Xbox One Power Issue
  • fuzzyrunner
    • Aug 2016
    • 29
    • US
    Hoping to get some troubleshooting ideas from you all. Unless someone has had this problem before and knows the solution.
    The issue:
    I press the power button or eject button to turn on the unit. The xbox turns on and plays its start up chime then probably 1-2 seconds later the unit plays the chime again and turns off. It does this no matter how I turn the unit on.
    All the videos and issues I've seen online deal with the unit turning on but then just shutting off but without any noise, etc. Mine seems to be actually shutting itself down properly but only a couple seconds after turning it on.
    Any thoughts or troubleshoot ideas I could start doing to narrow down where the problem could be coming from?
  • Play Retro
    • 3
    Re: Xbox One Power Issue
    Does the Cooling fan start?
    • fuzzyrunner
      • Aug 2016
      • 29
      • US
      Woops! I forgot I poster on here.
      Yes, the fan actually starts up when I press the power button.
      It also will turn on for a split second when I first plug the console in. The light on the power supply turns white for a couple seconds, the fan spins up, then the light turns orange again. It'll do this like 3 times before turning completely off. Then I press the power button, fan spins up and a second or two later the console chimes off.
        • Jul 2011
        • 6045
        Post some pictures of the board in the power supply
        Let see what you have
        • liquidzorch
          • Oct 2016
          • 135
          • mexico
          Have you found a solution to this problem. I have one with the exact same issue. I have tested so many components on the board it's not even funny.
            • Jul 2011
            • 6045
            Take some pictures of the switching power supply the front and back of the board please make sure that the pictures can be enlarged and you can read the text
            • FiXiNGA
              • Nov 2023
              • 4
              I have nearly the same issue but without any spinning of the fan. After the power on chime it has a white light for 5-6 seconds and then plays the off chime and turns off. In between hard drive spins and disc eject beeps.
              • TMTGTR
                An Xbox One PSU Odyssey
                by TMTGTR
                Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                =>Background:
                I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                06-17-2022, 05:40 PM
                HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                09-12-2024, 02:00 PM
              • unlogic
                Xbox One Controller (1708) battery powered issue
                by unlogic
                I have a strange issue with a 1708 controller when powered by battery. Wired it works fine, but on battery the light only starts flashing when you press and hold the X button. Once you let go it turns off. I've tried the same batteries on different controllers, and also fresh batteries, to no avail.
                Nothing seems off on the board on inspection. Any pointers as to where I might start looking or how to troubleshoot this?
                I've traced the battery line to around Q7 and Q6, and everything seems in order up to that point.
                I did a search already and haven't found...
                11-03-2023, 03:43 PM
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                🛠 Original Issue
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                by ugamazing
                12-17-2024, 07:05 PM
