Re: Original Xbox Replacement Caps
Yes, I assume those are the three orange ones near the Ltec caps.
what sub 1uf??
nothing like that on the mobo - you mean the psu?Leave a comment:
Thanks for the info, and yeah, that was the story with those Nichicon HM as well. The unit worked when I got it some years back before even knowing about them, then didn't use it for 2-3 years and that's when they crapped out.
I actually went ahead and did some pictures of the PSU, there's some discoloration on the PCB between a diode, resistor and ceramic cap (?), did anyone see that before?
By the way, what's the story on those sub-1uF electrolytics? I don't see any Panasonic etc. for sale with such low capacity so I guess you replace them just with whatever is available? And for things like those Taicon VX is it safer to use some 105°C GP stuff instead of Panasonic FC and the like? I can't even find any ESR ratings in the VX specsheet.
Edit: nevermind the discoloration thing, skimmed through the thread again and it looks exactly the same on this pic so I guess it's normal for those PSUs.Attached Filesif you find these attachements useful please consider making a small donation to the site
They do, but not as often in these older power supplies. Not sure if because older Ltec were of better quality or because PSUs just didn't stress them as much back then. But if you see Ltec in equipment made after ~2007, definitely replace them, because they are guaranteed to be bad or go bad. At least from what I have seen, 2006-2008 is when they seem to have started (or went) downhill. Nevertheless, keep an eye on those Ltec caps once in a while if you do intend to leave them in there - especially after the Xbox has been stored for a long time with no use (over 6-12 months.) For some crap caps, keeping them in storage without use can be just as bad for their reliability as using them.Last edited by momaka; 01-19-2021, 02:11 AM.Leave a comment:
Well looking at it again I think I'm going to leave it alone for the time being, unless someone comes up with a report of those Ltec caps failing. There's a ton of hard glue between the coils and those caps, going at that with a knife has a risk of cutting up the board. I know isopropyl could probably be used to soften it but that would be messy as well.Leave a comment:
Those power supply caps hold up surprisingly well considering they are tier 2 caps. I recapped a Foxlink for fun and all the old caps tested fine with ESR. If you want to do it for preventative measures then more power to you. I used Rubycon for the most part as Panasonic's were always bigger.
Back in this thread a few pages you can find my foxlink recap pic... https://www.badcaps.net/forum/showpo...&postcount=124Last edited by jayjr1105; 01-15-2021, 10:28 AM.Leave a comment:
Greetings,
I have a 1.4 Xbox that had those bad 3x3300uF+1x680uF Nichicon HM caps, symptoms were screen flickering etc. as mentioned above, already swapped those with Panasonic FR and the system is working great again.
Now regarding the PSU, not sure if I'd trust those caps there long term so I'm thinking of doing a preventive recap before putting in a new HDD. I neglected to make a pic of it but it's a Delta unit with Ltec 2200uF (LZG series according to an earlier post here). Did anyone who recapped theirs put an ESR meter to those caps? Mainly asking because all the glue in there does add some difficulty to it.
Also, I can choose between Panasonic FC and FR for the recap, I'm sure both would work but ideally would I just go FR for the entire thing or look up each cap and try to match ESR? For example LZG would be 0.030 or 0.035 ohms (not sure which size was used) while FR is lower at 0.018.
If I do go through with the recap I'll be sure to post some readings as I do have an Atlas ESR60.Leave a comment:
Use 5x 1500uF 2.5v polys (RR50E152MDN1) or 5x 1000uF 6.3v polys (RR70J102MDN1). Price is almost the same as the ZLQ or UHV but half or third the ESR.Last edited by Ryeno; 12-15-2020, 12:57 AM.Leave a comment:
Yes, screen flickering and visual issues are most likely the bad caps around the CPU.Because now my xbox start to have flickering on 2D images, and I presume it is from the caps. Which one? I don't exactly know so as I want to preserve it I prefer to do it all so I am good for the next 20 years.
Do you believe this comes only from the one near the CPU?
Thank you,
ArmandLeave a comment:
Thank you,
Those other usually don't go bad. Why are you replacing all those?Thank you very much! If you happen to know for the others I need also :
25v 22uf Nichicon VR (5x11mm)
25v 100uf Nichicon VR (6x11mm)
10v 3300uf Nichicon PW (12.5x25mm)
16v 1500uf Nichicon HD (10x20mm)
2.5V 1F Nichicon UC
SMD:
16v 47uf Nichicon WX
16v 10uf Nichicon WX
Thanks againLeave a comment:
2.5V 1F Nichicon UC
SMD:
Which ones are bad? Pics?Hi everyone,
I would like to save my baby version 1.4 and although I have read the entire post, I could not find any suitable reference for the replacement. It was very useful for getting the reference of my current one. Does anyone have the corresponding replacement?
I am interested in having well recognize brand.
Thank you,
Armand
It's usually the 3300uf caps that go bad. Nichicon UHV, Rubycon ZLQ are what I normally use.Last edited by jayjr1105; 11-09-2020, 09:20 AM.Leave a comment:
Thank you,
Yep, didn't plan on going low. That area is riddled with tiny SMD 16v caps I think 10uf so that makes sense, and it is right next to a regulator so yeah.Leave a comment:
make sure you use 16v there,
some boxes gave a 10v cap, but the voltage across it is already 9v
it smooths the power around a linear regulatorLeave a comment:
I'd replace them. A few 16V, 680 uF caps shouldn't cost too much. Nichicon HM from that era is just failure prone, no matter the size. With that said, it can sometimes take a little longer for the smaller HM/HN/HZ caps to fail than usual, especially the higher voltage versions. But it will probably happen eventually. Not all of them may exhibit double capacitance or higher either. On the other hand, the problem is that when some of these Nichicon HM/HN/HZ caps fail, they can sometimes become a short-circuit for a short while, and that could cause a weaker component to burn out. So depending on what the capacitors in those spots are connected to, that may or may not be big issue. But for a few cents extra... might as well get them done.
Just noticed a few boards have a Nichicon HM 680uf 16v near the AV connector. Should those be replaced as well? Not sure of that cap's purpose. I did pull one and it read a little high, not double like the 3300uf ones but still high.Leave a comment:
Looking good.
Should make it another 20 years easily... provided the GPU (nVidia GeForce 3 -based) can make it that long too.Leave a comment:
Saved another 1.6 from pissing Nichicons
by nick3092I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
Channel: General Capacitor Questions & Issues
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
Howdy folks,
The GX260 strikes again, I just now noticed that a bunch of smaller caps on the motherboard are bad.
There's no indication of what series these are, but they have the same color wrap as the HM series. They're rated at 22uf and 25v and about 5mm x 6.5mm. The only other markings are the temperature rating (105 degrees Celsius) and what I assume is a date code - A236. The data sheet for the HM series doesn't include caps with these ratings. I've attached some images of the caps themselves and where they are/were on the motherboard.
Does anyone...-
by spike93Hi everyone,
I'm probably going to ask a very noob question but after many readings and videos I'm still unsure on the answer.
I've broken one of the caps around the gpu of an xbox 360 by overheating it. In the forum I've found this thread where the user had exactly my situation (same console version and same broken caps): https://www.badcaps.net/forum/showthread.php?t=24983
The difference is that I've broken only one of the Rubycon caps (or at least that's what I can tell from a visual inspection). Now I'm planning to use a solid capacitor as replacement,... -
by bulkchart32i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
- Loading...
