Xbox One Power Issue
  • fuzzyrunner
    • Aug 2016
    • 29
    • US
    Hoping to get some troubleshooting ideas from you all. Unless someone has had this problem before and knows the solution.
    The issue:
    I press the power button or eject button to turn on the unit. The xbox turns on and plays its start up chime then probably 1-2 seconds later the unit plays the chime again and turns off. It does this no matter how I turn the unit on.
    All the videos and issues I've seen online deal with the unit turning on but then just shutting off but without any noise, etc. Mine seems to be actually shutting itself down properly but only a couple seconds after turning it on.
    Any thoughts or troubleshoot ideas I could start doing to narrow down where the problem could be coming from?
  • Play Retro
    Re: Xbox One Power Issue
    Does the Cooling fan start?
    • fuzzyrunner
      • Aug 2016
      • 29
      • US
      Woops! I forgot I poster on here.
      Yes, the fan actually starts up when I press the power button.
      It also will turn on for a split second when I first plug the console in. The light on the power supply turns white for a couple seconds, the fan spins up, then the light turns orange again. It'll do this like 3 times before turning completely off. Then I press the power button, fan spins up and a second or two later the console chimes off.
        • Jul 2011
        • 6065
        Post some pictures of the board in the power supply
        Let see what you have
        • liquidzorch
          • Oct 2016
          • 135
          • mexico
          Have you found a solution to this problem. I have one with the exact same issue. I have tested so many components on the board it's not even funny.
            • Jul 2011
            • 6065
            Take some pictures of the switching power supply the front and back of the board please make sure that the pictures can be enlarged and you can read the text
            • FiXiNGA
              • Nov 2023
              I have nearly the same issue but without any spinning of the fan. After the power on chime it has a white light for 5-6 seconds and then plays the off chime and turns off. In between hard drive spins and disc eject beeps.
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • justice171
                Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                by justice171
                I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                1. Verified that all critical voltages are present:
                  • 3.3V and 5V are always present if DC is plugged.
                  • 1.8V on the BIOS chip is present.
                2. Checked the power button functionality:
                  • When pressed, the voltage drops to 0V, indicating the button is functional.
                3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                  • Confirmed connectivity is intact, ruling out issues
                11-26-2024, 12:39 AM
              • claws77
                lenovo flex 5 14itl05 power sequence issue
                by claws77
                hi guys, my motherboard will not start no matter what
                when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                but rest nothing happens no sign of life.
                this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                i have no knowledge of motherboards ....
                10-20-2024, 02:48 PM
              • yaya3gmax
                Laptop Power Issue – Works on Battery, Fails on Adapter Load
                by yaya3gmax
                Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                Symptoms:
                • Laptop works normally on a pre-charged battery.
                • Battery does not charge when adapter is connected.
                • Without battery:
                  • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                  • Speakers “pop” when power cut occurs indicating harsh sutdown.
                  • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                08-21-2025, 07:16 AM
              • SuperJames
                Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                by SuperJames
                This one's a weird one, and still unsolved despite it having gone back to Dell once.
                Specs
                i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                Backstory
                I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                10-23-2023, 04:09 PM
