xbox 360 blowing mosfet
  • waldoalvarez00
    • Dec 2015
    • 57
    • Dominican Republic
    Hi Folks:
    I have an xbox 360 that had a shorted USB pin. After unbending it and turning it on it came without video and red ring. I tried the towel trick and it came up with video. Then the power source led turned red and I heard a mosfet failing. I tested the mosfets and found the two 5v mosfets were shorted (they showed as two resistances on the tester). I replaced them but now the one closer to the CPU is shorting everytime I power it on. If I remove it it starts with red ring.
    Any ideas of what could be failing? Maybe a shorted capacitor? What tests should I do?
    Regards
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: xbox 360 blowing mosfet
    What else have you checked for S/C in that area ?
      master hoarder
      • May 2008
      • 12175
      Post a picture of your board and tell us exactly what parts you think failed (i.e. Qxx, Cxx, etc.) and what you replaced them with.
      Also, the towel "trick" is simply that - it is a crappy temporary repair at best, and usually does more damage than good. If you got an RROD with a secondary code typical of GPU failure, then do a reflow on the GPU. Here is a rather crude but fairly easy method:
      https://www.badcaps.net/forum/showpo...3&postcount=15
      Again, do NOT use oven or towel "tricks" - they are always done by people who don't know what they are doing. Spending a little bit of money to get decent tools (a heatgun and temperature probe) is a must if you want to do it properly, and especially if you intend to keep your 360 console working for as long as possible or fixing other 360 consoles.
      • waldoalvarez00
        • Dec 2015
        • 57
        Ok I replaced those two with ones from another console, it got fairchild ones (both were damaged) so I putted two On semiconductor new ones (tested as good on the transistor tester) http://www.onsemi.com/PowerSolutions...o?id=NTD60N02R
        You see the one closer to the CPU next to the small black capacitor blew two times. No smoke no holes no nothing. The fan tries to start for a second then it stops entirely. It gets damaged and shows as to resistors on the tester. Maybe the controller chip? Just wondering. I don't have oscilloscope to test.
        Are you sure this gotta do with GPU reflow thing? That part of the circuit I think feeds USB and drives with 5V. Testpoints on all other parts give me 0v readings for RAM, CPU VRM and GPU VRM. Standby testpoints are the only ones good, 3.3v and 1.8v on the upper side of the board. No more voltage readings anywhere else.
        I know it gets +12 v on the upper Mosfet base for a short while if I remove it and start the console. Then goes back to zero and give the three rings.
        Yes I know towel trick is bad stuff. I just tried it to test it. I had no solder station then. Strange thing is it started for sure and I got video. Then it lost video but was still making sound (so yes maybe GPU reflow as you say is needed). After that trying to start it again it gave me sound, the Mosfet failed and the power brick turned the led red.
        I think there are two things here. GPU problem and something else. I am looking to find that other problem and then jump into GPU reflow.
        • waldoalvarez00
          • Dec 2015
          • 57
          I don't see short circuits in that area. I put the Meter in diode mode to test continuity and there are none with ground.
            • 31267
            when it shorted, did all 3 pins short together?
            if yes, then whatever is driving the gate pin may be damaged.
            • waldoalvarez00
              • Dec 2015
              • 57
              Not really sure. They show resistances in all the damaged Mosfets so yes could be the case. So what is driving the gate should be connected to a resistance. I have a 360 schematic, I attached it. I think is PAGE_TITLE=VREGS, V1P8 AND V5P0. So seems to me that part of the circuit is driven by the NCP5425 (http://www.onsemi.com/PowerSolutions....do?id=NCP5425) through those resistances R5F5 and R5F6.
              • waldoalvarez00
                • Dec 2015
                • 57
                Sometimes in SMPW I get the Mosfets blown when the feedback is damaged as they run on superhigh duty cycle. Also with shorts somewhere else as the tension output is so low the duty cycle is way too high for the Mosfet.
                • waldoalvarez00
                  • Dec 2015
                  • 57
                  I noticed this model is not the same exactly as the one in the schematic (Xenon), it is a Falcon board. It has no SMD resistors coming from the controller to the gates and has this controller http://www.analog.com/en/products/po...s/adp1823.html
                  I tried another thing. I removed the USB ports since they were bent anyways and just in case they had some shorts. I have a Xenon board bent and broken picked from the garbage, with some stuff missing but the USB ports and many things are ok.
                  So putted another mosfet and took the risk to power it on. Well this time it holded and didn't got damaged but the power brick is sensing something as the console spins the fans for a second and then the power brick turns the led red activating sort of an overcurrent protection mechanism.
                    • 31267
                    do you have schem's for other xbox boards?
                    • waldoalvarez00
                      • Dec 2015
                      • 57
                      I didn't but found them here is for Falcon. Enjoy
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        So they have a phase Lock loop on the power supply. They must have a problem with the frequency of the power supply drifting?
                          • 31267
                          nice
                          • waldoalvarez00
                            • Dec 2015
                            • 57
                            Sorry don't understand this. Where they have a phase lock loop and how it could be related? PLL are used for clocking right? How it is related? The chip seems to have some internal clock with external possibility not used in the design and osc frequeancy selectable through a pin.
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              PLL was use for FM radios so that when the frequency carrier started to drift a feedback circuit would correct it on the input oscillator. I am assuming that with the a power supply that is frequency modulated the modulator has a tendency to drift so they are using the PLL to correct this error.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Here's the Xenon stj
                                  • 31267
                                  that was posted earlier in the thread.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    It would appear that the Phase Lock loop control is on page 50 at this IU7U1
                                    • waldoalvarez00
                                      • Dec 2015
                                      • 57
                                      Just a buck converter for the CPU. It just lowers the 12v from input to the VID specified by the CPU.
                                      • keeney123
                                        Lauren
                                        • Sep 2014
                                        • 2536
                                        So why is is listed as phase 1, phase 2, phase 3? You will also notice the output looks back to the input through the V_CPUCORE as a reference. I have not look up the IC, but it would seem to me that the different phases are being sent up by what is being feed back form the V_CPUCORE and this is what is causing when the phases are sinking.
                                        • Scotchmist
                                          Asus GA502D keeps blowing mosfet
                                          by Scotchmist
                                          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                          I have removed the mosfet and can run the laptop no problem
                                          The MOSFET is FDPC5018SG
                                          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                          08-24-2024, 02:23 PM
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • TMTGTR
                                          An Xbox One PSU Odyssey
                                          by TMTGTR
                                          Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                          =>Background:
                                          I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                          06-17-2022, 05:40 PM
                                        • grimacelord
                                          Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                          by grimacelord
                                          Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                          After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                          I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                          10-24-2024, 12:31 PM
                                        • Nooy
                                          VGA MOSfet permanently shorted and loss of MOSfet pad
                                          by Nooy
                                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                          02-14-2024, 02:26 AM
