issues, when it trips, sometimes I have to try 3-5 times to get the lever to lock in the ON position.
    Also, I know I shouldn't have done that because from what I read, it's EXTREMELY DANGEROUS, DO NOT ATTEMPT THIS AT HOME, IT CAN KILL YOU, but I tried to remove the Ground wire from the plug of the oven, and yes the issue does not appear when I do this, the oven can run at 250°C for hours.
    What do you think it could be? If you are convinced that it's most likely the heating element that is failing, how do you explain the non randomness of the scenario above?
    Thanks in advance to help me save this oven!
  • R_J
    • Jun 2012
    • 9625
    Re: Bad heating element, or something else ?
    It could be that the heating element is shorting inside as the outside of the element is at ground. It can happen as the element inside heats up, expands, and shorts to the elements tube. I don't know how you can be 100% sure, If there is a way to remove the element mounting screws to isolate the element from ground that would tell you if it shorting internally. also inspect the element sometimes the outer tube of the element will show where it was shorting,
    By temporary removing the ground that would suggest that is the problem.
    You could also disconnect the element, that way it won't heat up and short confirming its not something else in the oven
    • guix
      • May 2018
      • 25
      • France
      Problem solved... Long story short, I had to invert L and N in the plug of the oven, in fact reverting a previous attempt by myself to fix the same issue a few months ago... Don't ask, too long to explain
        • 31294
        it has a plug?
        photo?
        normally we hardwire stuff that big.
        • guix
          • May 2018
          • 25
          • France
          It's not much bigger than a microwave.
          Not my picture but same oven with original plug.
            • 31294
            ok, i thought it was a big 12KW floor standing oven!
            • R_J
              • Jun 2012
              • 9625
              Just for the hell of it, check what A/C voltage you get between the mwo cabinet and any other appliance or sink with in arms reach.
                • 31294
                france is single-phase, the only thing you could find on a sink is static from capacitive coupling if his earth failed.
                • guix
                  • May 2018
                  • 25
                  • France
                  The case of the oven is properly grounded. Thanks, I didn't think about verifying this
                  • R_J
                    • Jun 2012
                    • 9625
                    But by looking at the plug you have removed the ground If the heat element is shorting to ground, it will apply full ac to the cabinet, without the ground it will NOT blow any breakers/fuses etc.
                      • 31294
                      ground on a schuko is by side-clips or an inverted pin(pin on socket side) on older french stuff.
                      he has ground there.
                      • kaboom
                        "Oh, Grouchy!"
                        • Jan 2011
                        • 2507
                        If the chassis is grounded, it'll trip the GFCI/RCD if present (as in the OP's case), OR energize and heat up if on conventional ckt bkr AND switch contacts for element are in the neutral- what fuckery reversible polarity is in combination with single-switch-contact (or relay contact) controls.
                        If cabinet is floating and GFCI present, it'll float up till someone touches it; the leakage should(?) trip the ground-fault protective device, with a "bite" during the time it takes to open.
                        That element is leaking to its sheath.
                        "pokemon go... to hell!"
                        EOL it...
                        All style and no substance.
                        guilty,guilty,guilty,guilty!
                        guilty of being cheap-made!
                        • EasyGoing1
                          The best way to drive a heating element?
                          by EasyGoing1
                          I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                          What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                          This is the general setup that I have now.
                          This is what the...
                          01-25-2023, 11:29 AM
                        • spleenharvester
                          AEG U3100-4-M Oven - RCD trips after heating up
                          by spleenharvester
                          Odd problem here with this oven. Once it's been heating for about 10 minutes the RCD trips. If you try and flip the RCD back on it will trip instantly until the oven has cooled down again.
                          It's previously eaten an element so I replaced the element again - fault remains. My next thought was possibly the cooling fan, as the mainboard's cooling fan kicks in after about 10 minutes usually, but the resistance is testing OK.
                          There's some quite badly melted plastic around the earth connection at the back of the oven, but I'm not sure if this damage was caused by the fault or...
                          08-18-2022, 12:31 PM
                        • JayPoorJay
                          A Central Air Heating Element, A PID and a Sauna
                          by JayPoorJay
                          What could go wrong...?
                          I'm not sure if this is the right sub category or even the right forum but here goes,,,
                          I'll just dive right in. I want to see if it's possible and what it would take to use a PID Controller (or 2) to run a central air conditioning heater element (the kind that goes into an air handler) and a small blower fan... The application is a DIY Sauna... Am I nuts? Mean, these components could be had for around 100 bucks.
                          What do I need to be thinking?
                          Of course I will go to Vevor and order one of their 200$ sauna heaters so I...
                          01-10-2024, 02:48 PM
                        • Curious808
                          LG LST5651SW stove: oven not heating properly
                          by Curious808
                          LG LST5651SW stove: The oven has a hidden bottom (bake) element that seems not to be heating up, but tests OK.
                          PROBLEM DESCRIPTION: Set oven to 400. The display shows it heating up normally to about 365, and stops there. The top (broil) element is visible and heated. Can't see the bottom element, but the bottom of the oven isn't extremely hot. A wet cloth on the bottom doesn't sizzle and doesn't really heat up. The stovetop burners seem to be working fine.
                          TESTING SO FAR:
                          1) Removed the back panel and leads to the bottom element. Using multimeter, continuity...
                          01-07-2023, 02:37 PM
                        • bohaboha
                          Queen coffee CQ MN-2 Heating element
                          by bohaboha
                          How to test this queen coffee maker heating element...
                          07-18-2022, 09:01 PM
