Hello i am looking for Boardview file For Playstation 5 Digital and Disc Version Please
Hello i am looking for Boardview file For Playstation 5 Digital and Disc Version PleaseLast edited by Preciousfrank; 02-16-2025, 05:17 AM.
by ahmedtouHi everyone,
help me please
I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
I will share all the details with you, including the disc information.
Code:HL-DT-ST BD-RE GGW-H20N XA02 (ATA) Current Profile: BD-R Disc Information: Status: Empty State of Last Session: Empty Erasable: No Free Sectors: 12,219,392 Free Space: 25,025,314,816 bytes Free Time: 2715:27:17 (MM:SS:FF) Next
by sikocanI believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
SN: PF3G1REP
MODEL: 20KW-00J1AU
PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
Channel: BIOS Requests ONLY!
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Syph1979Hi all. First post here, so I hope I'm getting this right and operating in the spirit of things here.
I've been working on consoles for a while now. Always learning and trying new repairs, but I have one that has been stumped and I wondered if anyone with more experience could help?
I picked up a PS5 from eBay recently. It was described as not having the disc drive, but it was also a no power unit. On testing it was clearly an issue with the supply (no 12v), so I replaced that and then when I inserted the power lead, I got 3 beeps. So far, seems all related. As I was... -
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... - Loading...
