PS5 WLOD EDM-030
  • Fide
    • Dec 2021
    • 5
    • Deutschland
    PS5 WLOD EDM-030
    Hello guys,
    I try to repair a PS5 with a WLOD.
    At the beginning I should tell that I get a BLOD and after the UART reading and shorts on the caps near by the HDMI Encorder I change the IC. And after the change I get a WLOD. I also noticed that the filters was blown. I change them also.
    The caps near by the HDMI Encorder are not shorted now. I also change the HDMI Port.
    I get some readings in Diode Mode which doesnt look right to me.
    1. HDMI Pin 18 i get 0.100V and Pin 19 OL
    2. Diode on the back side 0,100V
    3. Cap on the back side under the Diode OL
    I'm also wondering about the number of caps around the HDMI IC. This model have much less caps like the EDM-010
  • budwich
    ESD Diode on HDMI output of Yamaha a1050 RCVR
    by budwich
    I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
    I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
    09-11-2023, 12:21 PM
  • SuperAman
    PS5 HDMI port diode reading?
    by SuperAman
    I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
    02-03-2024, 10:16 PM
  • An-klamm
    Ps4 slim WLOD not HDMI encoder IC
    by An-klamm
    Hello!
    I bought 3x PS4 slim in the hope that I can repair all three so I can sell two and have one for free.
    All three had the error that no picture is outputed but the LED lights up white.
    I have already replaced the HDMI encoder IC and one PS4 is working straight away.
    It seems to be a different error with the others.
    I have measured everything that I can measure in the installed state. There are 5V, 5.1V, 2.4V, 3.6V, 1V, 2V. I can't see any differences between the working PS4 and the defective ones.
    I have measured the HDMI port and all PINs have approximately...
    03-30-2024, 03:57 AM
  • irepair559
    Ps4 1215a hdmi diode readings good everything good but no pic??
    by irepair559
    PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
    01-05-2023, 12:32 AM
  • aliougm
    Marantz SR4003 AVR HDMI board issue, seeking for help
    by aliougm
    I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
    Connection as below:
    Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
    If I bypassed AVR then HDTV screen color be good.
    I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
    3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
    I replaced all...
    04-30-2022, 12:21 PM
