PS3 Controller
+ More Options
Posts
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    PS3 Controller
    For grins-n-giggles....I had on older PS3 controller....sixaxis (no dual shock)
    The analog joystick thumb controls were sticky and wouldn't return to center.
    Since I hadn't done any soldering in a while, I did some research and Mouser had the joystick assemblies.
    So....popped them off and put the new ones in. Works like a champ.
    I read something about a 4 pin varistor, but I needed the 3 pin. Here is the PN: RKJXV1224005
    I love fixing old stuff.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: PS3 Controller
    Nice, i struggled no end when i tried to replace one of the joysticks, when i had a try a while back.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Re: PS3 Controller
      Nice normally to sort them when they get sticky like that spray some dexoit or Wd40 in the centre of the joy stick it will free up instantly and still work fine
        • 30965
        Re: PS3 Controller
        the sticks are cheaper than wd40
        • stretch0069
          • Oct 2003
          • 2658
          Re: PS3 Controller
          yeah...the sticks were like $5 or something. Cleaning didn't help mine. There was an interesting note about the sticks. You're not supposed to let them go to their physical limits. there was a 40 degree limit or something. Damn...now i'll have to find that pdf again.
          the main reason i did it was to dust off the skills. and its fun. i posted because it seemed like few posts i saw didn't have good info or they went to sites selling "refurbished" joysticks.
            • 30965
            Re: PS3 Controller
            more like 1$
            https://www.rapidonline.com/joystick...-60-deg-526055
            and caps
            https://www.rapidonline.com/white-la...h-knobs-526145
            • VaNDAL_UK
              • Aug 2010
              • 77
              • United Kingdom
              Re: PS3 Controller
              Sorry bud, those are completely the wrong ones and the caps. You may find those in cheap knock off clone pads but never in the originals only ALPS.
              The caps are a specific shape and size as well so you have to be carefull what you buy when fixing controllers. Quite subtle differences.
              • stretch0069
                • Oct 2003
                • 2658
                Re: PS3 Controller
                EEEEEEEEEEEEEEEEEEEEEEEHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!
                wrong answer. vandal_uk is right.....
                http://www.mouser.com/Search/Product...8-RKJXV1224005
                only $2 each.
                  • 30965
                  Re: PS3 Controller
                  maybe the clones are better!
                  • stretch0069
                    • Oct 2003
                    • 2658
                    Re: PS3 Controller
                    look at the data sheets..........
                    they
                    don't
                    work
                    • master3112
                      ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                      by master3112
                      I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                      When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                      10-29-2024, 09:32 PM
                    • ronnygracias
                      Help with freemotion incline trainer with controller comm error
                      by ronnygracias
                      The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
                      11-04-2024, 01:32 PM
                      Tankless hot water heater controller board not powering up when power is applied
                      by sam_sam_sam
                      I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                      I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                      However I would like to know if I could figure what happened to this controller board if possible
                      Tomorrow I will take some better pictures of both side of both boards
                      The...
                      12-09-2022, 09:14 PM
                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                      by sam_sam_sam
                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                      I am comparing them to a brand new one that I installed
                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                      I going to let it run for several days before I remount back on the wall next to the...
                      09-05-2024, 06:48 PM
                      Modifing a Battery Spot Welder because of Controller Issues
                      by sam_sam_sam
                      I keep having the same exact issue with these battery spot welder controller boards
                      They either do one of two things
                      One the controller does not send the signal for the transformer fire which is a very common problem with this controllers micro controller failure
                      Or
                      The controller has some malfunction which means that it does not cycle the pluses more than once or none at all and should do it any where from 1 pluse to 20 pluses because you can not change the setting does not respond to its input micro controller failure
                      This...
                      10-12-2019, 08:51 AM
