Help with Motor Control Board - ProForm treadmill
    replied
    Re: Help with Motor Control Board
    166VDC is fine and that is what I expected. I am still wondering about the solder joints on those two Zener diodes that the pads look to be damaged and you were getting 6.6V and then 15V, there may be bad joints on the board.
  • Crrose
    replied
    I thought I would try each individually since it couldn't hurt. I get 166.6 on the one closest to the relay and -49 on the other.
    I can also hear the relay clicking on and off which it wasn't doing before.
  • Crrose
    replied
    I just soldered wires to the large caps. When I turn the power on do I test them individually or hook both + to + and - to - ?. Everything is hooked back and put together like it is supposed to be.
    replied
    Heat is only needed when the motor is running and since the motor is not working you do not have to worry about heating up the bridge rectifier or the power MOSFET.
    We need to know if the main caps on the motor driver board has Voltage on the main cap or not. The relay looks to be for soft-start circuit.
    The MOSFET is connected in series with the motor and it is driven by PWM signal to the Gate.
  • Crrose
    replied
    Ok I have some 18/2 lamp wire I can use.
  • selldoor
    replied
    Originally posted by Crrose View Post
    I hooked by mower battery up and the relay opens and closes. Tested the Ohms and get .6 when set at 200ohms.
    Hurrah success- a little success but success -
    Wire guage ?? thin mains wire like for a low wattage bedside lamp
  • Crrose
    replied
  • Crrose
    replied
    I just realized my mower is 24v I'll try to get relay to click with it.
  • Crrose
    replied
    I can't hook up my board to the heat sink without attaching it to the mounting frame. Once it is attached to the mounting frame there is no access to the bottom of the board. I guess I could try to solder some wire to the bottom of the caps and hook it back up. Does it matter the size of wire?
    No click to relay but I was only using an 18v battery so may not be enough power.
  • selldoor
    replied
    Dont suppose you heard it click? - what polarity did you use battery plus to ???
    I meant you to wait until budm came back on to check about the diode.
  • Crrose
    replied
    Ok if I put my battery to RLY1 and RLY2 and test ohm at AC1 and AC2 I get no reading. If on diode mode its 1.452
  • selldoor
    replied
    Just reread post 10 and your comments on your meter if I have the test points correct I think that means the bridge is ok
  • selldoor
    replied
    Sorry I meant the nothing in ohms mode post10
    AC1 to DC+ I get .527, reversed nothing, AC2 to DC- is .522, reversed is nothing. AC1 to AC2 nothing either way. This was done on diode setting. When set to 2000 ohms there was no reading at all.
    No you cant apply mains power without the heatsinks and no you cant test the big caps without powering up
    In pictures on the net of these boards they have the heatsink part attached
    can you do that or is yours attached to the frame? or wont the cables reach?
    As mentioned before an alternative would be to solder wires to the caps.
  • Crrose
    replied
    I have a cheaper DMM it doesn't give you OL. In diode mode it starts at 1. and if no reading it stays that way, if I get a reading the .1 disappears and get a reading.
    Been searching for a cheap used FLuke but can't find one.
  • Crrose
    replied
    If I hooked the power up to the board and powered it on would it do any damage to it since the heat sink would not be hooked up?
  • selldoor
    replied
    Ok when you say nothing do you mean the same as touching the probes together 0.00 or perhaps a single 0 on the left of the meter screen? ( or OL -something meaning off scale or overscale)
    I think these are the points to check the relay - you apply the voltage
    to points R1 and R2 and take an ohms reading on AC1 to AC2 - should go from
    open offscale or OL to 0.00 or close to
    Perhaps wait for budm to comment as he did mention a zener in parallel and I dont know if he meant care as the reading wouldnt work or CARE as in damaging the diode
  • Crrose
    replied
    Can I test them without power to the board? When I do I only get .30v
  • Crrose
    replied
    I did the same with the relay and got these results if it means anything.
    Leg 2-3 = 1.435
    Leg 2-4 = 1.710
    Leg 2-5 = 1.790
    Leg 3-2 = 1.419
    Leg 3-4 = .961
    Leg 3-5 = 1.239
    Leg 4-2 and 4-3 = nothing
    Leg 4-5 = .565
    Leg 5-2 and 5-3 = nothing
    Leg 5-4 = .509
    replied
    Are you getting 160VDC at the two legs of those two main filter caps?
  • Crrose
    replied
