Zalman Fanmate-2 speed controller crashed my PC
  • redwire
    • 3912
    Sometimes I'd hear a coil whine which kept getting lower in pitch until poof blue screen on a PC.
    Tried everything, thought it was VRM instability and basically lived with it for 2 years.
    Other day I hear the whine again and rip the PC apart and find a cooling fan stalled and whistling. Nudge the fan it works, no whistle.
    Investigated and Zalman Fanmate-2 speed controller is a piece of garbage.
    Uses a linear 7805 regulator, no capacitors anywhere.
    So what happened is the 7805 would oscillate and the fan would whistle, I think sending bogus high freq. tach signal to motherboard and then it blue screens.
    Turfed the Zalman and the PC is stable like a rock.
    Unbelievable, after 2 years of this.
    Who'd thing a fan tach can crash a PC?
    Link to a guy's teardown of the Zalman Fanmate-2. Yes it's a garbage design.
    Gigabyte GA-Z97X Gaming GT motherboard bluescreen
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Zalman Fanmate-2 speed controller crashed my PC
    I figure most of the time, to keep a computer stable, cool it as much as you can -- slowing a fan down simply doesn't make sense...
    unless it causes someone's head to go unstable... Mine filters out the nearly white noise fairly well.
    • redwire
      • 3912
      This was driving a HDD cooler fan, pointing right at the controller pcb.
      It's slim- the sheet-metal is pretty restrictive and high/full speeds just made too much noise, all turbulence and no better airflow.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Interesting. I wonder how the fan controller can actually cause that. Perhaps it injects lots on noise on the fan tach line, thus causing the motherboard to go unstable?
        With a motherboard like that, I imagine you should be able to control the fan speed directly from the board. If you have spare 3 or 4-pin fan headers, just grab some spare female connectors and rewire your fan to be controlled by the motherboard's fan headers. These days, most motherboards offer PWM as well as Voltage-mode control.
        I disagree.
        Not everyone likes loud PCs. I am using quite a loud PC myself, and although I am used to it, sometimes it can get very annoying in the summer when the temps in my room kick up close to 30C/86F.
        Also, the fans wear out much faster at higher speed. Not to mention they collected dust faster, as well as the whole PC. So there is legitimate reason to not go overboard with the airflow.
        Ah, I see Molex connectors.
        Just mod the connector so the fan is running either at 5V or 7V, whichever works better with you. Then you won't even need a fan controller.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Originally posted by momaka
          I disagree.
          Yes, as said, some peoples heads go unstable with loud fans. However it can't be denied that the cooler the CPU is kept, the longer the CPU will last and less likely that the cpu will go unstable. Yes, longevity of the fan may suffer but that's a fan problem.
          The other issue at hand is whether the tach output suffers with a lower voltage. Ideally the tach output is an open collector/open drain so the output should not be affected by the lower voltage. However the input to that BJT/MOSFET may now no longer meet threshold requirement to saturate, and the output stops working -- and the PC thinks the fan seized. Now depending on the hardware and settings, the hardware monitoring chip can then tell the PC it's time to do an emergency shutdown - it quickly dying usually is better than erratic operation causing unreliable output.
          Anyway I think the threshold problem is happening with my reduced speed fan that doesn't register RPM anymore. This is most unfortunate as reduced speed fans are more likely to not spin up (due to overcoming initial inertia) and that tachometer data would be quite interesting to detect this situation.
          (I was always wondering why AC plug-in fans that have multiple speeds always clicks on high first...well this inertia problem is why!)
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            So just run the fan at a voltage that is not too high to make it loud and not too low so that it can't start.
            I find that 7V is typically okay for most fans. Only the very low power (low RPM) ones tend to require more voltage - but those you can typically run at full speed / 12V anyways, and they won't be too loud.
            Well, you only need to keep the CPU cooled below a certain temperature if you want it to last, nothing more and nothing less. Typically, the danger threshold starts above 60°C. I personally prefer to keep my CPUs below 55°C (and if possible under 50°C, even better). Reason being is that while the thermal diode in the CPU may read one temperature, the CPU core has many layers, and some of those layers could be running at 5-10°C higher than what the thermal diode is reading (particularly, the bottom layers).
