What equivalent series resistance (ESR) capacitor should I replace bad one with?
  • raventy
    • May 2017
    I've got a bad clock capacitor in my original xbox that I'm trying to replace. It's a 1F 2.5V cap however, I'm not sure what Equivalent Series Resistance (ESR) the new cap should be. I see they sell 1 Ohm, 90 mOhm, 70 mOhm, and 500 mOhm on digikey. Any suggestions? Also how do you feel about the brands Eaton, Taiyo Yuden, or ELNA? Thanks!
  • mariushm
    • May 2011
    • 3799
    Re: What equivalent series resistance (ESR) capacitor should I replace bad one with?
    That's a super capacitor which is used like a battery. The ESR won't matter much, but i'd personally try to use one with less than 200 mOhm.
    You can also use capacitor rated for slightly higher voltage (let's say 2.7v)
    You can also use slightly higher capacitance (if there is room) but don't overdo it. You can also use less capacitance, it just means the clock and potentially settings will be kept alive for less time when you remove the xbox completely from mains.
    something like this would do: https://www.digikey.com/product-deta...198-ND/3878078
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      AFAIK you can also leave the capacitor out.
      It's only for the clock and the box can get that via Internet time server anyway.
      EDIT: Some more details: https://www.badcaps.net/forum/showthread.php?t=48951
        • 31294
        if it's NOT a 1.6 series then you can leave it out.
        if it's a 1.6 then you need some capacitance or the system wont turn on.
        i have tried 220uf and it worked fine.
        • cind12
          GTX 1080 TI Gigabyte Aorus low resistance on vmem
          by cind12
          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
          Resistance on 12V 4K ohms (Power present when on)
          Resistance on 12V PEX 4K ohms...
          12-08-2023, 09:09 AM
        • String2016
          SMD Asking equivalent, Can I replace ISL88738H WITH ISL88739
          by String2016
          Can I replace ISL88738H WITH ISL88739?
          12-11-2024, 02:52 AM
        • Nagy Daniel
          Lowest possible resistance on laptop motherboard rail - Guide Table request
          by Nagy Daniel
          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
          So, I generated a table with AI so I can...
          03-04-2025, 08:24 AM
        • jamespeterh
          APC SMART SUA 2200 XL 640-0800G REV 7 cannot detect any load placed
          by jamespeterh
          Hi, all
          I've posted a similar Q&A on alternative site but this site seems to be more focused in saving UPS.
          The system is a SUA 2200XL Rev 7 230V 640-0800G Rev 7
          I have UPS that has a strange fault, it does not show or indicate any load on the system, via display or internally coms, LED test front panel works all light up.
          has anyone else seen a fault like this , operates but no load recorded, or just blown one of the important non replacable IC's
          1. internal monitoring via cable direct into the CPU that no load is present even...
          06-21-2025, 06:19 PM
        • novice1
          Acer Aspire E5-574G - Not Powering On
          by novice1
          Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
          This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
          To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
          11-03-2023, 05:53 PM
