Help with Motor Control Board - ProForm treadmill
  • selldoor
    replied
    Re: Help with Motor Control Board
    There you go, 130VDC motor.
    Perhaps thats one reason I couldnt see how the voltage was reduced to 24v
    It isnt !!!!!!
    Edit and off topic a little- that is actually qute encouraging- when I get to mine at least it seems the motor might test out with 24v it is a 180vdc one, wasnt sure how I would get anywhere near that to test it.
    replied
  • Crrose
    replied
    Had to use mirror since label on bottom of motor, can't get picture.
    Model B4CPM-112T
    CW Rotation
    Encl open
    Ext fan
    Electrical rating at 130 VDC FF 1.0 AOM
    2.75 HP duty: treadmill 6400 rpm 21 Amps
    1.75 HP cont duty @ 100 VDC FF 1.0 AOM
    I will hook the board back up and install it in the morning to check those pins.
    replied
    Can you provide the pictures of the motor and the label on the motor itself, from the way the circuit is it cannot be rated at 24VDC, more likely to be 130VDC or higher since the power supply is 160VDC and the size of the wires are way too small to handle the current if it runs on 24VDC.
    replied
    The VDD pins are tied together internally, same for the GND pins. Meter set to DC.
  • Crrose
    replied
    Ok you said to check VDD and GND, on the link you provided is shows pins 1 and 8 both VDD and 4 and 5 GND. Do I check red to pin 1 and black to pin 4 or pin 1 and pin 8? And I assume check with with meter on AC not DC?
  • Crrose
    replied
    OK I traced the gate leg. It goes to a 3 legged 100v capacitor. Then from one leg of the capacitor to the small 562 chip and the other leg to the 2 middle legs of the 8 legged chip (TC1410 NCOA 833AN). From the small 562 chip it goes to the 3rd bottom leg of the 8 leg chip, leg then to R19 Resistor. The left bottom leg of the 8 leg chip then goes to DZ3 which then goes back and connect to the source of the mossfet.
    replied
    TC1410: http://www.microchip.com/wwwproducts...product=TC1410
    Check the Voltage between VDD pin and GND, be real careful, you are working in the primary deadly side, do not let the probe slip on you.
  • Crrose
    replied
    Here is a close up of where the gate leg goes to. It looks like it is connected to the different chips and diodes in the corner then back around to the source leg.
  • Crrose
    replied
    Yes the relay is still clicking on then off a few seconds after power is turned off.
    replied
    OK, the relay still clicks on?
    At this point I believe the Gate drive signal is not present so it can be relate to that STI chip or I hope it is not the safety lockout.
    Need to trace the Gate connection to see where it goes to.
  • Crrose
    replied
    Ok I just put it back together and installed on board, put the red alligator clip on source and black on gate and there is no voltage to it powered on either.
  • Crrose
    replied
    Does the board need to be put back and powered up for this? With it disconnected I get 0v from source to gate. I tried both red to source and black to gate then black to source and red to gate.
    replied
    Correct info and measurement are really important, otherwise I cannot verify the circuit function.
    So the circuit is connected as I suspected.
    Check the DC voltage between Source pin and the Gate.
  • selldoor
    replied
    This time I am absolutely sure I dont understand anything in the last few posts
    .......... goodnight folks
  • Pentium4
    replied
    Originally posted by Crrose View Post
    I don't like Dallas but that should have been ruled a catch, 3 steps then right forearm down before hitting ground, but they are playing in Green Bay and the NFL does have a say so on who would make a better storyline. Why wasn't Green Bays catch that hit the ground earlier ruled incomplete after replays clearly showed it, even announcers thought incomplete, NFL said so is why.
    Totally agree. He maintained possession, so it should have been down at the 6 inch line like the original call said.
    And then did you notice after the "delay of game" penalty on Cobb (which should have been unsporstman like conduct), they didn't even apply the penalty to the next play, it was still 1st and 10.
  • Crrose
    replied
  • Pentium4
    replied
    What a game!
  • keeney123
    replied
    football time
  • Crrose
    replied
    Geez it was negative side, this is why I never went into electronics. On the real + side there is no reading.
