ACHI IR-PRO-SC Profile settings PS3, PS4
  • BGAlover
    • Apr 2017
    • 5
    Hi guys,
    as I mentioned in the title, what profile settings do you have for lifting/reattaching a PS3/PS4? And which RS232 to USB Adapter do you recommend, which works?
    Thank you.
    • 30977
    Re: ACHI IR-PRO-SC Profile settings PS3, PS4
    usb adapters,
    if you use Linux they all work
    if you use windows then you need to check what drivers you can get.
    • BGAlover
      • Apr 2017
      • 5
      Unfortunately not. I use Windows on my Laptop.
        • 30977
        what version, 3.11?
        • BGAlover
          • Apr 2017
          • 5
          Yes, my preferred Windows for DOS-Games.
          Just kidding. I am using Windows 10 Pro x64.
          I ordered now this one:
          https://www.amazon.de/gp/product/B00...?ie=UTF8&psc=1
          I'll give it a try for 11€ with the FTDI Chipset.
          • BGAlover
            • Apr 2017
            • 5
            Is there really no one how can share his profile settings for lifting/reattaching a PS3/PS4?
            • i440bx
              Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
              by i440bx
              Hey there,
              I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
              The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
              It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
              As written above, I plugged in a new CMOS cell and checked...
              08-19-2024, 02:28 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • AquaMan Ua
              Problem with PANASONIC CF53 laptop after changing BIOS settings
              by AquaMan Ua
              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
              05-17-2025, 09:40 AM
            • moscast
              How to create a profile for ACHI IR PRO SR (my first time with BGA machine)
              by moscast
              Hi everyone, I recently purchased a BGA machine (ACHI IR PRO SR, 2400W IR Bottom and 450w IR Upper) but I don't know how to create the processing profiles. I need to desolder a faulty GPU on a laptop.
              As software I was thinking of using this:
              https://www.badcaps.net/forum/troubl...hi-ly-by-psoft
              Can anyone tell me the most suitable or common heating curves for soldering and desoldering?
              Thank you​
              02-25-2024, 04:12 PM
            • Billydv1@verizon.net
              Various Asus Motherboards losing bios settings
              by Billydv1@verizon.net
              Trying to track this down. 3 boards all same problem. Rampage IV Extreme, Z87 Pro, Z97 pro. All boot and function correctly but all lose bios and time settings if power is shut off. If power is maintained, sytrms boot and reboot normally. I have verified cmos battery is supplying 3v to board. 8 pin bios chip has continuity to ground but no voltage to vcc pin. I assume that's the pin that maintains the settings with power to bios chip. How do I track this down? What voltage do these bios chips require?
              11-30-2023, 10:27 AM