            Take for example, AMD/ATI's Radeon HD4800 series of video cards - they have several thermal diodes in the cores: one for the "main" core, one for the memory handling part of the core, and one for the shader core. I suspect the memory and shader cores are in a lower layer further away from the heatsink, because they typically run 5-10C higher than the GPU's "main" temperature.
            So for the above reason, I like to see my CPU and GPU temperatures below 55°C (under load, of course). But anything lower than that isn't necessary, and you will hardly see any change in lifetime with temperatures lower that that.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Well, the problem isn't getting the fan started, it's getting the tach data so I know if it seizes for some other reason...
              Actually from a [device] physics perspective, the cooler it is, the longer it will last. At 50C it will last longer than 60C. Granted it may already last quite a while at 60C, but then... you can overclock it...
              The only layer gets hot is the diffusion layer as that's the most resistive layer. The metal layers won't get all that hot, fortunately the flip chips the diffusion layer is closest to the heatsink... The temperature sensor is on the same layer as the diffusions, however it definitely could be further in an XY direction on the die from the hotspots - but it won't be in the Z direction.
                • 31199
                the harddrive life is more effected than the electronics.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  The other "funny" aspect is that if someone implemented a true PWM controller for these tachometer fans, during the PWM dead time, the tachometer probably wouldn't work, again due to not being able to saturate the output transistor...
                  ahhh... screwed both ways, hence needing a 4-wire fan :-(
                  • redwire
                    • 3912
                    HDD's surely designed for some airflow, the power IC's get hot so I added the HDD cooling fan.
                    This old post says google data centers found no correlation with HDD lifetime and ambient temperature. But I think they all had lots of airflow, even if hotter air. Regardless, I like them cool
                    Intel 4-wire fan spec says "1.1 The expectation is a 4 wire PWM controlled fan when properly implemented will be significantly quieter than a similar 3 wire fan."
                    I'm using a 4-wire now and done with these cheeseball linear speed controllers.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Yeah, that's the only reason I like to have some airflow over my HDDs as well. Otherwise, I don't really care what temperature the internal platters run at, as long as it's not something crazy (i.e. over 50°C).
                      That said, for the older HDDs that don't use leaded solder, I don't bother to provide any cooling at all, as they won't have problems with Tin whisker growth and contacts becoming corroded.
                      The 20 GB IBM Travelstar in my laptop typically runs around 50°C in the summer. I try to turn off my laptop when I see it go beyond 53°C... but a few times I forgot and it hit 59°C. Still alright, though.
                      Nothing wrong with linear controllers. It's just that not all 3-wire fans play nice with them. Some will start to click rather loudly loud when pushed under a certain speed.
                      • master3112
                        ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                        by master3112
                        I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                        When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                        10-29-2024, 09:32 PM
                      • ronnygracias
                        Help with freemotion incline trainer with controller comm error
                        by ronnygracias
                        The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                        11-04-2024, 01:32 PM
                        Tankless hot water heater controller board not powering up when power is applied
                        by sam_sam_sam
                        I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                        I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                        However I would like to know if I could figure what happened to this controller board if possible
                        Tomorrow I will take some better pictures of both side of both boards
                        The...
                        12-09-2022, 09:14 PM
                        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                        by sam_sam_sam
                        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                        I am comparing them to a brand new one that I installed
                        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                        I going to let it run for several days before I remount back on the wall next to the...
                        09-05-2024, 06:48 PM
                        Modifing a Battery Spot Welder because of Controller Issues
                        by sam_sam_sam
                        I keep having the same exact issue with these battery spot welder controller boards
                        They either do one of two things
                        One the controller does not send the signal for the transformer fire which is a very common problem with this controllers micro controller failure
                        Or
                        The controller has some malfunction which means that it does not cycle the pluses more than once or none at all and should do it any where from 1 pluse to 20 pluses because you can not change the setting does not respond to its input micro controller failure
                        This...
                        10-12-2019, 08:51 AM
