Hi guys i was given an Antenna PreAmp Winegard Ap4800 and it doesn't work, i opened it up and discovered a missing component on circuit antenna input input side it's either a resistor or a cap not sure can you experts guess what it is and what resistance or capacitance should i try?here 2 pic attach.
Winegrad Antenna preamp AP4800 missing component?
Re: Winegrad Antenna preamp AP4800 missing component?
I'd say a cap.
While you can solder a thruhole part across the pads (after cleaning them), that board is pretty grungy. You may even have to wash it to better inspect the traces. Check for open traces and printed inductors. These units were easily damaged by induced/capacitive coupling to lightning too.
For the test cap, something from 10-100n should be plenty."pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
Thanks Kaboom,i have many boards in my scrap ,does it have to be a Cap from RF board? Apreciate .I'd say a cap.
For the test cap, something from 10-100n should be plenty.Comment
Hi guys ;today i set my hands on the Win-grad pre-amp fault and i was able to fix it,i had in my scrap a Cable box board and i went inside the tuner and looked for a 10-to 100n and found a 100n cap and put in place and voila i have a working Antenna Amp,appreciate the help given by Kaoom.Comment
Nice to hear it worked out for ya.
You're welcome.Originally posted by ivtecappreciate the help given by Kaoom.
EOL it...
by HondamanRecently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
Years ago I made a "T"... -
by ChaksTAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
The specs says ...
High antenna efficiency 868MHz ISM Band
5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
1. Should I Fix it with a glue.
2. Should I fix it with a double side adhesive tape
3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...12-09-2024, 11:06 AM -
by SolomonManAll,
I recently moved to a very rural area. I am about 25 miles from the nearest urban settings (2 separate College Towns). 45-50 miles from a Urban City (Toledo Ohio)
There was a Omni-directional Wineguard Antenna (amplified) that was mounted on the house originally. Came with the house. Center of the top of Roof a few feet from Chimney on a 4 foot pole. The 75 ohm line went from the roof down 2-3 stories to the small Wineguard amplifier and then it split to the living room and master bedroom. Currently a Very simple setup.
Since we moved in, 8 years ago,... -
by ugamazingBoard had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),... -
by jprezaHi everyone,
I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
Looking at the card, it appears to be missing the following:
1x 1.0uH inductor - orange square
2x...1 Photo - Loading...
