INSKAM Microscope USB port issue
  • lcdcaps1
    • Oct 2011
    • 322
    Hi
    All
    Does anyone have a INSKAM 7 inch LCD digital microscope
    I have a weird issue on the one I have where the USB port does not output enough power because when I connect a USB light or the ring light the light output is always really dim
    The ring light when connected to the microscope USB port is at the lowest brightness and turning the brightness knob makes no difference
    I have tried different cables and different USB power adapters
    I have confirmed there is nothing wrong with the ring light and the other USB light by plugging them into another USB source other than the microscope and they work fine and ring light brightness works
    Has anyone had any issues with this before
    Does anyone have any schematics or board view or photos of the board
    Thanks all
    • 30979
    most usb microscopes you dashcam type circuits, it probably has a usb supervisor chip on the 5v rail that limits current.
    • lcdcaps1
      • Oct 2011
      • 322
      Thanks for the reply
      I'll try and get into it and look
      • lcdcaps1
        • Oct 2011
        • 322
        I have just noticed my photos of the microscope. Did not attach. I have attached again.
        I am trying to get inside to have a look but after removing the screws it is still tight
        Has anyone got the same or similar microscope, please. The inside boards are most likely the same or similar throughout the diffirent models
        Thanks all
        • lcdcaps1
          • Oct 2011
          • 322
          I plugged in a USB amp meter into the USB port and got nothing showing
          I tried a few and tested on other devices
          I found this very strange
          It is as though the USB port is shorted or loose
          I do not understand why there is no voltage showing because there must be some voltage output as the LED ring light is being lit up
          Still trying to see how to get into it
          Removed the screws but still very tight
          • lcdcaps1
            • Oct 2011
            • 322
            What could cause the USB Ammeter show this behaviour
            Has anyone seen this issue before
            • lcdcaps1
              • Oct 2011
              • 322
              Hi
              Any ideas from anyone
              • lcdcaps1
                • Oct 2011
                • 322
                I have finally managed to get inside.
                I have attached some photos of the board
                  • 30979
                  the 4056 is a classic lithium charger chip
                  • lcdcaps1
                    • Oct 2011
                    • 322
                    the battery is charging
                    My suspects are the two small sot-23 components
                    I am trying to find some replacements but I cannot find any information on the 23ax component
                    what substitutes can i use In replace of 23ax and 1am
                    thanks
                      • 20637
                      thanks
                      Can you post a better picture of the 23ax IC , is there an underscore under the A , 23AX
                      • lcdcaps1
                        • Oct 2011
                        • 322
                        I am attaching another photo,
                        best as I can get
                        No underscore
                        Any ideas where I could find such components
                        Any scrap boards for example
                        Also any substitutes available
                        • lcdcaps1
                          • Oct 2011
                          • 322
                          Here are photos of the other side of the board
                          I am trying to find more details of this component, seems like a voltage regulator but cannot find a datasheet
                          What I find strange is that the USB port is working but not as it should
                          Also when I plug in a USB tester it shows nothing
                          • lcdcaps1
                            • Oct 2011
                            • 322
                            Studying the boards front and back I can see there is a chip which I believe is to be a ln2220par. The datasheets I am finding is all in chinese
                            From what I can establish it is a voltage regulator
                            If the USB port was outputing voltage I should see this on the USB meter so I can only assume that when I plug in a USB light and the Light is dim is because it using the battery voltage or the voltage from the Type c port that is used for charging and running the microscope of the Type C cable
                            Can anyone please give some input in regards to this
                            Has anyone had issues like this before
                            I will really appreciate any input
                            • lcdcaps1
                              • Oct 2011
                              • 322
                              As an experiment, I disconnect the battery and the USB light did not work when plugged into the USB port
                              This would mean that there is no voltage or current output from the USB port and can only think that the ln2U220par is responsible for supplying voltage to the USB port
                              Any help will really be appreciated
                              • m1ch43lzm
                                • Mar 2019
                                • 354
                                • Peru
                                The LN2220PAR looks like a step-up boost converter, your microscope is powered by a lithium battery? If yes that may be to boost the voltage for the usb port
                                This AliExpress listing claims to be a "replacement" of FP6291 and MT3608, both step-up converters
                                https://aliexpress.com/i/1005008340248788.html LN2220PAR MT36291 SOT23-6 24V Replace FP6291 MT3608
                                Attached the MT3608 and MT36291 data sheets, only difference is a current limit pin 6 which may be left floating on the MT36291, I can find MT3608 modules already assembled on a PCB very cheap on ali for less than $1
                                • lcdcaps1
                                  • Oct 2011
                                  • 322
                                  Thanks for the reply. The microscope is powered by Type C that charges the rechargeable battery
                                  The microscope can be used from the rechargeable battery without being plugged in
                                  • m1ch43lzm
                                    • Mar 2019
                                    • 354
                                    • Peru
                                    Measure voltages here
                                    Click image for larger version  Name:	boost1.jpg Views:	0 Size:	83.4 KB ID:	3641269
                                    At Vin it should be the battery voltage, Vout should be 5v
                                    Not sure about this resistor, is there a hole in it? To the left of that resistor is your 5v output for the USB port, measure resistance across it, it should be a very low value
                                    Measure resistance across the caps below, shouldn't be shorted
                                    Click image for larger version  Name:	check this.jpg Views:	0 Size:	85.8 KB ID:	3641270
                                    Click image for larger version  Name:	mt3608.jpg Views:	0 Size:	37.6 KB ID:	3641271
                                    One of the many readily available MT3608 modules on the online stores, the layout is very similar, you can harvest the IC from there if it's determined to be faulty
                                    EDIT: measure the current draw of your USB lights when plugged in to a regular USB power adapter, if it's too high it may have blown that resistor
                                    Maybe that USB port is supposed to work only with a USB stick for saving the pictures/video
                                    • lcdcaps1
                                      • Oct 2011
                                      • 322
                                      I was going to measure that resistor
                                      I will wait for the new parts
                                      The USB port is meant for the ring light and was working until one day it was not
                                      Thanks again
                                      • D3D_Tray
                                        Dell Latitude 5320 USB-C port issue
                                        by D3D_Tray
                                        Hey guys,
                                        so my half-year out of warranty Dell Latitiude 5320 (19817-1 SOUTH PEAK 13 10L) w/ i5-1145G7 and 16GB just started to act weirdly...
                                        The first/upper USB-C/TB port suddenly didn't accepted the charger every time and sometimes only a different one... or with a different cable but so far, the self-diagnostics didn't noticed anything so I suspected a dirty port.
                                        Today however... it stopped completely to accept a charger, the second/bottom one however does and after a half an hour, I notice something getting hot under there... blazing hot!
                                        04-24-2025, 10:27 AM
                                      • cajoeg
                                        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                        by cajoeg
                                        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                        02-10-2025, 04:01 PM
                                      • playit
                                        ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                                        by playit
                                        my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                                        my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                                        few years back ps2 mouse stopped working, but ps2...
                                        12-23-2024, 06:05 AM
                                      • ntec
                                        LED light issue
                                        by ntec
                                        Hi, I'm trying to fix my buddies rechargeable led work light made by olight and the model is odiance. For some reason now after a couple years of no issue, when powered off now, the led is faintly lit on 3 of the orange rows but as you can see from the first pic that's not where the leds are. The part that is faintly lit is beside the leds? Anyone know how that is possible? Is there small voltage still coming in somehow? The third pic is with the cover off....
                                        10-13-2024, 10:33 PM
                                      • rounin
                                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                        by rounin
                                        🛠 Original Issue
                                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                        04-19-2025, 01:18 AM
